curryently Duplicati - 2.0.5.1_beta_2020-01-18 is running.
I tried to setup a sftp backup Job destined to “sftp.hidrive.strato.com”
IP instead of DNS is working fine.
I got this error:
System.Net.Sockets.SocketException (0x80004005): Could not resolve host ‘sftp.hidrive.strato.com’
at System.Net.Dns.Error_11001 (System.String hostName) [0x00015] in :0
at System.Net.Dns.GetHostByName (System.String hostName) [0x00024] in :0
at System.Net.Dns.GetHostEntry (System.String hostNameOrAddress) [0x00061] in :0
at System.Net.Dns.GetHostAddresses (System.String hostNameOrAddress) [0x00065] in :0
at Renci.SshNet.Abstractions.DnsAbstraction.GetHostAddresses (System.String hostNameOrAddress) [0x00000] in :0
at Renci.SshNet.Session.SocketConnect (System.String host, System.Int32 port) [0x00000] in :0
at Renci.SshNet.Session.Connect () [0x0008b] in :0
at Renci.SshNet.BaseClient.Connect () [0x00077] in :0
at Duplicati.Library.Backend.SSHv2.CreateConnection () [0x0010d] in <746b17b10a8d4b85bde5b362339e462c>:0
at Duplicati.Library.Backend.SSHv2+d__39.MoveNext () [0x0002c] in <746b17b10a8d4b85bde5b362339e462c>:0
at Duplicati.Library.Interface.BackendExtensions.TestList (Duplicati.Library.Interface.IBackend backend) [0x00017] in :0
at Duplicati.Library.Backend.SSHv2.Test () [0x00000] in <746b17b10a8d4b85bde5b362339e462c>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.TestConnection (System.String url, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x000b7] in :0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.POST (System.String key, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x00094] in :0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) [0x00289] in :0
Duplicati is running as a plugin on latest Open Media Vault 4.1. The name resolution from the host system is working.
Do you have any hint for me what might be broken?
