I am running duplicati on my qnap ts-431+ (arm cpu). I am uploading files to jottacloud.
I discovered that the cpu usage is very high so I changed the compression setting to 1 (low compression).
Now I am observing the followong behaviour:
The CPU usage rises for some minutes and no upload is happening. After that the upload rate rises and the cpu usage drops. This repeats on and on. I am wondering why duplicati isn’t using the time it needs for uploading to continue the compression. In this case I would not have this type of upload interruptions.
Ressource monitor on my qnap:
(upload parts are 250MB)
After compression finishes:
Average time for compressing 250MB ~10min
Average upload time: ~3min
edit:
sgen is causing most of the load. Is this expected behaviour?
Edit2:
It gets even worse. In one hour I am just able to upload 750MB. Backing up about 800gb will take its time…
Better multi threading is a big goal right now starting with v2.0.3.6 canary (which has some issues, so as with all Canary versions we can’t recommend using it on important data).
That being said, I don’t know how much multi threading will help on an ARM chip… And of course there are other resources to consider including memory and disk IO.
If you look on your temp folder while a backup is running do you see a lot of dup*.dindex* files with current timestamps? If so, then the upload step is likely your bottleneck. If not, then it could be any combination of:
disk reads (source data)
hashing (deduplication)
compression (though you’ve already lowered that)
encryption
disk writes (archives to be uploaded, memory thrashing)
You could try making sure your temp folder is on a different did than source files, or better yet is an SSD or ramdrive.
Could find 310 files of this type in the backup directory on jotta cloud
The HDD does not seem the bottleneck, the usage is low. CPU (94% usage of mono sgen in top) seems to be the main culprit.
The weird thing is that I also have a backup on an sftp storage with the same options. The only difference is that the encryption key is much longer for jotta (both aes256) does this makes a difference in encyrption speed?
edit: you meant the local temp folder right? I am looking for it
btw:
[/share/CE_CACHEDEV1_DATA/.qpkg/Duplicati/tmp] # du -hs .
52G .
is this size “normal”?
I am using Duplicati 2.0.3.6
I did some tests and the solution seems to be the compression settings. I had to choose 0
My suspicion is that in the new version there is someting wrong with these settings.
I had the same options on the same nas for another backup and did not had these problems.
I have no idea how to investigate this further at this point (if somebody gives me a hint I will try to verify my suspision).
Nevertheless, my ressources are not used efficently:
It looks like compression setting 1 is as hard as 9 and 0 disables it.
