Crash on startup in 2.3.0.4 (Stable), not in 2.3.0.106_canary_2026-07-03
Hi there! I upgraded from 2.3.0.106 (canary) to v2.3.0.4_stable_2026-07-09 on macOS arm64, and the new release crashes on startup. (It’s an abort; I’ve got the crash trace. Don’t see anything particularly useful crash log but then again, I don’t know what Duplicati logs are useful!) Re-downgrading to 2.3.0.106 makes Duplicati work again, thankfully.
Will happily help debugging however I can. :slight_smile:
Summary
Translated Report (Full Report Below)
Process: duplicati [39199]
Path: /Applications/Duplicati.app/Contents/MacOS/duplicati
Identifier: com.duplicati.app
Version: 2.3.0.4_stable_2026-07-09 (2.3.0.4_stable_2026-07-09)
Code Type: ARM-64 (Native)
Role: Default
Parent Process: launchd [1]
Coalition: com.duplicati.app [14021]
User ID: 501
Date/Time: 2026-07-19 09:35:38.1951 -0400
Launch Time: 2026-07-19 09:35:32.4069 -0400
Hardware Model: MacBookPro17,1
OS Version: macOS 26.5.2 (25F84)
Release Type: User
Crash Reporter Key: A6A57FE6-ADC1-FD22-94C0-B2885140EF4A
Incident Identifier: 198F1EA9-0971-4225-9CE1-DA743B57678F
Sleep/Wake UUID: 6F7AB970-6249-417F-9F5F-C65E6FFB3833
Time Awake Since Boot: 160000 seconds
Time Since Wake: 904 seconds
System Integrity Protection: enabled
Triggered by Thread: 0, Dispatch Queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 6, Abort trap: 6
Terminating Process: duplicati [39199]
Application Specific Information:
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x188eba5e8 __pthread_kill + 8
1 libsystem_pthread.dylib 0x188ef58d8 pthread_kill + 296
2 libsystem_c.dylib 0x188dfc644 abort + 148
3 libcoreclr.dylib 0x105f2e3ac PROCAbort + 72
4 libcoreclr.dylib 0x105f2e2b8 TerminateProcess + 176
5 libcoreclr.dylib 0x105e5d3e4 SfiNextWorker(StackFrameIterator*, unsigned int*, bool*, bool*) + 960
6 libcoreclr.dylib 0x105e5a654 DispatchExSecondPass(ExInfo*) + 128
7 libcoreclr.dylib 0x105e5a82c DispatchRethrownManagedException(_CONTEXT*) + 244
8 libcoreclr.dylib 0x105dd8420 IL_Rethrow() + 96
9 ??? 0x109641e6c ???
10 ??? 0x109641cf4 ???
11 libcoreclr.dylib 0x105ef3020 CallDescrWorkerInternal + 132
12 libcoreclr.dylib 0x105d8b514 MethodDescCallSite::CallTargetWorker(unsigned long long const*, unsigned long long*, int) + 792
13 libcoreclr.dylib 0x105c930ac RunMain(MethodDesc*, short, int*, PtrArray**) + 644
14 libcoreclr.dylib 0x105c933d8 Assembly::ExecuteMainMethod(PtrArray**, int) + 268
15 libcoreclr.dylib 0x105cb6a70 CorHost2::ExecuteAssembly(unsigned int, char16_t const*, int, char16_t const**, unsigned int*) + 648
16 libcoreclr.dylib 0x105b7353c coreclr_execute_assembly + 232
17 libhostpolicy.dylib 0x100c2ff58 run_app_for_context(hostpolicy_context_t const&, int, char const**) + 1068
18 libhostpolicy.dylib 0x100c30d88 corehost_main + 348
19 libhostfxr.dylib 0x100bc05d0 fx_muxer_t::handle_exec_host_command(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator> const&, host_startup_info_t const&, std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator> const&, std::__1::unordered_map<known_options, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator>, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator>>>, known_options_hash, std::__1::equal_to<known_options>, std::__1::allocator<std::__1::pair<known_options const, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator>, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator>>>>>> const&, int, char const**, int, host_mode_t, bool, char*, int, int*) + 1268
20 libhostfxr.dylib 0x100bbf3d0 fx_muxer_t::execute(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator>, int, char const**, host_startup_info_t const&, char*, int, int*) + 968
21 libhostfxr.dylib 0x100bbadfc hostfxr_main_startupinfo + 128
22 duplicati 0x100b1de4c exe_start(int, char const**) + 1372
23 duplicati 0x100b1e124 main + 184
24 dyld 0x188b37e00 start + 6992
Thread 1:
0 libsystem_kernel.dylib 0x188eb1c34 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x188ec4574 mach_msg2_internal + 76
2 libsystem_kernel.dylib 0x188eba9c0 mach_msg_overwrite + 480
3 libsystem_kernel.dylib 0x188eb1fc0 mach_msg + 24
4 libcoreclr.dylib 0x105f356f8 MachMessage::Receive(unsigned int) + 80
5 libcoreclr.dylib 0x105f34a98 SEHExceptionThread(void*) + 156
6 libsystem_pthread.dylib 0x188ef5c58 _pthread_start + 136
7 libsystem_pthread.dylib 0x188ef0c1c thread_start + 8
Thread 2:: .NET SynchManager
0 libsystem_kernel.dylib 0x188ebf610 __poll_nocancel + 8
1 libcoreclr.dylib 0x105f299cc CorUnix::CPalSynchronizationManager::WorkerThread(void*) + 248
2 libcoreclr.dylib 0x105f32624 CorUnix::CPalThread::ThreadEntry(void*) + 352
3 libsystem_pthread.dylib 0x188ef5c58 _pthread_start + 136
