Trying to get some consistent results here and not having any luck.
Running this commandline:
“C:\Program Files\Duplicati 2\Duplicati.CommandLine.exe” test “webdavs://{nextcloud}/remote.php/dav/files/{username}/C.drive?auth-username={username}&auth-password={pw}” --dbpath=“c:##db\FDUBIZQIYI.sqlite” --encryption-module=aes --passphrase="{secret}" --disable-module=console-password-input
yields …some extra unknown files … please run repair.
I copy the commandline above and put in repair instead of test and this comes back:
Listing remote folder …
ErrorID: EmptyRemoteLocation
No filelists found on the remote destination
Color me confused. The ‘test’ command shows some missing files and the ‘repair’ command can’t even find the remote location.
Some other results that may or may not help in the diagnosis:
list-broken-files -->
ErrorID: CannotListOnDatabaseInRepair
Cannot continue because the database is marked as being under repair, but does not have broken files.
list -->
No time or version matched a fileset
I get the same results under 2.0.5.104 canary and the latest beta 2.0.5.1 so clearly it is something I am doing wrong or don’t understand. The gui tool lists the same results.
Also looking for a recommendation for a 3rd party DAV testing tool. The ones I’ve found on line is equivalent to killing a mosquito with a shotgun.
Although in my ‘test’ vs ‘repair’ commandline adventures, I’m not sure what a 3rd party tool would do for me, since one of the duplicati functions finds the files and the other one doesn’t.
