What compression modules are supported? I put bz2, but it doesn’t seem to be working, which one has more data compression?
Try this:
In my very simple testing it seems a lot slower than the default method, but does save a little more space.
This option does not appear to me.
What version are you using? It’s in the Zip Compression section:
2.0.5.1_beta_2020-01-18
I have the Canary version and this option does not appear to choose another extension as you showed.
Sorry I missed your reply 6 days ago! I got my screen shot from 2.0.5.114 Canary. Weird that it doesn’t show for you.
Could you describe or screenshot what does appear? How far can you go?
Options → Advanced options?
Zip compression? Any others there? This group is about 3/4 down the page.
zip-compression-method? Is dropdown not expanding when you click on it?
I tried two non-default languages and also 2.0.5.111 on Linux. All look fine…
You’re looking in Default options in Settings. Try looking in a job’s Options → Advanced options.
where is this option? can you show me a picture?
Not in the “settings” tab?
Click screen 5 Options then look for Advanced options section:
Click Add advanced option dropdown, and scroll about 3/4 down:
Click zip-compression-method, then expand dropdown for choices:
Seemingly not, although I don’t know if there’s a reason for that. You could file an enhancement request.