4 libsystem_pthread.dylib 0x188ef0c1c thread_start + 8
Thread 3:: .NET EventPipe
1 libcoreclr.dylib 0x105c1838c ds_ipc_poll(_DiagnosticsIpcPollHandle*, unsigned long, unsigned int, void ()(char const, unsigned int)) + 180
2 libcoreclr.dylib 0x105b9b180 ds_ipc_stream_factory_get_next_available_stream(void ()(char const, unsigned int)) + 796
3 libcoreclr.dylib 0x105b9f734 server_thread(void*) + 364
4 libcoreclr.dylib 0x105f32624 CorUnix::CPalThread::ThreadEntry(void*) + 352
5 libsystem_pthread.dylib 0x188ef5c58 _pthread_start + 136
6 libsystem_pthread.dylib 0x188ef0c1c thread_start + 8
Thread 4:: .NET DebugPipe
0 libsystem_kernel.dylib 0x188eb2948 __open_nocancel + 8
1 libsystem_kernel.dylib 0x188ec6c34 open$NOCANCEL + 64
2 libcoreclr.dylib 0x105c17d5c TwoWayPipe::WaitForConnection() + 40
3 libcoreclr.dylib 0x105c1315c DbgTransportSession::TransportWorker() + 200
4 libcoreclr.dylib 0x105c120e0 DbgTransportSession::TransportWorkerStatic(void*) + 40
5 libcoreclr.dylib 0x105f32624 CorUnix::CPalThread::ThreadEntry(void*) + 352
Thread 5:: .NET Debugger
0 libsystem_kernel.dylib 0x188eb550c __psynch_cvwait + 8
1 libsystem_pthread.dylib 0x188ef6154 _pthread_cond_wait + 1024
2 libcoreclr.dylib 0x105f28244 CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*) + 116
3 libcoreclr.dylib 0x105f27ff0 CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*) + 300
4 libcoreclr.dylib 0x105f2b414 CorUnix::InternalWaitForMultipleObjectsEx(CorUnix::CPalThread*, unsigned int, void* const*, int, unsigned int, int, int) + 1292
5 libcoreclr.dylib 0x105c1091c DebuggerRCThread::MainLoop() + 220
6 libcoreclr.dylib 0x105c107d8 DebuggerRCThread::ThreadProc() + 260
7 libcoreclr.dylib 0x105c10588 DebuggerRCThread::ThreadProcStatic(void*) + 56
8 libcoreclr.dylib 0x105f32624 CorUnix::CPalThread::ThreadEntry(void*) + 352
9 libsystem_pthread.dylib 0x188ef5c58 _pthread_start + 136
10 libsystem_pthread.dylib 0x188ef0c1c thread_start + 8
Thread 6:
2 libcoreclr.dylib 0x105f28324 CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*) + 340
5 libcoreclr.dylib 0x105f2b704 WaitForSingleObjectEx + 80
6 libcoreclr.dylib 0x105e30a54 CLREventBase::WaitEx(unsigned int, WaitMode, PendingSync*) + 188
7 libcoreclr.dylib 0x105dbe364 FinalizerThread::WaitForFinalizerEvent(CLREvent*) + 48
8 libcoreclr.dylib 0x105dbe4f4 FinalizerThread::FinalizerThreadWorker(void*) + 144
9 libcoreclr.dylib 0x105d5c8e0 ManagedThreadBase::KickOff(void ()(void), void*) + 236
10 libcoreclr.dylib 0x105dbe93c FinalizerThread::FinalizerThreadStart(void*) + 92
11 libcoreclr.dylib 0x105f32624 CorUnix::CPalThread::ThreadEntry(void*) + 352
12 libsystem_pthread.dylib 0x188ef5c58 _pthread_start + 136
13 libsystem_pthread.dylib 0x188ef0c1c thread_start + 8
Thread 7:
4 libcoreclr.dylib 0x105f2bcb8 SleepEx + 160
5 libcoreclr.dylib 0x105d5ff0c TieredCompilationManager::BackgroundWorkerStart() + 176
6 libcoreclr.dylib 0x105d5fde4 TieredCompilationManager::BackgroundWorkerBootstrapper1(void*) + 96
7 libcoreclr.dylib 0x105d5c8e0 ManagedThreadBase::KickOff(void ()(void), void*) + 236
8 libcoreclr.dylib 0x105d5fd0c TieredCompilationManager::BackgroundWorkerBootstrapper0(void*) + 40
9 libcoreclr.dylib 0x105f32624 CorUnix::CPalThread::ThreadEntry(void*) + 352
10 libsystem_pthread.dylib 0x188ef5c58 _pthread_start + 136
11 libsystem_pthread.dylib 0x188ef0c1c thread_start + 8
Thread 8:
Thread 9:
Thread 10:: .NET SigHandler
0 libsystem_kernel.dylib 0x188eb3cac __read_nocancel + 8
1 libSystem.Native.dylib 0x100c87768 SignalHandlerLoop + 112
Thread 11:: .NET Sockets
0 libsystem_kernel.dylib 0x188eb7fc4 kevent + 8
1 libSystem.Native.dylib 0x100c84610 SystemNative_WaitForSocketEvents + 80
2 ??? 0x10a5bd670 ???
3 ??? 0x10a5f29d0 ???
4 ??? 0x10873a274 ???
5 libcoreclr.dylib 0x105ef3020 CallDescrWorkerInternal + 132
6 libcoreclr.dylib 0x105d8b190 DispatchCallSimple(unsigned long*, unsigned int, unsigned long, unsigned int) + 276
7 libcoreclr.dylib 0x105d9e870 KickOffThread_Worker(void*) + 144
8 libcoreclr.dylib 0x105d5c8e0 ManagedThreadBase::KickOff(void ()(void), void*) + 236
9 libcoreclr.dylib 0x105d9ccac KickOffThread(void*) + 212
10 libcoreclr.dylib 0x105f32624 CorUnix::CPalThread::ThreadEntry(void*) + 352
11 libsystem_pthread.dylib 0x188ef5c58 _pthread_start + 136
12 libsystem_pthread.dylib 0x188ef0c1c thread_start + 8
Thread 12:: .NET Timer
5 libcoreclr.dylib 0x105d597b0 Thread::DoAppropriateWaitWorker(int, void**, int, unsigned int, WaitMode, void*) + 700
6 libcoreclr.dylib 0x105d55188 Thread::DoAppropriateWait(int, void**, int, unsigned int, WaitMode, PendingSync*) + 136
7 libcoreclr.dylib 0x105da381c WaitHandle_WaitOneCore + 108
8 ??? 0x10873e7f4 ???
9 ??? 0x10875dc70 ???
10 ??? 0x10873a284 ???
