Wifi failed while a backup was running on a Windows 10 machine and this message came out:
“Detected non-empty blocksets with no associated blocks!”
which kept appearing if I tried to restart the operation.
Then I tried a database repair but it wouldn’t work. What am I supposed to do other than starting everything from scratch?
This is the contents of the log file:
May 19, 2019 10:06 PM: Result
MainOperation: Repair
RecreateDatabaseResults: null
ParsedResult: Success
Version: 2.0.4.5 (2.0.4.5_beta_2018-11-28)
EndTime: 19/05/2019 22:06:37 (1558296397)
BeginTime: 19/05/2019 22:06:23 (1558296383)
Duration: 00:00:14.3883605
Messages: [
2019-05-19 22:06:23 +02 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Repair has started,
2019-05-19 22:06:24 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2019-05-19 22:06:36 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (376 bytes),
2019-05-19 22:06:36 +02 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-RemoteUnwantedMissingFile]: removing file listed as Temporary: duplicati-20190519T175513Z.dlist.zip.aes,
2019-05-19 22:06:36 +02 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-SchedulingMissingFileForDelete]: scheduling missing file for deletion, currently listed as Uploading: duplicati-bff92596d0fbd4969950399f791eebe12.dblock.zip.aes,
Warnings:
Errors:
BackendStatistics:
RemoteCalls: 1
BytesUploaded: 0
BytesDownloaded: 0
FilesUploaded: 0
FilesDownloaded: 0
FilesDeleted: 0
FoldersCreated: 0
RetryAttempts: 0
UnknownFileSize: 0
UnknownFileCount: 0
KnownFileCount: 376
KnownFileSize: 19722258472
LastBackupDate: 01/01/0001 1:00:00 (-62135596800)
BackupListCount: 0
TotalQuotaSpace: 0
FreeQuotaSpace: 0
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
Messages: [
Warnings:
Errors:
