The commandline options follow the code, so the option you are looking for is here:
public override bool LoadAsDefault { get { return true; } }
/// <summary>
/// Gets a list of supported commandline arguments
/// </summary>
public override IList<ICommandLineArgument> SupportedCommands
get
return new List<ICommandLineArgument>(new ICommandLineArgument[] {
new CommandLineArgument(OPTION_URL, CommandLineArgument.ArgumentType.String, Strings.SendHttpMessage.SendhttpurlShort, Strings.SendHttpMessage.SendhttpurlLong),
new CommandLineArgument(OPTION_MESSAGE, CommandLineArgument.ArgumentType.String, Strings.SendHttpMessage.SendhttpmessageShort, Strings.SendHttpMessage.SendhttpmessageLong, DEFAULT_BODY),
new CommandLineArgument(OPTION_MESSAGE_PARAMETER_NAME, CommandLineArgument.ArgumentType.String, Strings.SendHttpMessage.SendhttpmessageparameternameShort, Strings.SendHttpMessage.SendhttpmessageparameternameLong, DEFAULT_MESSAGE_PARAMETER_NAME),
new CommandLineArgument(OPTION_EXTRA_PARAMETERS, CommandLineArgument.ArgumentType.String, Strings.SendHttpMessage.SendhttpextraparametersShort, Strings.SendHttpMessage.SendhttpextraparametersLong),
new CommandLineArgument(OPTION_SENDLEVEL, CommandLineArgument.ArgumentType.Enumeration, Strings.SendHttpMessage.SendhttplevelShort, Strings.SendHttpMessage.SendhttplevelLong(ParsedResultType.Success.ToString(), ParsedResultType.Warning.ToString(), ParsedResultType.Error.ToString(), ParsedResultType.Fatal.ToString(), "All"), DEFAULT_LEVEL, null, Enum.GetNames(typeof(ParsedResultType)).Union(new string[] { "All" } ).ToArray()),
new CommandLineArgument(OPTION_SENDALL, CommandLineArgument.ArgumentType.Boolean, Strings.SendHttpMessage.SendhttpanyoperationShort, Strings.SendHttpMessage.SendhttpanyoperationLong),
new CommandLineArgument(OPTION_VERB, CommandLineArgument.ArgumentType.String, Strings.SendHttpMessage.HttpverbShort, Strings.SendHttpMessage.HttpverbLong, "POST"),
new CommandLineArgument(OPTION_LOG_LEVEL, CommandLineArgument.ArgumentType.Enumeration, Strings.ReportHelper.OptionLoglevellShort, Strings.ReportHelper.OptionLoglevelLong, DEFAULT_LOG_LEVEL.ToString(), null, Enum.GetNames(typeof(Logging.LogMessageType))),
new CommandLineArgument(OPTION_LOG_FILTER, CommandLineArgument.ArgumentType.String, Strings.ReportHelper.OptionLogfilterShort, Strings.ReportHelper.OptionLogfilterLong),
new CommandLineArgument(OPTION_MAX_LOG_LINES, CommandLineArgument.ArgumentType.Integer, Strings.ReportHelper.OptionmaxloglinesShort, Strings.ReportHelper.OptionmaxloglinesLong, DEFAULT_LOGLINES.ToString()),
If you are only looking for fixing this in the WebUI, there is a default setting file here that is applied to new backups being created:
Backup: {
Settings: [
{Name: "encryption-module", Value: "aes"},
{Name: "compression-module", Value: "zip"},
{Name: "dblock-size", Value: "50mb"},
{Name: "keep-time", Value: ""}
Schedule: {
Repeat: "1D",
Time: "13:00:00",
AllowedDays: ["mon", "tue", "wed", "thu", "fri", "sat", "sun"]