“Normal” is relative based on your settings. If you’re using defaults (such as “Upload volume size” (–dblock) of 50MB and --asynchronous-upload-limit=4 then you shouldn’t see more than maybe 500MB in use in the temp folder.
Are all 52G current files or do some of them look like orphans from previous runs?
Note that some issues have been identified in version 2.0.3.6, including performance related ones, so you might want to consider downgrading to 2.0.3.5 and see if that helps at all.
The files are looking like this:
File list
[/share/CE_CACHEDEV1_DATA/.qpkg/Duplicati/tmp] # ls -ltra
drwxrwx— 6 admin administ 4096 May 4 14:07 …/
-rw-rw-rw- 1 admin administ 4612726 May 17 16:13 dup-f6fd3afd-f238-4644-80b0-bdd5622e082e
-rw-rw-rw- 1 admin administ 6386056 May 17 16:14 dup-ba4d927c-51fa-4820-9122-bb0f235de0d8
-rw-rw-rw- 1 admin administ 4508 May 17 16:15 dup-e60bc4d8-52a1-4161-bf94-4e68952ae1ae
-rw-rw-rw- 1 admin administ 338 May 17 19:08 dup-b6f21554-5550-4c36-bb26-2b6505338f7b
-rw-rw-rw- 1 admin administ 42502544 May 17 22:06 dup-1b48add9-197d-484d-8f9c-18c020782078
-rw-rw-rw- 1 admin administ 6389866 May 17 22:07 dup-5e8a50b3-b2ca-4694-bae1-9a8831a8d4a1
-rw-rw-rw- 1 admin administ 35056 May 17 22:15 dup-0f53426c-6ad4-4d31-8d3c-63a43f1431c1
-rw-rw-rw- 1 admin administ 338 May 18 01:07 dup-e27a1f06-15fc-4a25-bdca-5f21e7e6e1c4
-rw-rw-rw- 1 admin administ 337 May 18 04:08 dup-626a5449-4736-4d5d-b091-0f22f55d860a
-rw-rw-rw- 1 admin administ 338 May 18 07:07 dup-367c341c-f8c4-4636-ba44-bff22961f81d
-rw-rw-rw- 1 admin administ 338 May 18 10:09 dup-ccb910b8-f201-422d-b7da-a4dab502462e
-rw-rw-rw- 1 admin administ 338 May 18 13:09 dup-44be5d07-f09f-4954-9e27-20aa326c04ed
-rw-rw-rw- 1 admin administ 844142 May 18 16:06 dup-78367731-9a28-42cd-9864-8d8a8df1f165
-rw-rw-rw- 1 admin administ 6391202 May 18 16:06 dup-8dacc737-6bce-4183-979c-65636413ef1d
-rw-rw-rw- 1 admin administ 2628 May 18 16:07 dup-af359359-0127-48e6-bc4a-6c92b1d345ac
-rw-rw-rw- 1 admin administ 5563839 May 18 19:06 dup-04042e5b-10b9-4861-9e38-7a3ad49cc982
-rw-rw-rw- 1 admin administ 6392406 May 18 19:07 dup-a0ffb61b-5f0b-4bbb-bd8e-b2285f56cab0
-rw-rw-rw- 1 admin administ 6877 May 18 19:08 dup-1c05e6af-ac2d-45bd-aaa1-914f940fda13
-rw-rw-rw- 1 admin administ 4039294 May 18 22:06 dup-212ecc0d-e8f4-4b4a-9ce6-efc0746264da
-rw-rw-rw- 1 admin administ 6395461 May 18 22:06 dup-f371a8dd-b4f6-4a26-9223-2bc9786caf30
-rw-rw-rw- 1 admin administ 7234 May 18 22:08 dup-5663c282-cdd6-43ab-b44e-83434851aa03
-rw-rw-rw- 1 admin administ 338 May 19 01:09 dup-af3669e3-e80a-4374-8473-bf5dcdcd25dd
-rw-rw-rw- 1 admin administ 337 May 19 04:08 dup-50f8d26c-3793-4b9c-a836-a9b3f39f04f3
-rw-rw-rw- 1 admin administ 338 May 19 07:07 dup-016e0a66-f9fc-47e2-ae28-a891eac76ac6
-rw-rw-rw- 1 admin administ 338 May 19 10:09 dup-19312e16-53fb-4a7b-940a-75766f25b104
-rw-rw-rw- 1 admin administ 338 May 19 13:07 dup-57b5fa48-76f9-4c5a-ad1d-0c9b3392750f
-rw-rw-rw- 1 admin administ 52421908 May 19 14:44 dup-7123dc2c-4811-4269-9d10-67af4b0226ff
-rw-rw-rw- 1 admin administ 52365630 May 19 14:44 dup-29a0dbec-83f1-40df-866c-8d2c625499d6
-rw-rw-rw- 1 admin administ 52400727 May 19 14:44 dup-4baf4e2d-6221-4240-abc2-dc78875a0199
-rw-rw-rw- 1 admin administ 52428135 May 19 14:44 dup-d585236e-394b-49fd-9391-13eec2a98cf6
-rw-rw-rw- 1 admin administ 48177 May 19 14:45 dup-99169300-9d21-44c0-80a9-9183cb39bd12
-rw-rw-rw- 1 admin administ 37620 May 19 14:46 dup-bfffd6ba-3dd8-4ce1-a465-85bd64d4d5df
-rw-rw-rw- 1 admin administ 51620 May 19 14:47 dup-a10ca18a-e65c-4e37-948d-3014dd5eb142
-rw-rw-rw- 1 admin administ 35341 May 19 14:47 dup-539b8bb9-de57-4db0-ae8b-d0365d802419
-rw-rw-rw- 1 admin administ 52355394 May 19 14:48 dup-3cd9daf9-fe70-4332-a378-76b8e0dca4ea
-rw-rw-rw- 1 admin administ 52396641 May 19 14:48 dup-2b7d5773-d5e9-47ba-9ccf-45e4108969d8
-rw-rw-rw- 1 admin administ 48227 May 19 14:49 dup-d65e2325-69af-4f64-9b64-80f6bd66aaec
-rw-rw-rw- 1 admin administ 41643 May 19 14:49 dup-3fb95f29-3ce2-4dbc-bcf9-2af4ff799821
-rw-rw-rw- 1 admin administ 52341176 May 19 14:50 dup-f68d6d46-c6dc-4b80-a177-59eceb74b385
-rw-rw-rw- 1 admin administ 52403627 May 19 14:50 dup-56b294ce-8698-4206-8b10-939ad8ac1c66
-rw-rw-rw- 1 admin administ 52389931 May 19 14:50 dup-2e6c5fdb-3c41-4c7b-997c-03d5d26a57d5
-rw-rw-rw- 1 admin administ 52358765 May 19 14:50 dup-9634ede9-1b01-4e7d-a92b-8dc540f625f6
-rw-rw-rw- 1 admin administ 42947 May 19 14:51 dup-50d951e7-e94c-436b-97cc-522c62623008
-rw-rw-rw- 1 admin administ 48274 May 19 14:52 dup-7e2a0030-a512-4dd1-88bd-8df1ce374818
-rw-rw-rw- 1 admin administ 41243 May 19 14:52 dup-7b481bca-b5d2-41d4-9d3a-47d35e801a2f
-rw-rw-rw- 1 admin administ 38877 May 19 14:53 dup-2a859db8-a6d6-4c29-8716-09719ec35e68
-rw-rw-rw- 1 admin administ 52411868 May 19 14:53 dup-024583a4-d2da-48c6-bf08-ec95dc29dbb7
-rw-rw-rw- 1 admin administ 52424334 May 19 14:53 dup-351f969f-4d4b-476f-a37d-fa7675e9d15c
-rw-rw-rw- 1 admin administ 52386549 May 19 14:54 dup-05798766-32a8-4305-9ec8-9bf71b5c4749
-rw-rw-rw- 1 admin administ 52385479 May 19 14:54 dup-b7665dbe-75fc-4d46-bbfe-e8685947372c
-rw-rw-rw- 1 admin administ 38601 May 19 14:54 dup-e0f5cfcb-d740-4ed6-ab91-6e7db14ba0e9
-rw-rw-rw- 1 admin administ 38296 May 19 14:55 dup-3113bbc0-25da-4881-9a05-b1af0bfdeb09
-rw-rw-rw- 1 admin administ 40005 May 19 14:56 dup-8bd0c11d-e62d-4006-b4fd-7ea023cb7e79
-rw-rw-rw- 1 admin administ 34208 May 19 14:57 dup-efb88162-dff3-4879-8c1c-a100c422bb4e
-rw-rw-rw- 1 admin administ 52357107 May 19 14:57 dup-94543dd7-52eb-4c61-9c03-d9937ed1312b
-rw-rw-rw- 1 admin administ 52379221 May 19 14:57 dup-9269d8f6-defb-4d54-8b24-8865f9b2bae4
-rw-rw-rw- 1 admin administ 33208 May 19 14:58 dup-54f854d1-38e8-4725-9687-0385e1d0c4f7
-rw-rw-rw- 1 admin administ 40850 May 19 14:59 dup-ae596b26-56b4-4e47-8b41-3f612efb8fde
-rw-rw-rw- 1 admin administ 52330552 May 19 15:00 dup-d9aa1478-d33b-4a21-aca2-87966a8ed303
-rw-rw-rw- 1 admin administ 52377856 May 19 15:00 dup-bf541020-bd84-4d46-858e-9db5f42f4d9d
-rw-rw-rw- 1 admin administ 46251 May 19 15:01 dup-0b43a3cd-f0bc-4c0a-b0b6-91525318f40c