12 libcoreclr.dylib 0x105d8b190 DispatchCallSimple(unsigned long*, unsigned int, unsigned long, unsigned int) + 276
13 libcoreclr.dylib 0x105d9e870 KickOffThread_Worker(void*) + 144
14 libcoreclr.dylib 0x105d5c8e0 ManagedThreadBase::KickOff(void ()(void), void*) + 236
15 libcoreclr.dylib 0x105d9ccac KickOffThread(void*) + 212
16 libcoreclr.dylib 0x105f32624 CorUnix::CPalThread::ThreadEntry(void*) + 352
17 libsystem_pthread.dylib 0x188ef5c58 _pthread_start + 136
18 libsystem_pthread.dylib 0x188ef0c1c thread_start + 8
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000000 x1: 0x0000000000000000 x2: 0x0000000000000000 x3: 0x0000000000000000
x4: 0x0000000000000000 x5: 0x00000000000000a0 x6: 0x0000000000000002 x7: 0x0000000000000000
x8: 0xa8a71598d1bcdbe9 x9: 0xa8a7159924b30669 x10: 0x0000000000000002 x11: 0x00000000fffffffd
x12: 0x0000000000000000 x13: 0x0000000000000000 x14: 0x0000000000000000 x15: 0x0000000000000000
x16: 0x0000000000000148 x17: 0x00000001f673b088 x18: 0x0000000000000000 x19: 0x0000000000000006
x20: 0x0000000000000103 x21: 0x00000001f50fde60 x22: 0x000000016f2ddc20 x23: 0x00000001011a1cc8
x24: 0x000000016f2ddb70 x25: 0x00000001011aeeb0 x26: 0x000000016f2dec10 x27: 0x0000000109641cf4
x28: 0x0000000000000000 fp: 0x000000016f2dd8e0 lr: 0x0000000188ef58d8
sp: 0x000000016f2dd8c0 pc: 0x0000000188eba5e8 cpsr: 0x40001000
far: 0x0000000000000000 esr: 0x56000080 (Syscall)
Binary Images:
0x100b1c000 - 0x100b2bfff com.duplicati.app (2.3.0.4_stable_2026-07-09) <7f6ded36-a870-3892-a44f-844208e78bb9> /Applications/Duplicati.app/Contents/MacOS/duplicati
0x100bb4000 - 0x100bf3fff libhostfxr.dylib () /Applications/Duplicati.app/Contents/MacOS/libhostfxr.dylib
0x100c18000 - 0x100c53fff libhostpolicy.dylib (
) /Applications/Duplicati.app/Contents/MacOS/libhostpolicy.dylib
0x105b70000 - 0x105fbbfff libcoreclr.dylib () /Applications/Duplicati.app/Contents/MacOS/libcoreclr.dylib
0x100c7c000 - 0x100c8bfff libSystem.Native.dylib (
) /Applications/Duplicati.app/Contents/MacOS/libSystem.Native.dylib
0x1078b0000 - 0x107afffff libclrjit.dylib () <5181947f-e0a5-37ef-ab0c-83e9657579c7> /Applications/Duplicati.app/Contents/MacOS/libclrjit.dylib
0x131c18000 - 0x131c27fff libSystem.Security.Cryptography.Native.Apple.dylib (
) /Applications/Duplicati.app/Contents/MacOS/libSystem.Security.Cryptography.Native.Apple.dylib
0x131ca4000 - 0x131cb3fff libMono.Unix.dylib () <2f6ba079-e5e1-38bd-bee5-c9fd3f141468> /Applications/Duplicati.app/Contents/MacOS/libMono.Unix.dylib
0x132380000 - 0x1324cffff libe_sqlite3.dylib (
) /Applications/Duplicati.app/Contents/MacOS/libe_sqlite3.dylib
0x188eb1000 - 0x188eee2af libsystem_kernel.dylib () /usr/lib/system/libsystem_kernel.dylib
0x188eef000 - 0x188efbb3b libsystem_pthread.dylib (
) <4f33683c-18c8-39a1-800b-2e3bd43bcc13> /usr/lib/system/libsystem_pthread.dylib
0x188d84000 - 0x188e04d9f libsystem_c.dylib () <694b7881-1bf3-3d0f-8f19-b50ae4e8ef8a> /usr/lib/system/libsystem_c.dylib
0x0 - 0xffffffffffffffff ??? (
) <00000000-0000-0000-0000-000000000000> ???
0x188b18000 - 0x188bbe217 dyld () /usr/lib/dyld
0x188e05000 - 0x188e95ae7 libc++.1.dylib (
) <5013c0f8-84a9-3b56-9feb-c353816a750f> /usr/lib/libc++.1.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=873.3M resident=0K(0%) swapped_out_or_unallocated=873.3M(100%)
Writable regions: Total=184.0M written=514K(0%) resident=514K(0%) swapped_out=0K(0%) unallocated=183.5M(100%)
                            VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 256K 1
Kernel Alloc Once 32K 1
MALLOC 52.8M 18
MALLOC guard page 3632K 4
Memory Tag 22 64.0M 1
STACK GUARD 56.2M 13
Stack 22.4M 13
VM_ALLOCATE 1.1G 323
VM_ALLOCATE (reserved) 320K 2 reserved VM address space (unallocated)
__AUTH 1328K 150
__AUTH_CONST 17.7M 343
__CTF 824 1
__DATA 4679K 309
__DATA_CONST 16.7M 350
__DATA_DIRTY 1338K 287
__FONT_DATA 2352 1
__LINKEDIT 575.5M 10
__OBJC_RO 79.1M 1
__OBJC_RW 2598K 1
__TEXT 297.7M 360
__TPRO_CONST 128K 2
mapped file 85.8M 184
page table in kernel 514K 1
shared memory 80K 4
TOTAL 2.4G 2380
TOTAL, minus reserved VM space 2.4G 2380
Full Report
{“app_name”:“duplicati”,“timestamp”:“2026-07-19 09:35:39.00 -0400”,“app_version”:“2.3.0.4_stable_2026-07-09”,“slice_uuid”:“7f6ded36-a870-3892-a44f-844208e78bb9”,“build_version”:“2.3.0.4_stable_2026-07-09”,“platform”:1,“bundleID”:“com.duplicati.app”,“share_with_app_devs”:1,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 26.5.2 (25F84)”,“roots_installed”:0,“name”:“duplicati”,“incident_id”:“198F1EA9-0971-4225-9CE1-DA743B57678F”}
“uptime” : 160000,
“procRole” : “Default”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookPro17,1”,
“coalitionID” : 14021,
“osVersion” : {
“train” : “macOS 26.5.2”,
“build” : “25F84”,
“releaseType” : “User”
“captureTime” : “2026-07-19 09:35:38.1951 -0400”,
“codeSigningMonitor” : 1,
“incident” : “198F1EA9-0971-4225-9CE1-DA743B57678F”,
“pid” : 39199,
“translated” : false,
“cpuType” : “ARM-64”,
“procLaunch” : “2026-07-19 09:35:32.4069 -0400”,
“procStartAbsTime” : 3985042988654,
“procExitAbsTime” : 3985181885879,
“procName” : “duplicati”,
“procPath” : “/Applications/Duplicati.app/Contents/MacOS/duplicati”,
“bundleInfo” : {“CFBundleShortVersionString”:“2.3.0.4_stable_2026-07-09”,“CFBundleVersion”:“2.3.0.4_stable_2026-07-09”,“CFBundleIdentifier”:“com.duplicati.app”},
“storeInfo” : {“deviceIdentifierForVendor”:“CAB4A65A-F98D-55AE-BE9C-C98D83E4DB75”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.duplicati.app”,
“crashReporterKey” : “A6A57FE6-ADC1-FD22-94C0-B2885140EF4A”,
