Error in my log:
2019-01-03 00:37:29 -05 - [Error-Duplicati.Library.Main.Database.LocalBackupDatabase-CheckingErrorsForIssue1400]: Checking errors, related to #1400. Unexpected result count: 0, expected 1, hash: mzp5GXIVXICmXDUaGPQ6T0RBjJd6FUvGhv+6IHUcRV8=, size: 68544, blocksetid: 63134, ix: 47, fullhash: 6xvaiAfAUnq3x1pjPRmcpeCoyKY8L/mMClwsTQRhD8Q=, fullsize: 4881344,
2019-01-03 00:37:29 -05 - [Error-Duplicati.Library.Main.Database.LocalBackupDatabase-FoundIssue1400Error]: Found block with ID 253058 and hash mzp5GXIVXICmXDUaGPQ6T0RBjJd6FUvGhv+6IHUcRV8= and size 52128
These are related to git issue Failed to process path: xxx => Unexpected result count: 0, expected 1 · Issue #1400 · duplicati/duplicati · GitHub. I wasn’t sure if I should post here or there so I posted here.
Some notes. I have the default --snapshot-policy = off which I will turn on for the future. I think default should be on, but that’s just me.
And I know it’s off (well, at least I think so) because I also get these warnings:
Failed to process path: C:\Users\USER1\NTUSER.DAT,
Failed to process path: C:\Users\USER1\ntuser.dat.LOG1,
Failed to process path: C:\Users\USER1\ntuser.dat.LOG2,
Failed to process path: C:\Users\USER1\AppData\Local\Microsoft\Windows\UsrClass.dat,
Failed to process path: C:\Users\USER1\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG1,
Interestingly, I did NOT get these errors first time.
I am trying to backup two Windows user trees.
First time, ran as USER1 un-elevated/not-prived and I could not backup USER2 cuz no access.
Second time, ran as USER1 with Run as administrator and I could then backup USER2 but I got the errors and warnings above.
So with no snapshot perhaps this is simply that files changed between start and end of backup.
