Connection refused WIN 11 Firefox
Hello, after updating to version 2.4.1.0, Duplicati no longer starts, or rather, I get the message: “The target computer refused the connection.” The target is http://127.0.0.1:8200/index.html.
What can I do about this? Thx for help!
Rutmay
Hi @rutmay, welcome to the forum :waving_hand:
That means that whatever the target is, it is not responding.
Can you check if Duplicati is running? (taskmgr.exe for Windows or ps for Linux/macOS).
If Duplicati is not running, check for a file called crashlog.txt to see if it tells what the problem is.
If Duplicati is running, try opening it from the TrayIcon; it is most likely using a different port.
Thanks!
Duplicati isr running (Duplicati.GUI.TrayIcon), crashlog.txt I cant find, if I try to open from the TrayIcon, the Icon is grey with white cross, right click “reconnect”, than again I get the message: “The target computer refused the connection”
That’s strange; I’ve been using Duplicati for many years and have installed many updates without ever running into an issue. Could it have something to do with certificates? I did select that option (perhaps for the first time?), but the browser still shows “http” rather than “https.” Not that I’m certain if that’s related, though…
I suspect that selecting “Generate and use TLS (HTTPS) certificates” in the installer will cause Duplicati to require HTTPS when connecting to the web UI. If you manually change the URL to https:// it should connect, though your browser will probably throw up an untrusted certificate warning.
Reinstalling didn’t help, so I completely uninstalled and reinstalled without the Windows service – now it works!
Thanks for the help!
Rutmay