“appleIntelligenceStatus” : {“reasons”:[“assetIsNotReady”,“notOptedIn”],“state”:“unavailable”},
“developerMode” : 1,
“bootProgressRegister” : “0x2f000000”,
“codeSigningID” : “com.duplicati.app”,
“codeSigningTeamID” : “K5M7VR369R”,
“codeSigningFlags” : 570503953,
“codeSigningValidationCategory” : 6,
“codeSigningTrustLevel” : 4294967295,
“codeSigningAuxiliaryInfo” : 0,
“instructionByteStream” : {“beforePC”:“fyMD1f17v6n9AwCRCuD/l78DAJH9e8Go/w9f1sADX9YQKYDSARAA1A==”,“atPC”:“AwEAVH8jA9X9e7+p/QMAkf/f/5e/AwCR/XvBqP8PX9bAA1/WcAqA0g==”},
“bootSessionUUID” : “27AD5195-94A9-4CC9-B5EA-87A52A969F20”,
“wakeTime” : 904,
“sleepWakeUUID” : “6F7AB970-6249-417F-9F5F-C65E6FFB3833”,
“sip” : “enabled”,
“exception” : {“codes”:“0x0000000000000000, 0x0000000000000000”,“rawCodes”:[0,0],“type”:“EXC_CRASH”,“signal”:“SIGABRT”},
“termination” : {“flags”:0,“code”:6,“namespace”:“SIGNAL”,“indicator”:“Abort trap: 6”,“byProc”:“duplicati”,“byPid”:39199},
“asi” : {“libsystem_c.dylib”:[“abort() called”]},
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:3592244,“threadState”:{“x”:[{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:160},{“value”:2},{“value”:0},{“value”:12152705865580600297},{“value”:12152705866972464745},{“value”:2},{“value”:4294967293},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:328},{“value”:8429744264},{“value”:0},{“value”:6},{“value”:259},{“value”:8406425184,“symbolLocation”:224,“symbol”:“_main_thread”},{“value”:6160243744},{“value”:4313455816},{“value”:6160243568},{“value”:4313509552},{“value”:6160247824},{“value”:4452523252},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6592354520},“cpsr”:{“value”:1073745920},“fp”:{“value”:6160242912},“sp”:{“value”:6160242880},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592112104,“matchesCrashFrame”:1},“far”:{“value”:0}},“queue”:“com.apple.main-thread”,“frames”:[{“imageOffset”:38376,“symbol”:“__pthread_kill”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:26840,“symbol”:“pthread_kill”,“symbolLocation”:296,“imageIndex”:10},{“imageOffset”:493124,“symbol”:“abort”,“symbolLocation”:148,“imageIndex”:11},{“imageOffset”:3924908,“symbol”:“PROCAbort”,“symbolLocation”:72,“imageIndex”:3},{“imageOffset”:3924664,“symbol”:“TerminateProcess”,“symbolLocation”:176,“imageIndex”:3},{“imageOffset”:3068900,“symbol”:“SfiNextWorker(StackFrameIterator*, unsigned int*, bool*, bool*)”,“symbolLocation”:960,“imageIndex”:3},{“imageOffset”:3057236,“symbol”:“DispatchExSecondPass(ExInfo*)”,“symbolLocation”:128,“imageIndex”:3},{“imageOffset”:3057708,“symbol”:“DispatchRethrownManagedException(_CONTEXT*)”,“symbolLocation”:244,“imageIndex”:3},{“imageOffset”:2524192,“symbol”:“IL_Rethrow()”,“symbolLocation”:96,“imageIndex”:3},{“imageOffset”:4452523628,“imageIndex”:12},{“imageOffset”:4452523252,“imageIndex”:12},{“imageOffset”:3682336,“symbol”:“CallDescrWorkerInternal”,“symbolLocation”:132,“imageIndex”:3},{“imageOffset”:2209044,“symbol”:“MethodDescCallSite::CallTargetWorker(unsigned long long const*, unsigned long long*, int)”,“symbolLocation”:792,“imageIndex”:3},{“imageOffset”:1192108,“symbol”:“RunMain(MethodDesc*, short, int*, PtrArray**)”,“symbolLocation”:644,“imageIndex”:3},{“imageOffset”:1192920,“symbol”:“Assembly::ExecuteMainMethod(PtrArray**, int)”,“symbolLocation”:268,“imageIndex”:3},{“imageOffset”:1337968,“symbol”:“CorHost2::ExecuteAssembly(unsigned int, char16_t const*, int, char16_t const**, unsigned int*)”,“symbolLocation”:648,“imageIndex”:3},{“imageOffset”:13628,“symbol”:“coreclr_execute_assembly”,“symbolLocation”:232,“imageIndex”:3},{“imageOffset”:98136,“symbol”:“run_app_for_context(hostpolicy_context_t const&, int, char const**)”,“symbolLocation”:1068,“imageIndex”:2},{“imageOffset”:101768,“symbol”:“corehost_main”,“symbolLocation”:348,“imageIndex”:2},{“imageOffset”:50640,“symbol”:“fx_muxer_t::handle_exec_host_command(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator> const&, host_startup_info_t const&, std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator> const&, std::__1::unordered_map<known_options, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator>, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator>>>, known_options_hash, std::__1::equal_to<known_options>, std::__1::allocator<std::__1::pair<known_options const, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator>, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator>>>>>> const&, int, char const**, int, host_mode_t, bool, char*, int, int*)”,“symbolLocation”:1268,“imageIndex”:1},{“imageOffset”:46032,“symbol”:“fx_muxer_t::execute(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator>, int, char const**, host_startup_info_t const&, char*, int, int*)”,“symbolLocation”:968,“imageIndex”:1},{“imageOffset”:28156,“symbol”:“hostfxr_main_startupinfo”,“symbolLocation”:128,“imageIndex”:1},{“imageOffset”:7756,“symbol”:“exe_start(int, char const**)”,“symbolLocation”:1372,“imageIndex”:0},{“imageOffset”:8484,“symbol”:“main”,“symbolLocation”:184,“imageIndex”:0},{“imageOffset”:130560,“symbol”:“start”,“symbolLocation”:6992,“imageIndex”:13}]},{“id”:3592339,“frames”:[{“imageOffset”:3124,“symbol”:“mach_msg2_trap”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:79220,“symbol”:“mach_msg2_internal”,“symbolLocation”:76,“imageIndex”:9},{“imageOffset”:39360,“symbol”:“mach_msg_overwrite”,“symbolLocation”:480,“imageIndex”:9},{“imageOffset”:4032,“symbol”:“mach_msg”,“symbolLocation”:24,“imageIndex”:9},{“imageOffset”:3954424,“symbol”:“MachMessage::Receive(unsigned