I’ve been having some problems with the duplicati Canary build 2.0.3.6 on an Ubuntu 16.04.3 LTS system and I want to go back to 2.0.3.3.
I have stopped the service:
systemctl stop dupliati
Then removed the package:
dpkg -r duplicati
I then install the “older” package:
dpkg -i duplicati_2.0.3.3-1_all.deb
All seems well, however when I log into the Web UI, and go to the About page, I see that I am still on version 2.0.3.6. This version was installed through an automatic update, and not using dpkg. How do I go about removing it so that I can be running only on 2.0.3.3?
Thanks @JonMikelV - yep @Wim_Jansen gave me the pointer I needed to resolve this issue.
I’m running Duplicati as a service. Sometimes if I have a desktop session open I run the tray icon, but I manually created a separate Xfce menu entry for this as I found that the default menu entry on Ubuntu 16.04 causes Duplicati to start running as a backup server, but under and unprivileged user. This would be fine under certain circumstances, but I want to back up /etc and other key system paths. All depends on your use case I guess.
