I had an error in DB with my backup so I decided to delete and create DB.
But now I see that progress stuck in one state. It’s almost done (may be 97%) and nothing’s happened neither in ExplicitOnly Logs in About\Logs nor with DB file.
Before I see that dbname.journal was created, but now it’s absent. So I think everything was commited to DB.
I have a big backup and I don’t want to do it again. And I think there is a big probability that it will happened again.
D2 ver is: 2.0.7.1_beta_2023-05-25 (x64).
Windows Server 2019 x64.
So… What should I do with it?
P.S. I put log text and ‘Failed to load assembly’ I see every time I refresh the page. But I think the problem is not in it.
* Sep 6, 2023 7:35 AM: Failed to load assembly C:\Program Files\Duplicati 2\Xamarin.Mac.dll, error message: Неабстрактный метод, не являющийся методом .cctor в интерфейсе.
* Sep 5, 2023 10:55 PM: Failed to load assembly C:\Program Files\Duplicati 2\Xamarin.Mac.dll, error message: Неабстрактный метод, не являющийся методом .cctor в интерфейсе.
* Sep 5, 2023 10:11 PM: Failed to load assembly C:\Program Files\Duplicati 2\Xamarin.Mac.dll, error message: Неабстрактный метод, не являющийся методом .cctor в интерфейсе.
* Sep 5, 2023 8:57 PM: Failed to load assembly C:\Program Files\Duplicati 2\Xamarin.Mac.dll, error message: Неабстрактный метод, не являющийся методом .cctor в интерфейсе.
* Sep 5, 2023 5:16 PM: CommitRestoredBlocklist took 0:00:00:00.003
* Sep 5, 2023 5:16 PM: Starting - CommitRestoredBlocklist
* Sep 5, 2023 5:16 PM: ExecuteNonQuery: INSERT INTO "BlocksetEntry" ("BlocksetID", "Index", "BlockID") SELECT DISTINCT "H"."BlocksetID", "H"."Index", "H"."BlockID" FROM (SELECT "E"."BlocksetID" AS "BlocksetID", "D"."FullIndex" AS "Index", "F"."ID" AS "BlockID" FROM ( SELECT "E"."BlocksetID", "F"."Index" + ("E"."BlocklistIndex" * 3200) AS "FullIndex", "F"."BlockHash", MIN(102400, "E"."Length" - (("F"."Index" + ("E"."BlocklistIndex" * 3200)) * 102400)) AS "BlockSize", "E"."Hash", "E"."BlocklistSize", "E"."BlocklistHash" FROM ( SELECT * FROM ( SELECT "A"."BlocksetID", "A"."Index" AS "BlocklistIndex", MIN(3200 * 32, ((("B"."Length" + 102400 - 1) / 102400) - ("A"."Index" * (3200))) * 32) AS "BlocklistSize", "A"."Hash" AS "BlocklistHash", "B"."Length" FROM "BlocklistHash" A, "Blockset" B WHERE "B"."ID" = "A"."BlocksetID" ) C, "Block" D WHERE "C"."BlocklistHash" = "D"."Hash" AND "C"."BlocklistSize" = "D"."Size" ) E, "TempBlocklist-D6D3ACCEBEBADC4EB70F991DBD7A7B69" F WHERE "F"."BlocklistHash" = "E"."Hash" ORDER BY "E"."BlocksetID", "FullIndex" ) D, "BlocklistHash" E, "Block" F, "Block" G WHERE "D"."BlocksetID" = "E"."BlocksetID" AND "D"."BlocklistHash" = "E"."Hash" AND "D"."BlocklistSize" = "G"."Size" AND "D"."BlocklistHash" = "G"."Hash" AND "D"."Blockhash" = "F"."Hash" AND "D"."BlockSize" = "F"."Size" UNION SELECT "Blockset"."ID" AS "BlocksetID", 0 AS "Index", "Block"."ID" AS "BlockID" FROM "Blockset", "Block", "TempSmalllist-14A3B0B131B8B0448474829DBF32C5D3" S WHERE "Blockset"."Fullhash" = "S"."FileHash" AND "S"."BlockHash" = "Block"."Hash" AND "S"."BlockSize" = "Block"."Size" AND "Blockset"."Length" = "S"."BlockSize" AND "Blockset"."Length" <= 102400 ) H WHERE ("H"."BlocksetID" || ':' || "H"."Index") NOT IN (SELECT ("ExistingBlocksetEntries"."BlocksetID" || ':' || "ExistingBlocksetEntries"."Index") FROM "BlocksetEntry" "ExistingBlocksetEntries" ) took 0:00:05:47.415