int)”,“symbolLocation”:80,“imageIndex”:3},{“imageOffset”:3951256,“symbol”:“SEHExceptionThread(void*)”,“symbolLocation”:156,“imageIndex”:3},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:10},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:10}],“threadState”:{“x”:[{“value”:268451845},{“value”:17179869190},{“value”:2147488018},{“value”:29699698865923},{“value”:10329396346880},{“value”:29699698851840},{“value”:5356},{“value”:0},{“value”:0},{“value”:17179869184},{“value”:5356},{“value”:0},{“value”:2405},{“value”:0},{“value”:6915},{“value”:0},{“value”:18446744073709551569},{“value”:8429744408},{“value”:0},{“value”:0},{“value”:5356},{“value”:29699698851840},{“value”:10329396346880},{“value”:29699698865923},{“value”:17179869190},{“value”:6160809024},{“value”:2147488018},{“value”:18446744073709550527},{“value”:6}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6592152948},“cpsr”:{“value”:4096},“fp”:{“value”:6160806208},“sp”:{“value”:6160806128},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592076852},“far”:{“value”:0}}},{“id”:3592340,“name”:“.NET SynchManager”,“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:4294967295},{“value”:257},{“value”:256},{“value”:1103806595328},{“value”:0},{“value”:0},{“value”:4313458232},{“value”:2},{“value”:0},{“value”:2},{“value”:256},{“value”:1},{“value”:256},{“value”:0},{“value”:417},{“value”:256},{“value”:0},{“value”:4313457728},{“value”:4313456320},{“value”:1000},{“value”:4294967295},{“value”:250},{“value”:1},{“value”:0},{“value”:0},{“value”:0},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:4394752460},“cpsr”:{“value”:1610616832},“fp”:{“value”:6162444176},“sp”:{“value”:6162444112},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592132624},“far”:{“value”:0}},“frames”:[{“imageOffset”:58896,“symbol”:“__poll_nocancel”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:3905996,“symbol”:“CorUnix::CPalSynchronizationManager::WorkerThread(void*)”,“symbolLocation”:248,“imageIndex”:3},{“imageOffset”:3941924,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:352,“imageIndex”:3},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:10},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:10}]},{“id”:3592341,“name”:“.NET EventPipe”,“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:4294967295},{“value”:3},{“value”:0},{“value”:6164065616},{“value”:125},{“value”:101},{“value”:4313425948},{“value”:4313467752},{“value”:1},{“value”:2},{“value”:9},{“value”:1},{“value”:16},{“value”:1188951201493985412},{“value”:417},{“value”:4738},{“value”:0},{“value”:4313425936},{“value”:1},{“value”:4391104364,“symbolLocation”:0,“symbol”:“server_warning_callback(char const*, unsigned int)”},{“value”:4313467712},{“value”:4294967295},{“value”:4395102058},{“value”:500},{“value”:1},{“value”:4294967295},{“value”:6164065744}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:4391535500},“cpsr”:{“value”:1610616832},“fp”:{“value”:6164065648},“sp”:{“value”:6164065568},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592132624},“far”:{“value”:0}},“frames”:[{“imageOffset”:58896,“symbol”:“__poll_nocancel”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:689036,“symbol”:“ds_ipc_poll(_DiagnosticsIpcPollHandle*, unsigned long, unsigned int, void ()(char const, unsigned int))”,“symbolLocation”:180,“imageIndex”:3},{“imageOffset”:176512,“symbol”:“ds_ipc_stream_factory_get_next_available_stream(void ()(char const, unsigned int))”,“symbolLocation”:796,“imageIndex”:3},{“imageOffset”:194356,“symbol”:“server_thread(void*)”,“symbolLocation”:364,“imageIndex”:3},{“imageOffset”:3941924,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:352,“imageIndex”:3},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:10},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:10}]},{“id”:3592342,“name”:“.NET DebugPipe”,“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:0},{“value”:4313500704},{“value”:4313500688},{“value”:14},{“value”:0},{“value”:117},{“value”:1},{“value”:4313498580},{“value”:1},{“value”:3},{“value”:3},{“value”:5314},{“value”:166},{“value”:4238353408},{“value”:398},{“value”:8429752768},{“value”:0},{“value”:0},{“value”:4313498044},{“value”:0},{“value”:0},{“value”:4020},{“value”:4313498016},{“value”:6165687680},{“value”:6591803851,“symbolLocation”:0,“symbol”:“std::nothrow”},{“value”:3},{“value”:19}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6592162868},“cpsr”:{“value”:1610616832},“fp”:{“value”:6165687504},“sp”:{“value”:6165687456},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592080200},“far”:{“value”:0}},“frames”:[{“imageOffset”:6472,“symbol”:“__open_nocancel”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:89140,“symbol”:“open$NOCANCEL”,“symbolLocation”:64,“imageIndex”:9},{“imageOffset”:687452,“symbol”:“TwoWayPipe::WaitForConnection()”,“symbolLocation”:40,“imageIndex”:3},{“imageOffset”:667996,“symbol”:“DbgTransportSession::TransportWorker()”,“symbolLocation”:200,“imageIndex”:3},{“imageOffset”:663776,“symbol”:“DbgTransportSession::TransportWorkerStatic(void*)”,“symbolLocation”:40,“imageIndex”:3},{“imageOffset”:3941924,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:352,“imageIndex”:3},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:10},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:10}]},{“id”:3592343,“name”:“.NET