Connection to server was rejected due to invalid authentication
Hi guys, I have been running duplicati for a couple of years and really appreciate the software. I have an issue and would love some help…
I run duplicati on docker and manage my containers using Portainer.
I updated Duplicati using docker compose yesterday and noticed some warnings on my backups overnight.
I tried to log in via the web UI and got the error “Connection to server was rejected due to invalid authentication.” with the option to log in. I have never had a password for Duplicati as everything is local.
Any ideas?
LimitedErrors: []
Log data:
2024-12-11 01:02:16 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /source/home/peter/DockerVolumes/influxdb/data/influxd.bolt
System.IO.IOException: The process cannot access the file '/source/home/peter/DockerVolumes/influxdb/data/influxd.bolt' because it is being used by another process.
  at Microsoft.Win32.SafeHandles.SafeFileHandle.Init(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize, Int64& fileLength, UnixFileMode& filePermissions)
  at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize, UnixFileMode openPermissions, Int64& fileLength, UnixFileMode& filePermissions, Boolean failForSymlink, Boolean& wasSymlink, Func`4 createOpenException)
  at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize, Nullable`1 unixCreateMode)
  at Duplicati.Library.Snapshots.NoSnapshotLinux.OpenRead(String localPath)
  at Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.<>c__DisplayClass1_0.<<Run>b__0>d.MoveNext()
2024-12-11 01:02:28 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /source/home/peter/DockerVolumes/portainer/portainer.db
System.IO.IOException: The process cannot access the file '/source/home/peter/DockerVolumes/portainer/portainer.db' because it is being used by another process.
2024-12-11 01:02:28 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /source/home/peter/DockerVolumes/portainer/useractivity.db
System.IO.IOException: The process cannot access the file '/source/home/peter/DockerVolumes/portainer/useractivity.db' because it is being used by another process.
I have found the problem, I had to look in the logs and log in using the key provided by the logs. I guess I should read the release notes rather than just update to latest in Portainer!
That is a new requirement for Duplicati: mandatory API password.
With Docker, you can set the environment variable:
DUPLICATI__WEBSERVICE_PASSWORD=<your password>
This is caused by the update to .NET8 where Linux advisory file locking is now honored. The real fix is to use LVM and set up snapshots so you get a consistent view, but you can also choose to get a “write-consistent” view as Duplicati did in 2.0.8.1 and older.
To get a “write-consistent” view, you can set the option --ignore-advisory-locking=true (it can be set globally to work for all backups).
with Docker, you can also consider setting the environment variable:
DOTNET_SYSTEM_IO_DISABLEFILELOCKING=true
Which will ignore any advisory locks from within Duplicati.
I have created a documentation page that describes some common setups for Duplicati in Docker.
Thank you, much appreciated
Do you know how to set the environment variable if I run Duplicati in unRAID? I have the same problem as the original poster, and I would appreciate any help!
i think you can check the unRAID forum for a description:
Thank you so much - this worked. Much appreciated.
