Commandline Command order
The Command select list on the Commandline window doesn’t seem to be alphabetical (at least in English).
Is there a particular reason for this or can we update the UI to sort them?
I did not think of sorting them, but it is easy to just add sorting before displaying:
Thanks for making it so easy! Pull Request made. :slight_smile:
Closing as Solved now that code has been merged into the master. Thanks! :slight_smile:
