After upgrading Duplicati from 2.3.0.4 to 2.4.0.0_stable_2026-09-03 using the cocolatey package (and quitting Duplicati beforehand) on Windows, Duplicati only displays an error message:
Duplicati.Library.Interface.UserInformationException: Server crashed on startup
---> System.Exception: Ein schwerwiegender Fehler trat in Duplicati auf: Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: 'no such column: "OperationType" - should this be a string literal in single-quotes?'.
at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)
at Microsoft.Data.Sqlite.SqliteCommand.PrepareAndEnumerateStatements()+MoveNext()
at Microsoft.Data.Sqlite.SqliteCommand.GetStatements()+MoveNext()
at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()
at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)
at Microsoft.Data.Sqlite.SqliteCommand.ExecuteDbDataReader(CommandBehavior behavior)
at Duplicati.Server.Database.Connection.Read[T](IDbCommand cmd, Func`2 f)+MoveNext()
at System.Linq.Enumerable.<ToArray>g__EnumerableToArray|324_0[TSource](IEnumerable`1 source)
at Duplicati.Server.Database.Connection.ReadFromDb[T](Func`2 f, Action`1 prep)
at Duplicati.Server.Database.Connection.get_Backups()
at Duplicati.Server.Program.GetMaxVolumeSize(Connection connection, Dictionary`2 commandlineOptions)
at Duplicati.Server.Program.CheckTempDirFreeSpace(Connection connection, Dictionary`2 commandlineOptions)
at Duplicati.Server.Program.EmitWarningsForConfigurationIssues(Connection connection, IApplicationSettings applicationSettings, Dictionary`2 commandlineOptions)
at Duplicati.Server.Program.Main(IApplicationSettings applicationSettings, String[] _args)
---> Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: 'no such column: "OperationType" - should this be a string literal in single-quotes?'.
at Duplicati.GUI.TrayIcon.HostedInstanceKeeper.<>c__DisplayClass5_0.<.ctor>b__0(Object _)
at Duplicati.GUI.TrayIcon.HostedInstanceKeeper..ctor(IApplicationSettings applicationSettings, String[] args)
at Duplicati.GUI.TrayIcon.Program.RunMain(String[] _args)
at Duplicati.GUI.TrayIcon.Program.Main(String[] _args)
I can’t even copy this error message from the error window as it closes as soon as I want to copy it. Found this on AppData\Local\Duplicati\Duplicati.GUI.TrayIcon-crashlog.txt
There was a different error message before about not being able to create a backup database as the file could not be accessed, but I wasn’t able to copy this and can’t find it in a log file anymore.
What shall I do?
