I run duplicati docker with a --volume that is a NFS mounted folder from my NAS, it has the 1000 gid and 1000 uid owner. I’ve mounted it in /test inside the docker using: docker run --volume /media/NAS/localTest:/test --network host duplicati/duplicati
My problem is that the root, which is the user that Duplicati is launched with, can’t access this test folder.
When I exec -ti /bin/bash into this container, as root, I can see the test folder, but can’t read what it contains.
# ls -l
drwxrwx--- 1 1000 1000 60 Dec 6 22:07 test
# cd test/
bash: cd: test/: Permission denied
I’ve tried to create a group test with gid 1000, make root part of the group. But somehow that doens’t let me in still:
# groupadd -g 1000 test
# usermod -a -G test root
# groups root
root : root test
# ls /test
ls: cannot open directory /test: Permission denied
Also I’ve tried to launch the docker with --user 1000:1000 but the duplicati server app fails:
docker run --volume /media/NAS/localTest:/test --user 1000:1000 --network host duplicati/duplicati
A serious error occurred in Duplicati: System.Exception: Failed to create, open or upgrade the database.
Error message: Access to the path "/data/Duplicati" is denied.
at Duplicati.Server.Program.GetDatabaseConnection (System.Collections.Generic.Dictionary`2[TKey,TValue] commandlineOptions) [0x00229] in <c5f097a49c0a4f1fb0f93cf3f5f218b1>:0
at Duplicati.Server.Program.RealMain (System.String[] _args) [0x001a7] in <c5f097a49c0a4f1fb0f93cf3f5f218b1>:0
Do you know any way to let me launch the docker, and let root access this folder?
NFS servers can map root to something less dangerous, like nobody:nogroup. See Root squash.
You could test by creating a folder with completely open permissions, then make a file, and ls -l it.
If you’re getting root squash, then you need to figure out how to turn it off or open perms up further…
Thanks a lot for your answer. I ended up figuring out that NFS permssions are far from simple and whatever the linux permissions are, the server can actually override them.
Also I’ve been able to setup ACL so that my local MyUser (UID 1000) as well as the duplicati docker (root) can access it. Here is how the ACL look like. There is a root squash setup as well.
I use neither NFS nor Linux ACLs (which are not the same as NFS ACLs, but must be translated).
Maybe somebody else can comment, or you’ll need to consult the wider Internet (or try searching).