-rw-rw-rw- 1 admin administ 50873 May 19 15:02 dup-ee0d26c0-79b8-4fac-b4f6-52f95026707b
-rw-rw-rw- 1 admin administ 52337145 May 19 15:04 dup-a2de7f3c-a9e5-4485-b5dc-b6a20556ef2a
-rw-rw-rw- 1 admin administ 52407061 May 19 15:04 dup-a776aec1-2d4d-4872-b1eb-7c096ab62370
-rw-rw-rw- 1 admin administ 71025 May 19 15:06 dup-f5dc8344-0b8a-439e-bfad-3716304a4058
-rw-rw-rw- 1 admin administ 42771 May 19 15:07 dup-f4c3d825-ff5b-437e-bfdb-985457652908
-rw-rw-rw- 1 admin administ 52329788 May 19 15:07 dup-df14e0e2-6dc9-4edf-918f-ca7dd024d440
-rw-rw-rw- 1 admin administ 52410504 May 19 15:07 dup-41d9bba2-6a7c-4414-b08d-3253d0578ab2
-rw-rw-rw- 1 admin administ 29661 May 19 15:08 dup-b4e0867d-d788-4f14-bf4b-55dafd80439e
-rw-rw-rw- 1 admin administ 51858 May 19 15:09 dup-79d26aad-524a-4a50-a549-a5882a42052d
-rw-rw-rw- 1 admin administ 52360605 May 19 15:10 dup-748cdc0e-768e-47ee-9d69-dde6051261f0
-rw-rw-rw- 1 admin administ 52348599 May 19 15:10 dup-72e4c5bf-22db-4411-b87d-24a800b516a5
-rw-rw-rw- 1 admin administ 51430 May 19 15:11 dup-0b330b4e-1825-4aa3-981d-6eb6ccd3cef8
-rw-rw-rw- 1 admin administ 55946 May 19 15:12 dup-5c5d3bbb-4c46-4853-9425-3fc9f0b0a7ad
-rw-rw-rw- 1 admin administ 52419160 May 19 15:12 dup-9b649878-dcfa-4c75-860c-253bef0254d6
-rw-rw-rw- 1 admin administ 52361135 May 19 15:12 dup-480ae153-88ab-4797-b714-fe7094be685b
-rw-rw-rw- 1 admin administ 36547 May 19 15:14 dup-4b21581f-3d1d-4a5b-b8ed-e9ff23841c83
-rw-rw-rw- 1 admin administ 50087 May 19 15:14 dup-ce0edcb7-cf33-4978-b7d5-a539a2cfef49
-rw-rw-rw- 1 admin administ 52425088 May 19 15:20 dup-c0d33899-1040-46c2-b989-bc4c81e73a6f
-rw-rw-rw- 1 admin administ 52338079 May 19 15:20 dup-8049d510-1068-40ff-988a-b09b61237ae9
-rw-rw-rw- 1 admin administ 68241 May 19 15:21 dup-ae4dfe8f-7244-481d-a29d-098cd6e871a3
-rw-rw-rw- 1 admin administ 78341 May 19 15:22 dup-4c8f8500-03bc-41ae-af44-55ecb8a4a845
-rw-rw-rw- 1 admin administ 52360531 May 19 15:25 dup-62ea0851-10fd-4a8c-ae78-7088e73a819c
-rw-rw-rw- 1 admin administ 52383392 May 19 15:25 dup-fba8469b-02b7-402b-a46e-3886078dcee1
-rw-rw-rw- 1 admin administ 54508 May 19 15:27 dup-0ae8f452-ea0b-43cd-8878-90226dcc92cf
-rw-rw-rw- 1 admin administ 74972 May 19 15:28 dup-19f91a52-9d27-446a-ab49-5c4bd70091ab
-rw-rw-rw- 1 admin administ 52374527 May 19 15:28 dup-0c493ce8-4323-4ad0-9697-ed5d7b5c30dc
-rw-rw-rw- 1 admin administ 52399499 May 19 15:28 dup-c03ec41d-83ca-4495-9c1c-86ff133a4ee9
-rw-rw-rw- 1 admin administ 36970 May 19 15:29 dup-6382a261-c964-40d3-934e-341209b41194
-rw-rw-rw- 1 admin administ 48561 May 19 15:30 dup-86728d3f-626a-4101-99ad-95fb770fab5c
-rw-rw-rw- 1 admin administ 52376473 May 19 15:31 dup-7df02480-d1a7-45c6-86a0-56c8252a4935
-rw-rw-rw- 1 admin administ 52397273 May 19 15:31 dup-57a5294d-d1ce-4bc3-a70b-c4916d37f965
-rw-rw-rw- 1 admin administ 29281 May 19 15:32 dup-68f795dc-3344-4ca5-9113-872a513faabf
-rw-rw-rw- 1 admin administ 52782 May 19 15:33 dup-1e24ca39-0baf-423e-8538-ca3112245206
-rw-rw-rw- 1 admin administ 52347550 May 19 15:34 dup-df852562-ac86-435f-92ab-9c1355605d02
-rw-rw-rw- 1 admin administ 52411888 May 19 15:34 dup-e428834c-003f-40e4-8103-dd59506535fb
-rw-rw-rw- 1 admin administ 47021 May 19 15:35 dup-89a7b6a6-9087-4d2d-8d9a-1951d5943074
-rw-rw-rw- 1 admin administ 39733 May 19 15:36 dup-b47218dc-1da3-42bb-ae49-22f8bfb79282
-rw-rw-rw- 1 admin administ 52392914 May 19 15:37 dup-6b74f83c-6d9f-4137-ac5d-d08033f10a0a
-rw-rw-rw- 1 admin administ 52385374 May 19 15:37 dup-7f7e6d19-bcc1-4a99-b6d5-4a56504964d4
-rw-rw-rw- 1 admin administ 54462 May 19 15:39 dup-0f68bfc6-9676-47db-89e1-2141daf335f5
-rw-rw-rw- 1 admin administ 41916 May 19 15:40 dup-ef421661-4ff6-4d30-affc-1217fdbf74c8
-rw-rw-rw- 1 admin administ 52342238 May 19 15:40 dup-23ffcb7b-efb7-4308-b383-6e561411ef8b
-rw-rw-rw- 1 admin administ 52378365 May 19 15:40 dup-387f4f8f-7fd2-4fa5-9d28-0f1f6b0ff8bc
-rw-rw-rw- 1 admin administ 41766 May 19 15:42 dup-7af6efbc-ef93-45d0-8d13-544cecbc3c9d
-rw-rw-rw- 1 admin administ 38552 May 19 15:43 dup-32344640-da20-42ec-b04a-3f60e3dd7453
-rw-rw-rw- 1 admin administ 52326514 May 19 15:43 dup-63776c79-9df8-47ef-a188-e8fd963b9c43
-rw-rw-rw- 1 admin administ 52370298 May 19 15:43 dup-dbee3734-e52a-46e3-8506-89622e442227
-rw-rw-rw- 1 admin administ 62924 May 19 15:44 dup-0d03efda-5f6d-468c-93e5-68a2fe996dcc
-rw-rw-rw- 1 admin administ 30646 May 19 15:45 dup-13ac500f-2016-41ad-b635-39c5fe0b7ad7
-rw-rw-rw- 1 admin administ 52352290 May 19 15:46 dup-c74994cc-d185-4b86-8a81-079130a21c73
-rw-rw-rw- 1 admin administ 52352120 May 19 15:46 dup-81858007-db02-4cb3-a13c-f895d4c397d4
-rw-rw-rw- 1 admin administ 28873 May 19 15:47 dup-112970a0-8b4f-4dcd-b966-c8bdc4b00bc7
-rw-rw-rw- 1 admin administ 49239 May 19 15:48 dup-ea974a1d-ca83-46ed-95fd-99458e59bf74
-rw-rw-rw- 1 admin administ 52378548 May 19 15:49 dup-881ec5f0-7e93-42bf-8cda-07a238520f40
-rw-rw-rw- 1 admin administ 52420863 May 19 15:49 dup-a17c7c63-908b-4143-9a0e-f7e99a7317bd
-rw-rw-rw- 1 admin administ 139433 May 23 02:37 dup-f6045a73-dba5-4eea-8aaf-9b6ba1a15097
-rw-rw-rw- 1 admin administ 104779778 May 23 02:37 dup-fd46a6b9-ea62-4ffd-8315-600bd4d2a1c2
-rw-rw-rw- 1 admin administ 104817126 May 23 02:37 dup-59146c6d-5bce-45ca-a1e7-18538dcaa236
-rw-rw-rw- 1 admin administ 104840926 May 23 02:38 dup-b1566302-44e1-4724-a33a-968e76112da4
-rw-rw-rw- 1 admin administ 104780088 May 23 02:38 dup-7e54198e-e01a-4aa3-915a-a1f1e6498191
-rw-rw-rw- 1 admin administ 163260 May 23 02:45 dup-a5751b9f-e24a-46af-adb7-0d8054937e53
-rw-rw-rw- 1 admin administ 104836003 May 23 02:46 dup-e3c13968-6a30-4246-a513-ad2ee7033e64
-rw-rw-rw- 1 admin administ 143420 May 23 02:52 dup-24fd104e-f0a6-453b-93b6-2e9591d5319b
-rw-rw-rw- 1 admin administ 111646 May 23 02:59 dup-0b23e48c-7e16-41a4-aaa8-f8a17b46499a
-rw-rw-rw- 1 admin administ 97070 May 23 03:05 dup-c316bbb4-04f3-474a-aa57-476523a8574f
-rw-rw-rw- 1 admin administ 72115 May 23 03:08 dup-1f57d4c9-c412-42c8-982f-180aeacdd19b
