I’m pretty sure I’m running the latest canary (2.0.4.18_canary_2019-05-12) after uninstalling, cleaning out program data, and reinstalling now. I’m not completely sure how anything to do with filters is logged in the profiling, but anything to do with listing and checking the files seems to express through rather nicely.
I’ve copied one of the issue queries here which may help:
SELECT COUNT(*) FROM (SELECT DISTINCT "Path" FROM ( SELECT "L"."Path", "L"."Lastmodified", "L"."Filelength", "L"."Filehash", "L"."Metahash", "L"."Metalength", "L"."BlocklistHash", "L"."FirstBlockHash", "L"."FirstBlockSize", "L"."FirstMetaBlockHash", "L"."FirstMetaBlockSize", "M"."Hash" AS "MetaBlocklistHash" FROM ( SELECT "J"."Path", "J"."Lastmodified", "J"."Filelength", "J"."Filehash", "J"."Metahash", "J"."Metalength", "K"."Hash" AS "BlocklistHash", "J"."FirstBlockHash", "J"."FirstBlockSize", "J"."FirstMetaBlockHash", "J"."FirstMetaBlockSize", "J"."MetablocksetID" FROM ( SELECT "A"."Path" AS "Path", "D"."Lastmodified" AS "Lastmodified", "B"."Length" AS "Filelength", "B"."FullHash" AS "Filehash", "E"."FullHash" AS "Metahash", "E"."Length" AS "Metalength", "A"."BlocksetID" AS "BlocksetID", "F"."Hash" AS "FirstBlockHash", "F"."Size" AS "FirstBlockSize", "H"."Hash" AS "FirstMetaBlockHash", "H"."Size" AS "FirstMetaBlockSize", "C"."BlocksetID" AS "MetablocksetID" FROM "File" A LEFT JOIN "Blockset" B ON "A"."BlocksetID" = "B"."ID" LEFT JOIN "Metadataset" C ON "A"."MetadataID" = "C"."ID" LEFT JOIN "FilesetEntry" D ON "A"."ID" = "D"."FileID" LEFT JOIN "Blockset" E ON "E"."ID" = "C"."BlocksetID" LEFT JOIN "BlocksetEntry" G ON "B"."ID" = "G"."BlocksetID" LEFT JOIN "Block" F ON "G"."BlockID" = "F"."ID" LEFT JOIN "BlocksetEntry" I ON "E"."ID" = "I"."BlocksetID" LEFT JOIN "Block" H ON "I"."BlockID" = "H"."ID" WHERE "A"."BlocksetId" >= 0 AND "D"."FilesetID" = 22 AND ("I"."Index" = 0 OR "I"."Index" IS NULL) AND ("G"."Index" = 0 OR "G"."Index" IS NULL) ) J LEFT OUTER JOIN "BlocklistHash" K ON "K"."BlocksetID" = "J"."BlocksetID" ORDER BY "J"."Path", "K"."Index" ) L LEFT OUTER JOIN "BlocklistHash" M ON "M"."BlocksetID" = "L"."MetablocksetID" ) UNION SELECT DISTINCT "Path" FROM ( SELECT "G"."BlocksetID", "G"."ID", "G"."Path", "G"."Length", "G"."FullHash", "G"."Lastmodified", "G"."FirstMetaBlockHash", "H"."Hash" AS "MetablocklistHash" FROM ( SELECT "B"."BlocksetID", "B"."ID", "B"."Path", "D"."Length", "D"."FullHash", "A"."Lastmodified", "F"."Hash" AS "FirstMetaBlockHash", "C"."BlocksetID" AS "MetaBlocksetID" FROM "FilesetEntry" A, "File" B, "Metadataset" C, "Blockset" D, "BlocksetEntry" E, "Block" F WHERE "A"."FileID" = "B"."ID" AND "B"."MetadataID" = "C"."ID" AND "C"."BlocksetID" = "D"."ID" AND "E"."BlocksetID" = "C"."BlocksetID" AND "E"."BlockID" = "F"."ID" AND "E"."Index" = 0 AND ("B"."BlocksetID" = -100 OR "B"."BlocksetID" = -200) AND "A"."FilesetID" = 22 ) G LEFT OUTER JOIN "BlocklistHash" H ON "H"."BlocksetID" = "G"."MetaBlocksetID" ORDER BY "G"."Path", "H"."Index" ))
It is possible the CMD is being limited in resources (memory) somehow?
I’ve tried the --use-block-cache=true switch as well which made no difference in either the GUI or CMD.
