An example of a profiling log to read a dlist of a backup of C:\backup source\A.txt looks is below.
2023-03-15 18:40:14 -04 - [Verbose-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-ProcessingFilelistVolumes]: Processing filelist volume 1 of 2
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "Fileset" ("OperationID", "Timestamp", "VolumeID", "IsFullBackup") VALUES (1, 1678919836, 1, 0); SELECT last_insert_rowid();
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "Fileset" ("OperationID", "Timestamp", "VolumeID", "IsFullBackup") VALUES (1, 1678919836, 1, 0); SELECT last_insert_rowid(); took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: UPDATE "Fileset" SET "IsFullBackup" = True WHERE "ID" = 1;
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: UPDATE "Fileset" SET "IsFullBackup" = True WHERE "ID" = 1; took 0:00:00:00.001
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: SELECT "ID" FROM "PathPrefix" WHERE "Prefix" = "C:\backup source\"
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: SELECT "ID" FROM "PathPrefix" WHERE "Prefix" = "C:\backup source\" took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "PathPrefix" ("Prefix") VALUES ("C:\backup source\"); SELECT last_insert_rowid();
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "PathPrefix" ("Prefix") VALUES ("C:\backup source\"); SELECT last_insert_rowid(); took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: SELECT "ID" FROM "Blockset" WHERE "Length" = 1 AND "FullHash" = "VZrq0IJk1XldOQlxjN0Fq9SVcuhP5VWQ7vMaiKCP3/0="
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: SELECT "ID" FROM "Blockset" WHERE "Length" = 1 AND "FullHash" = "VZrq0IJk1XldOQlxjN0Fq9SVcuhP5VWQ7vMaiKCP3/0=" took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "Blockset" ("Length", "FullHash") VALUES (1,"VZrq0IJk1XldOQlxjN0Fq9SVcuhP5VWQ7vMaiKCP3/0="); SELECT last_insert_rowid();
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "Blockset" ("Length", "FullHash") VALUES (1,"VZrq0IJk1XldOQlxjN0Fq9SVcuhP5VWQ7vMaiKCP3/0="); SELECT last_insert_rowid(); took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: SELECT "Metadataset"."ID" FROM "Metadataset","Blockset" WHERE "Metadataset"."BlocksetID" = "Blockset"."ID" AND "Blockset"."FullHash" = "UW7CCxtLGw1gqSW6qxiGU8Xd/arQWsoW55bRZeAeQug=" AND "Blockset"."Length" = 137
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: SELECT "Metadataset"."ID" FROM "Metadataset","Blockset" WHERE "Metadataset"."BlocksetID" = "Blockset"."ID" AND "Blockset"."FullHash" = "UW7CCxtLGw1gqSW6qxiGU8Xd/arQWsoW55bRZeAeQug=" AND "Blockset"."Length" = 137 took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: SELECT "ID" FROM "Blockset" WHERE "Length" = 137 AND "FullHash" = "UW7CCxtLGw1gqSW6qxiGU8Xd/arQWsoW55bRZeAeQug="
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: SELECT "ID" FROM "Blockset" WHERE "Length" = 137 AND "FullHash" = "UW7CCxtLGw1gqSW6qxiGU8Xd/arQWsoW55bRZeAeQug=" took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "Blockset" ("Length", "FullHash") VALUES (137,"UW7CCxtLGw1gqSW6qxiGU8Xd/arQWsoW55bRZeAeQug="); SELECT last_insert_rowid();
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "Blockset" ("Length", "FullHash") VALUES (137,"UW7CCxtLGw1gqSW6qxiGU8Xd/arQWsoW55bRZeAeQug="); SELECT last_insert_rowid(); took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "Metadataset" ("BlocksetID") VALUES (2); SELECT last_insert_rowid();
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "Metadataset" ("BlocksetID") VALUES (2); SELECT last_insert_rowid(); took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: SELECT "ID" FROM "FileLookup" WHERE "PrefixID" = 1 AND "Path" = "A.txt" AND "BlocksetID" = 1 AND "MetadataID" = 1
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: SELECT "ID" FROM "FileLookup" WHERE "PrefixID" = 1 AND "Path" = "A.txt" AND "BlocksetID" = 1 AND "MetadataID" = 1 took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "FileLookup" ("PrefixID", "Path", "BlocksetID", "MetadataID") VALUES (1,"A.txt",1,1); SELECT last_insert_rowid();
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "FileLookup" ("PrefixID", "Path", "BlocksetID", "MetadataID") VALUES (1,"A.txt",1,1); SELECT last_insert_rowid(); took 0:00:00:00.000
The “Fileset” work at the top is probably once per dlist, but each file probably deals with “Blockset” (file data), “MetadataSet” (file attributes), “PathPrefix”, and “FileLookup”. The latter two form a space-efficient way to store the file path. Previously it stored full path intact. Now it stores the path’s prefix separately…
Looking at a second backup where file B.txt was added, one can see it finishing similarly and moving on.
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "FileLookup" ("PrefixID", "Path", "BlocksetID", "MetadataID") VALUES (1,"B.txt",3,2); SELECT last_insert_rowid(); took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: Starting - ExecuteReader: SELECT "Key", "Value" FROM "Configuration"
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: ExecuteReader: SELECT "Key", "Value" FROM "Configuration" took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: SELECT COUNT(*) FROM "Block" WHERE "Size" > 102400
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: SELECT COUNT(*) FROM "Block" WHERE "Size" > 102400 took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "Configuration"
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "Configuration" took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: INSERT INTO "Configuration" ("Key", "Value") VALUES ("blocksize", "102400")
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: INSERT INTO "Configuration" ("Key", "Value") VALUES ("blocksize", "102400") took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: INSERT INTO "Configuration" ("Key", "Value") VALUES ("blockhash", "SHA256")
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: INSERT INTO "Configuration" ("Key", "Value") VALUES ("blockhash", "SHA256") took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: INSERT INTO "Configuration" ("Key", "Value") VALUES ("filehash", "SHA256")
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: INSERT INTO "Configuration" ("Key", "Value") VALUES ("filehash", "SHA256") took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: INSERT INTO "Configuration" ("Key", "Value") VALUES ("passphrase", "no-encryption")
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: INSERT INTO "Configuration" ("Key", "Value") VALUES ("passphrase", "no-encryption") took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: INSERT INTO "Configuration" ("Key", "Value") VALUES ("repair-in-progress", "true")
2023-03-15 18:40:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: INSERT INTO "Configuration" ("Key", "Value") VALUES ("repair-in-progress", "true") took 0:00:00:00.000
2023-03-15 18:40:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-CommitUpdateFilesetFromRemote]: Starting - CommitUpdateFilesetFromRemote
2023-03-15 18:40:15 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-CommitUpdateFilesetFromRemote]: CommitUpdateFilesetFromRemote took 0:00:00:00.141
2023-03-15 18:40:15 -04 - [Information-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-FilelistsRestored]: Filelists restored, downloading 2 index files
For testing (because system is slow and there are lots of versions), add --version=0 to just do latest.
This might also prove or disprove a wild guess that you ran out of /tmp space by doing so many dlist.
Unable to recreate database, fails with “SQLite error cannot rollback - no transaction is active”
has a similar-looking stack, found by Google search on a couple of the things you had. Thanks for that.