-rw-rw-rw- 1 admin administ 104786316 May 23 03:08 dup-11e20719-4654-4ca7-9bfe-a2fea9245da8
-rw-rw-rw- 1 admin administ 174547 May 23 03:13 dup-04de04ee-8371-4fed-9aea-b3d75223b07f
-rw-rw-rw- 1 admin administ 104758254 May 23 03:13 dup-7be7d585-4820-4f4d-ab9b-6642b07585ec
-rw-rw-rw- 1 admin administ 104769719 May 23 03:13 dup-2feb8bd4-7e49-4bd6-a261-244d4633e7cc
-rw-rw-rw- 1 admin administ 114386 May 23 03:19 dup-28e36550-d53a-432d-81e5-e12ea7638262
-rw-rw-rw- 1 admin administ 105339 May 23 03:26 dup-e99f3fe9-d920-4eeb-855c-b0ab3c986a10
-rw-rw-rw- 1 admin administ 104826883 May 23 03:26 dup-ae8c7e21-e28c-40a5-9476-82981597cec5
-rw-rw-rw- 1 admin administ 104770689 May 23 03:26 dup-9056d3ff-25ec-4c32-833b-b7b40a1e4186
-rw-rw-rw- 1 admin administ 104805172 May 23 03:27 dup-b04c4876-84cf-40fb-af24-4240d935f289
-rw-rw-rw- 1 admin administ 104832824 May 23 03:27 dup-bf17f041-929d-4adf-93f8-6a4d445fc232
-rw-rw-rw- 1 admin administ 109835 May 23 03:32 dup-84cad1ff-6434-467f-b58a-6315d4e34e95
-rw-rw-rw- 1 admin administ 104836003 May 23 03:33 dup-33cda13c-dd59-4db0-8315-f89e972d38a1
-rw-rw-rw- 1 admin administ 103701 May 23 03:38 dup-cba6093f-57c8-4e48-8b15-42e5d5acdc09
-rw-rw-rw- 1 admin administ 104836003 May 23 03:39 dup-ee077e4f-78eb-473d-bdc7-943ab456e821
-rw-rw-rw- 1 admin administ 124005 May 23 03:45 dup-dde0fe06-6078-4ee2-943f-a034332cfeaa
-rw-rw-rw- 1 admin administ 104836003 May 23 03:45 dup-a0cccdc8-852b-4d3f-ac3a-d871b6cad781
-rw-rw-rw- 1 admin administ 75986 May 23 03:50 dup-344a7f78-6a89-4b9c-85d6-f2245d230412
-rw-rw-rw- 1 admin administ 104836003 May 23 03:51 dup-bffe760f-ba30-4f8d-9f45-5223da74a96e
-rw-rw-rw- 1 admin administ 72115 May 23 03:54 dup-ceb65960-60ed-414a-80f2-f603acbaee78
-rw-rw-rw- 1 admin administ 104836003 May 23 03:54 dup-04f9b545-06f4-47e5-ac8c-abaa38067934
-rw-rw-rw- 1 admin administ 72115 May 23 03:58 dup-05e8fcaa-070f-4e9c-9040-3350c889222e
-rw-rw-rw- 1 admin administ 104836003 May 23 03:58 dup-c4265cc3-c53a-4986-bc5d-36ac3414264a
-rw-rw-rw- 1 admin administ 72115 May 23 04:02 dup-e461a8fd-7bc8-42b9-957b-33f84f6a569e
-rw-rw-rw- 1 admin administ 72115 May 23 04:05 dup-75358714-4ae7-4a4b-b2db-48303c6e59e5
-rw-rw-rw- 1 admin administ 72115 May 23 04:08 dup-f7c18ef8-057f-47e8-a7fe-900114ec32fa
-rw-rw-rw- 1 admin administ 174704 May 23 04:12 dup-f32c5c42-f9af-451d-b25d-41b1a7eab64a
-rw-rw-rw- 1 admin administ 104839230 May 23 04:12 dup-c07976cd-add8-45d7-9b64-5cb45aba8815
-rw-rw-rw- 1 admin administ 104846476 May 23 04:12 dup-45d959f7-75f9-4c37-9d64-a92a7b0b6613
-rw-rw-rw- 1 admin administ 104766574 May 23 04:13 dup-0fb00002-65ea-454c-8760-b8c87f37e917
-rw-rw-rw- 1 admin administ 118858 May 23 04:18 dup-672c6ec3-b4e2-4945-99f1-e47f45c40799
-rw-rw-rw- 1 admin administ 104815453 May 23 04:19 dup-1bc9c12e-dd08-424c-aa48-aedaf891c21c
-rw-rw-rw- 1 admin administ 104836003 May 23 04:19 dup-a9fac19b-6c30-47a9-86a1-ab98e1eb4c23
