CLI Error with command Compare if passphrase contains a quotation mark (")
I saw error that a parameter (with name contains the part of passphrase) doesn’t support.
You will probably have to escape it. Try putting a \ before the quote or put it twice. Just a guess…
I tried use twice quote as I saw in export as command line but unfortenutely I saw this error again.
BTW if command backup, I don’t see such error then use double quote.