Debugger”,“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:160},{“value”:0},{“value”:0},{“value”:1},{“value”:0},{“value”:0},{“value”:2},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:305},{“value”:8429744192},{“value”:0},{“value”:4313501160},{“value”:4313501224},{“value”:1},{“value”:0},{“value”:0},{“value”:0},{“value”:1},{“value”:256},{“value”:1},{“value”:3}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6592356692},“cpsr”:{“value”:2684358656},“fp”:{“value”:6167309376},“sp”:{“value”:6167309232},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592091404},“far”:{“value”:0}},“frames”:[{“imageOffset”:17676,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:29012,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1024,“imageIndex”:10},{“imageOffset”:3899972,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:116,“imageIndex”:3},{“imageOffset”:3899376,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:300,“imageIndex”:3},{“imageOffset”:3912724,“symbol”:“CorUnix::InternalWaitForMultipleObjectsEx(CorUnix::CPalThread*, unsigned int, void* const*, int, unsigned int, int, int)”,“symbolLocation”:1292,“imageIndex”:3},{“imageOffset”:657692,“symbol”:“DebuggerRCThread::MainLoop()”,“symbolLocation”:220,“imageIndex”:3},{“imageOffset”:657368,“symbol”:“DebuggerRCThread::ThreadProc()”,“symbolLocation”:260,“imageIndex”:3},{“imageOffset”:656776,“symbol”:“DebuggerRCThread::ThreadProcStatic(void*)”,“symbolLocation”:56,“imageIndex”:3},{“imageOffset”:3941924,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:352,“imageIndex”:3},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:10},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:10}]},{“id”:3592344,“frames”:[{“imageOffset”:17676,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:29012,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1024,“imageIndex”:10},{“imageOffset”:3900196,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:340,“imageIndex”:3},{“imageOffset”:3899376,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:300,“imageIndex”:3},{“imageOffset”:3912724,“symbol”:“CorUnix::InternalWaitForMultipleObjectsEx(CorUnix::CPalThread*, unsigned int, void* const*, int, unsigned int, int, int)”,“symbolLocation”:1292,“imageIndex”:3},{“imageOffset”:3913476,“symbol”:“WaitForSingleObjectEx”,“symbolLocation”:80,“imageIndex”:3},{“imageOffset”:2886228,“symbol”:“CLREventBase::WaitEx(unsigned int, WaitMode, PendingSync*)”,“symbolLocation”:188,“imageIndex”:3},{“imageOffset”:2417508,“symbol”:“FinalizerThread::WaitForFinalizerEvent(CLREvent*)”,“symbolLocation”:48,“imageIndex”:3},{“imageOffset”:2417908,“symbol”:“FinalizerThread::FinalizerThreadWorker(void*)”,“symbolLocation”:144,“imageIndex”:3},{“imageOffset”:2017504,“symbol”:“ManagedThreadBase::KickOff(void ()(void), void*)”,“symbolLocation”:236,“imageIndex”:3},{“imageOffset”:2419004,“symbol”:“FinalizerThread::FinalizerThreadStart(void*)”,“symbolLocation”:92,“imageIndex”:3},{“imageOffset”:3941924,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:352,“imageIndex”:3},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:10},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:10}],“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:256},{“value”:0},{“value”:0},{“value”:160},{“value”:1},{“value”:999999000},{“value”:257},{“value”:0},{“value”:0},{“value”:2},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:305},{“value”:8429744192},{“value”:0},{“value”:51930907096},{“value”:51930907160},{“value”:1},{“value”:999999000},{“value”:1},{“value”:256},{“value”:257},{“value”:512},{“value”:1},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6592356692},“cpsr”:{“value”:2684358656},“fp”:{“value”:6168930384},“sp”:{“value”:6168930240},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592091404},“far”:{“value”:0}}},{“id”:3592346,“frames”:[{“imageOffset”:17676,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:29012,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1024,“imageIndex”:10},{“imageOffset”:3900196,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:340,“imageIndex”:3},{“imageOffset”:3899376,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:300,“imageIndex”:3},{“imageOffset”:3914936,“symbol”:“SleepEx”,“symbolLocation”:160,“imageIndex”:3},{“imageOffset”:2031372,“symbol”:“TieredCompilationManager::BackgroundWorkerStart()”,“symbolLocation”:176,“imageIndex”:3},{“imageOffset”:2031076,“symbol”:“TieredCompilationManager::BackgroundWorkerBootstrapper1(void*)”,“symbolLocation”:96,“imageIndex”:3},{“imageOffset”:2017504,“symbol”:“ManagedThreadBase::KickOff(void ()(void), void*)”,“symbolLocation”:236,“imageIndex”:3},{“imageOffset”:2030860,“symbol”:“TieredCompilationManager::BackgroundWorkerBootstrapper0(void*)”,“symbolLocation”:40,“imageIndex”:3},{“imageOffset”:3941924,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:352,“imageIndex”:3},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:10},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:10}],“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:1536},{“value”:0},{“value”:0},{“value”:160},{“value”:0},{“value”:99999000},{“value”:1793},{“value”:0},{“value”:0},{“value”:2},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:305},{“value”:8429744192},{“value”:0},{“value”:51930911704},{“value”:51930911768},{“value”:1},{“value”:99999000},{“value”:0},{“value”:1536},{“value”:1793},{“value”:2048},{“value”:4395507712,“symbolLocation”:168,“symbol”:“g_gc_dac_vars”},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6592356692},“cpsr”:{“value”:2684358656},“fp”:{“value”:6170553536},“sp”:{“value”:6170553392},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592091404},“far”:{“value”:0}}},{“id”:3592347,“frames”:,“threadState”:{“x”:[{“value”:6171127808},{“value”:8963},{“value”:6170591232},{“value”:0},{“value”:409604},{“value”:18446744073709551615},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:0},“cpsr”:{“value”:4096},“fp”:{“value”:0},“sp”:{“value”:6171127808},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592334856},“far”:{“value”:0}}},{“id”:3592348,“frames”:,“threadState”:{“x”:[{“value”:6171701248},{“value”:11011},{“value”:6171164672},{“value”:0},{“value”:409604},{“value”:18446744073709551615},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:0},“cpsr”:{“value”:4096},“fp”:{“value”:0},“sp”:{“value”:6171701248},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592334856},“far”:{“value”:0}}},{“id”:3592351,“name”:“.NET