- Add-On -
Hello @JonMikelV
I have just realised 2.0.4.17 got released. I have upgraded.
Error persits.
I have tested:
- Backup
- Repair
- new DB
- lokal DB deleted and then repaired.
Apr 12, 2019 2:16 PM: Failed while executing “Repair” with id: 4
System.Security.Cryptography.CryptographicException: File length is invalid —> System.IO.InvalidDataException: File length is invalid
bei SharpAESCrypt.SharpAESCrypt.Read(Byte buffer, Int32 offset, Int32 count)
bei Duplicati.Library.Utility.Utility.CopyStream(Stream source, Stream target, Boolean tryRewindSource, Byte buf)
bei Duplicati.Library.Encryption.EncryptionBase.Decrypt(Stream input, Stream output)
bei Duplicati.Library.Main.BackendManager.<>c__DisplayClass36_0.b__0()
bei System.Threading.Tasks.Task.Execute()
— Ende der internen Ausnahmestapelüberwachung —
bei Duplicati.Library.Main.AsyncDownloader.AsyncDownloaderEnumerator.AsyncDownloadedFile.get_TempFile()
bei Duplicati.Library.Main.Operation.RecreateDatabaseHandler.DoRun(LocalDatabase dbparent, Boolean updating, IFilter filter, NumberedFilterFilelistDelegate filelistfilter, BlockVolumePostProcessor blockprocessor)
bei Duplicati.Library.Main.Operation.RecreateDatabaseHandler.Run(String path, IFilter filter, NumberedFilterFilelistDelegate filelistfilter, BlockVolumePostProcessor blockprocessor)
bei Duplicati.Library.Main.Operation.RepairHandler.RunRepairLocal(IFilter filter)
bei Duplicati.Library.Main.Operation.RepairHandler.Run(IFilter filter)
bei Duplicati.Library.Main.Controller.RunAction[T](T result, String& paths, IFilter& filter, Action`1 method)
bei Duplicati.Library.Main.Controller.Repair(IFilter filter)
bei Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)
Apr 12, 2019 2:11 PM: Failed while executing “Repair” with id: 4
Apr 12, 2019 2:08 PM: Failed while executing “Repair” with id: 4
Apr 12, 2019 2:07 PM: Failed while executing “Backup” with id: 4
Duplicati.Library.Interface.UserInformationException: The database was attempted repaired, but the repair did not complete. This database may be incomplete and the backup process cannot continue. You may delete the local database and attempt to repair it again.
bei Duplicati.Library.Main.Operation.BackupHandler.d__19.MoveNext()
— Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde —
bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
bei CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task)
bei Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.b__0(BackupResults result)
bei Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter)
