I’m currently trying to do a restore of a directory.
I currently have two backup locations one in a local enviroment and another one on the cloud.
When I try to restore my data, I get the error message database is locked
for both locations
code = Busy (5), message = System.Data.SQLite.SQLiteException (0x800007AF): database is locked
database is locked
at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteScalarInt64(IDbCommand self, Boolean writeLog, String cmd, Int64 defaultvalue, Object[] values)
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteScalarInt64(IDbCommand self, String cmd, Int64 defaultvalue, Object[] values)
at Duplicati.Library.Main.Database.LocalDatabase..ctor(IDbConnection connection, String operation)
at Duplicati.Library.Main.Database.LocalDatabase..ctor(String path, String operation, Boolean shouldclose)
at Duplicati.Library.Main.Database.LocalListDatabase..ctor(String path)
at Duplicati.Library.Main.Operation.ListFilesHandler.Run(IEnumerable`1 filterstrings, IFilter compositefilter)
at Duplicati.Library.Main.Controller.<>c__DisplayClass24_0.<List>b__0(ListResults result)
at Duplicati.Library.Main.Controller.RunAction[T](T result, IFilter& filter, Action`1 method)
at Duplicati.Library.Main.Controller.List(IEnumerable`1 filterstrings, IFilter filter)
I’m currently using the version Duplicati - 2.1.0.5_stable_2025-03-04
