how do i disable wornings in duplicati 2
Welcome to the forums @Dan_Lupovitch.
While I don’t see a specific disable warnings option, there is the option to log only errors, which I think would suppress any warnings.
Here is a link to the manual about log-level.
Where are they? You got one answer for a custom log file. I don’t think the GUI popup can be disabled.
Best path for that is to try to remove them by resolving whatever concern caused warnings to appear…