SigHandler”,“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:1},{“value”:37},{“value”:39200},{“value”:16},{“value”:0},{“value”:0},{“value”:0},{“value”:275054592},{“value”:214},{“value”:1},{“value”:4465704464},{“value”:0},{“value”:0},{“value”:0},{“value”:396},{“value”:51913916928},{“value”:0},{“value”:80},{“value”:4465701032},{“value”:0},{“value”:1},{“value”:270008320},{“value”:4308140032},{“value”:4308140032},{“value”:4308140032},{“value”:0},{“value”:4308140032}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:4308105064},“cpsr”:{“value”:2684358656},“fp”:{“value”:6172274624},“sp”:{“value”:6172274528},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592085164},“far”:{“value”:0}},“frames”:[{“imageOffset”:11436,“symbol”:“__read_nocancel”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:46952,“symbol”:“SignalHandlerLoop”,“symbolLocation”:112,“imageIndex”:4},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:10},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:10}]},{“id”:3592354,“name”:“.NET Sockets”,“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:0},{“value”:51932889088},{“value”:1024},{“value”:0},{“value”:0},{“value”:0},{“value”:1024},{“value”:8406475808,“symbolLocation”:0,“symbol”:“errno”},{“value”:4308165020},{“value”:6588948067},{“value”:4308092352,“symbolLocation”:0,“symbol”:“SystemNative_WaitForSocketEvents”},{“value”:2},{“value”:4308165052},{“value”:6},{“value”:363},{“value”:8403588072,“symbolLocation”:4776,“symbol”:“lsl::sPoolBytes”},{“value”:0},{“value”:6173895768},{“value”:51932889088},{“value”:6173896264},{“value”:93},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:4308092432},“cpsr”:{“value”:536875008},“fp”:{“value”:6173895504},“sp”:{“value”:6173895472},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592102340},“far”:{“value”:0}},“frames”:[{“imageOffset”:28612,“symbol”:“kevent”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:34320,“symbol”:“SystemNative_WaitForSocketEvents”,“symbolLocation”:80,“imageIndex”:4},{“imageOffset”:4468758128,“imageIndex”:12},{“imageOffset”:4468976080,“imageIndex”:12},{“imageOffset”:4436763252,“imageIndex”:12},{“imageOffset”:3682336,“symbol”:“CallDescrWorkerInternal”,“symbolLocation”:132,“imageIndex”:3},{“imageOffset”:2208144,“symbol”:“DispatchCallSimple(unsigned long*, unsigned int, unsigned long, unsigned int)”,“symbolLocation”:276,“imageIndex”:3},{“imageOffset”:2287728,“symbol”:“KickOffThread_Worker(void*)”,“symbolLocation”:144,“imageIndex”:3},{“imageOffset”:2017504,“symbol”:“ManagedThreadBase::KickOff(void ()(void), void*)”,“symbolLocation”:236,“imageIndex”:3},{“imageOffset”:2280620,“symbol”:“KickOffThread(void*)”,“symbolLocation”:212,“imageIndex”:3},{“imageOffset”:3941924,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:352,“imageIndex”:3},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:10},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:10}]},{“id”:3592363,“name”:“.NET Timer”,“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:160},{“value”:240},{“value”:0},{“value”:1},{“value”:0},{“value”:0},{“value”:2},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:305},{“value”:8429744192},{“value”:0},{“value”:51934309336},{“value”:51934309400},{“value”:1},{“value”:0},{“value”:240},{“value”:0},{“value”:1},{“value”:256},{“value”:1},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6592356692},“cpsr”:{“value”:2684358656},“fp”:{“value”:6177138400},“sp”:{“value”:6177138256},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6592091404},“far”:{“value”:0}},“frames”:[{“imageOffset”:17676,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:9},{“imageOffset”:29012,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1024,“imageIndex”:10},{“imageOffset”:3900196,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:340,“imageIndex”:3},{“imageOffset”:3899376,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:300,“imageIndex”:3},{“imageOffset”:3912724,“symbol”:“CorUnix::InternalWaitForMultipleObjectsEx(CorUnix::CPalThread*, unsigned int, void* const*, int, unsigned int, int, int)”,“symbolLocation”:1292,“imageIndex”:3},{“imageOffset”:2004912,“symbol”:“Thread::DoAppropriateWaitWorker(int, void**, int, unsigned int, WaitMode, void*)”,“symbolLocation”:700,“imageIndex”:3},{“imageOffset”:1986952,“symbol”:“Thread::DoAppropriateWait(int, void**, int, unsigned int, WaitMode, PendingSync*)”,“symbolLocation”:136,“imageIndex”:3},{“imageOffset”:2308124,“symbol”:“WaitHandle_WaitOneCore”,“symbolLocation”:108,“imageIndex”:3},{“imageOffset”:4436781044,“imageIndex”:12},{“imageOffset”:4436909168,“imageIndex”:12},{“imageOffset”:4436763268,“imageIndex”:12},{“imageOffset”:3682336,“symbol”:“CallDescrWorkerInternal”,“symbolLocation”:132,“imageIndex”:3},{“imageOffset”:2208144,“symbol”:“DispatchCallSimple(unsigned long*, unsigned int, unsigned long, unsigned int)”,“symbolLocation”:276,“imageIndex”:3},{“imageOffset”:2287728,“symbol”:“KickOffThread_Worker(void*)”,“symbolLocation”:144,“imageIndex”:3},{“imageOffset”:2017504,“symbol”:“ManagedThreadBase::KickOff(void ()(void), void*)”,“symbolLocation”:236,“imageIndex”:3},{“imageOffset”:2280620,“symbol”:“KickOffThread(void*)”,“symbolLocation”:212,“imageIndex”:3},{“imageOffset”:3941924,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:352,“imageIndex”:3},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:10},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:10}]}],