-rw-rw-rw- 1 admin administ 109301 May 23 04:25 dup-371c4430-ea81-4ee1-b28d-bd015a3afb34
-rw-rw-rw- 1 admin administ 80162 May 23 04:32 dup-988a6c9f-828a-4682-9451-4f5983cdf60e
-rw-rw-rw- 1 admin administ 130610 May 23 04:38 dup-c6d0e68f-aa58-45c9-b314-078612776728
-rw-rw-rw- 1 admin administ 72115 May 23 04:43 dup-cf3cf0cc-c294-483f-bbf3-081848970a6e
-rw-rw-rw- 1 admin administ 104825697 May 23 04:43 dup-343e8b72-2a91-4ba7-abc7-b0cdec0d3290
-rw-rw-rw- 1 admin administ 104836398 May 23 04:43 dup-b5fee63a-cd25-4ca0-b585-c3dceefb04a8
-rw-rw-rw- 1 admin administ 151745 May 23 04:50 dup-481dc266-d292-4bf5-bdb8-9ebc84ade5c2
-rw-rw-rw- 1 admin administ 117828 May 23 04:57 dup-b01e5e38-6412-4323-8c2e-8d5d737a2894
-rw-rw-rw- 1 admin administ 104851962 May 23 04:57 dup-04438d81-ac24-4a9c-9cc6-2fbb43e199b7
-rw-rw-rw- 1 admin administ 104843755 May 23 04:57 dup-94f0e8ff-d8ef-42da-9d88-ede1dc766dca
-rw-rw-rw- 1 admin administ 104758484 May 23 04:58 dup-5b733aa6-ccfb-4224-892c-6dbbc4e7c833
-rw-rw-rw- 1 admin administ 104758559 May 23 04:58 dup-7e0c4d2a-5c62-44a0-b692-e9e10074880d
-rw-rw-rw- 1 admin administ 123712 May 23 05:05 dup-4d6b1b9c-067d-45f3-9646-061c81bbb213
-rw-rw-rw- 1 admin administ 127335 May 23 05:12 dup-47f95925-bbd3-4022-8de2-f1e16891c21d
-rw-rw-rw- 1 admin administ 103999 May 23 05:18 dup-752d6af9-cd22-4c06-afee-15788886c728
-rw-rw-rw- 1 admin administ 79210 May 23 05:23 dup-524b21a2-a5d2-4e8f-9ccc-012f30856f40
-rw-rw-rw- 1 admin administ 104842837 May 23 05:24 dup-3b6bda0f-e643-4f00-903e-70189700cc04
-rw-rw-rw- 1 admin administ 104855508 May 23 05:24 dup-0bb8e15b-1f3d-4b4f-913f-45596cf92e53
-rw-rw-rw- 1 admin administ 104812057 May 23 05:25 dup-f1ca2470-73d7-4127-b2c2-71c51a3a5a72
-rw-rw-rw- 1 admin administ 121870 May 23 05:31 dup-d4a8daea-f823-49ab-8e96-2045c82b4c86
-rw-rw-rw- 1 admin administ 111294 May 23 05:38 dup-ea9d7d6d-9f7b-4950-bf10-fbe3986cfcfb
-rw-rw-rw- 1 admin administ 104771517 May 23 05:38 dup-a375ec30-763e-466b-96bd-e7805dafc59a
-rw-rw-rw- 1 admin administ 131596 May 23 05:44 dup-76d9d8d6-10d8-4835-bef5-076e8cbfa4cb
-rw-rw-rw- 1 admin administ 104302 May 23 05:50 dup-6bf48868-1f46-4c0a-bdda-7a506b66705c
-rw-rw-rw- 1 admin administ 104766043 May 23 05:51 dup-eb45aefc-a8cf-4521-9eff-ce17805fb25a
-rw-rw-rw- 1 admin administ 104822704 May 23 05:51 dup-c65d9f9d-4518-41e1-9611-ebf63e8b7ff1
-rw-rw-rw- 1 admin administ 114679 May 23 05:59 dup-4b9d8b24-87de-464a-af50-90f0c21ba30e
-rw-rw-rw- 1 admin administ 108578 May 23 06:06 dup-c365bd18-b3cb-4cbe-ab98-1a39233a45b4
-rw-rw-rw- 1 admin administ 104764305 May 23 06:06 dup-8dfbbde9-17c8-4b0b-9a61-69f741838b2f
-rw-rw-rw- 1 admin administ 104794498 May 23 06:06 dup-8f8d8ed8-a3a1-4fc1-a583-541741dc6b8a
-rw-rw-rw- 1 admin administ 135347 May 23 06:14 dup-2cf5aa43-4a35-416e-8f04-922e7724a9fe
-rw-rw-rw- 1 admin administ 83960 May 23 06:22 dup-9db52258-0f34-4d2f-aa57-f0286299b49b
-rw-rw-rw- 1 admin administ 104774858 May 23 06:22 dup-12bb73cd-8282-4bf7-9c12-24e60ea40478
