Hi, I hope you can help me… I had a automatic incremental duplicati backup (for my documents) on my PC set up, which was working fine.
Now I had to reset my PC and forgot the export the job for this backup.
Is it somehow possible to continue the “old” incremental backup without start starting complete new?
Do you remember or have stored things like the encryption passphrase and any access information the destination needs (e.g., if remote). Knowing what you backed up is less important because you can take first guess at Source, then go look to correct if needed.
If you can get the backup roughed in, then Database Repair should recreate a database.