“usedImages” : [
“source” : “P”,
“arch” : “arm64”,
“base” : 4306616320,
“CFBundleShortVersionString” : “2.3.0.4_stable_2026-07-09”,
“CFBundleIdentifier” : “com.duplicati.app”,
“size” : 65536,
“uuid” : “7f6ded36-a870-3892-a44f-844208e78bb9”,
“path” : “/Applications/Duplicati.app/Contents/MacOS/duplicati”,
“name” : “duplicati”,
“CFBundleVersion” : “2.3.0.4_stable_2026-07-09”
“source” : “P”,
“arch” : “arm64”,
“base” : 4307238912,
“size” : 262144,
“uuid” : “e7871808-49fb-3f9f-9922-e0548bcd31a3”,
“path” : “/Applications/Duplicati.app/Contents/MacOS/libhostfxr.dylib”,
“name” : “libhostfxr.dylib”
“source” : “P”,
“arch” : “arm64”,
“base” : 4307648512,
“size” : 245760,
“uuid” : “fe6b8a42-fb22-3c56-8db4-17e396ee6386”,
“path” : “/Applications/Duplicati.app/Contents/MacOS/libhostpolicy.dylib”,
“name” : “libhostpolicy.dylib”
“source” : “P”,
“arch” : “arm64”,
“base” : 4390846464,
“size” : 4505600,
“uuid” : “f17f4ec9-b2e5-39d9-bd70-fdaa8cf2dff1”,
“path” : “/Applications/Duplicati.app/Contents/MacOS/libcoreclr.dylib”,
“name” : “libcoreclr.dylib”
“source” : “P”,
“arch” : “arm64”,
“base” : 4308058112,
“size” : 65536,
“uuid” : “fef6b6c6-4f56-3d2e-bf6a-e80d626bc3f7”,
“path” : “/Applications/Duplicati.app/Contents/MacOS/libSystem.Native.dylib”,
“name” : “libSystem.Native.dylib”
“source” : “P”,
“arch” : “arm64”,
“base” : 4421517312,
“size” : 2424832,
“uuid” : “5181947f-e0a5-37ef-ab0c-83e9657579c7”,
“path” : “/Applications/Duplicati.app/Contents/MacOS/libclrjit.dylib”,
“name” : “libclrjit.dylib”
“source” : “P”,
“arch” : “arm64”,
“base” : 5129732096,
“size” : 65536,
“uuid” : “b200095c-9162-3622-95f8-d2fb2d54b3f6”,
“path” : “/Applications/Duplicati.app/Contents/MacOS/libSystem.Security.Cryptography.Native.Apple.dylib”,
“name” : “libSystem.Security.Cryptography.Native.Apple.dylib”
“source” : “P”,
“arch” : “arm64”,
“base” : 5130305536,
“size” : 65536,
“uuid” : “2f6ba079-e5e1-38bd-bee5-c9fd3f141468”,
“path” : “/Applications/Duplicati.app/Contents/MacOS/libMono.Unix.dylib”,
“name” : “libMono.Unix.dylib”
“source” : “P”,
“arch” : “arm64”,
“base” : 5137498112,
“size” : 1376256,
“uuid” : “e444369d-c2da-342b-9327-939113fbf418”,
“path” : “/Applications/Duplicati.app/Contents/MacOS/libe_sqlite3.dylib”,
“name” : “libe_sqlite3.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6592073728,
“size” : 250544,
“uuid” : “fca53b98-3d6a-38b2-a0ec-df0f7e05f171”,
“path” : “/usr/lib/system/libsystem_kernel.dylib”,
“name” : “libsystem_kernel.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6592327680,
“size” : 52028,
“uuid” : “4f33683c-18c8-39a1-800b-2e3bd43bcc13”,
“path” : “/usr/lib/system/libsystem_pthread.dylib”,
“name” : “libsystem_pthread.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6590840832,
“size” : 527776,
“uuid” : “694b7881-1bf3-3d0f-8f19-b50ae4e8ef8a”,
“path” : “/usr/lib/system/libsystem_c.dylib”,
“name” : “libsystem_c.dylib”
“size” : 0,
“source” : “A”,
“base” : 0,
“uuid” : “00000000-0000-0000-0000-000000000000”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6588301312,
“size” : 680472,
“uuid” : “f924bdd3-4365-3466-9580-8b1b3fa8f857”,
“path” : “/usr/lib/dyld”,
“name” : “dyld”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6591369216,
“size” : 592616,
“uuid” : “5013c0f8-84a9-3b56-9feb-c353816a750f”,
“path” : “/usr/lib/libc++.1.dylib”,
“name” : “libc++.1.dylib”
“sharedCache” : {
“base” : 6587170816,
“size” : 5990973440,
“uuid” : “157e6d2e-2e5c-39b1-8f2a-8866ee228bed”
“vmSummary” : “ReadOnly portion of Libraries: Total=873.3M resident=0K(0%) swapped_out_or_unallocated=873.3M(100%)\nWritable regions: Total=184.0M written=514K(0%) resident=514K(0%) swapped_out=0K(0%) unallocated=183.5M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nActivity Tracing 256K 1 \nKernel Alloc Once 32K 1 \nMALLOC 52.8M 18 \nMALLOC guard page 3632K 4 \nMemory Tag 22 64.0M 1 \nSTACK GUARD 56.2M 13 \nStack 22.4M 13 \nVM_ALLOCATE 1.1G 323 \nVM_ALLOCATE (reserved) 320K 2 reserved VM address space (unallocated)\n__AUTH 1328K 150 \n__AUTH_CONST 17.7M 343 \n__CTF 824 1 \n__DATA 4679K 309 \n__DATA_CONST 16.7M 350 \n__DATA_DIRTY 1338K 287 \n__FONT_DATA 2352 1 \n__LINKEDIT 575.5M 10 \n__OBJC_RO 79.1M 1 \n__OBJC_RW 2598K 1 \n__TEXT 297.7M 360 \n__TPRO_CONST 128K 2 \nmapped file 85.8M 184 \npage table in kernel 514K 1 \nshared memory 80K 4 \n=========== ======= ======= \nTOTAL 2.4G 2380 \nTOTAL, minus reserved VM space 2.4G 2380 \n”,
“legacyInfo” : {
“threadTriggered” : {
“queue” : “com.apple.main-thread”
“logWritingSignature” : “5a3d0ab46c58c2d0eb750321d66a366550b1b126”,
“bug_type” : “309”,
“roots_installed” : 0,
“trmStatus” : 1,
“trialInfo” : {
“rollouts” : [
“rolloutId” : “642da32dea3b2418c750f848”,
“factorPackIds” : [
“66d8b2f77cd4b62688efd2cf”
“deploymentId” : 240000011
“rolloutId” : “67648e5334a82511f4acf879”,
“factorPackIds” : [
  "deploymentId" : 240000008
“experiments” : [
I’ve got the .ips file from the crash, but the forum isn’t in favour of me uploading it; will find a way to get it to you if it’s helpful.