-rw-rw-rw- 1 admin administ 104840623 May 23 06:23 dup-4672ebc9-ddc6-41f1-844b-542e1bd73bf7
-rw-rw-rw- 1 admin administ 104848667 May 23 06:23 dup-4bcdb98a-869e-4803-84b1-eecf6aa7d61b
-rw-rw-rw- 1 admin administ 104764262 May 23 06:23 dup-65d8448b-51ed-4c62-a8eb-40a04fe3d4b2
-rw-rw-rw- 1 admin administ 145818 May 23 06:30 dup-a37c933e-2f01-4298-b1df-f890ba93d8b8
-rw-rw-rw- 1 admin administ 104836003 May 23 06:31 dup-7d0250ab-90c6-45fc-94bf-7b9eb99bd83e
-rw-rw-rw- 1 admin administ 107316 May 23 06:38 dup-145f98ef-2de0-4115-b626-acae99d4445b
-rw-rw-rw- 1 admin administ 104836003 May 23 06:38 dup-8b09c89c-9f41-43a8-96c8-cff15553d951
-rw-rw-rw- 1 admin administ 79544 May 23 06:45 dup-fa9c8b2f-879a-41e3-88e7-564ff21b9cf1
-rw-rw-rw- 1 admin administ 104836003 May 23 06:45 dup-aca10e14-3751-46b3-a937-97a0535ef9ea
-rw-rw-rw- 1 admin administ 103350 May 23 06:51 dup-40d40bbd-a826-4192-aee2-55ecc0181238
-rw-rw-rw- 1 admin administ 104836003 May 23 06:52 dup-02738a2a-dc4a-4bac-b17e-8ef1ebad87fe
-rw-rw-rw- 1 admin administ 72115 May 23 06:55 dup-25c737ca-bbdc-4970-91fa-701937e90d62
-rw-rw-rw- 1 admin administ 104836003 May 23 06:56 dup-bf7531a7-be10-4506-ad84-dbf8240f14fd
-rw-rw-rw- 1 admin administ 104836317 May 23 06:56 dup-e4207a02-96e2-4165-a7a6-1a7d99c3eb59
-rw-rw-rw- 1 admin administ 72115 May 23 06:59 dup-9dd4190c-05cd-4876-9d5a-544b80c0a432
drwxrwxrwx 3 admin administ 135168 May 23 06:59 ./
-rw-rw-rw- 1 admin administ 76349708 May 23 07:00 dup-bb850cf9-9221-4d8f-a8e8-46207744a558
-rw-rw-rw- 1 admin administ 93880113 May 23 07:00 dup-23b5a945-c7a9-4a37-bb1c-7188651f189a
The actual running process has been started on the 22.05. and nothing else is running at the moment.
How can I downgrade? Just replacing the executable?
Found it
WARNING! Due to changes in database versions it is not possible (well, very hands-on) to downgrade ACROSS these versions (as of 2018-10-28):
2.0.1.7 (using version 3 - 0 & 2 usage in preview releases only)
2.0.1.18 (move to version 4)
2.0.3.4 (move to version 5)
2.0.3.12 (move to version 6 - see Release: 2.0.3.12 (canary) 2018-10-23 )
2.0.4.13 (unconfined move to version 7 - see *broken* Release: 2.0.4.13 (canary) 2019-01-29 )
2.0.4.23 from 2.0.4.13 or newer (2.0.4.23 beta is a notification upd…
edit:
seems that the hint with the downgrade did the job:
CPU and Upload are now working in parallel. I also left the compression activated.
And I also get this message:
which I didn’t had with 2.0.3.6 (collecting data)
Glad to hear it! (Sorry I didn’t include the link to the How-To - it’s still new so I keep forgetting it’s there.)
The “Collecting data” message issue has mostly just been a browser caching problem of some updated CSS - a few ctrl+f5 refreshes or a new incognito / private window generally resolves that issue.
I’ve gone ahead and flagged your post as the solution as well as updated the topic title to better reflect the specific issue that was address. Please let me know if you disagree with either!
