I use Duplicati - 2.0.3.3_beta_2018-04-02 for several backup jobs to cloud destinations. I wanted to change the destination for one of the jobs from Mega to Google Drive keeping the backups aready made.
I synced the files from Mega to Google Drive using rclone.
I changed the job’s destination to Google Drive.
Connection test worked.
The first run gave the error message: Found 82 remote files that are not recorded in local storage, please run repair
In the log:
Fatal error
Duplicati.Library.Interface.UserInformationException: Found 82 remote files that are not recorded in local storage, please run repair
a következő helyen: Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
a következő helyen: Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify(BackendManager backend, String protectedfile)
a következő helyen: Duplicati.Library.Main.Operation.BackupHandler.Run(String[] sources, IFilter filter)
A database Repair resulted in the error message: Got 34 error(s) with no new entries in the log.
Then I tried database Recreate. Result: The requested file does not exist
Log:
Apr 30, 2018 4:17 PM: Message
Processing required 1 blocklist volumes
Remote file referenced as duplicati-b8b055dfa998a4f0dafe5922546d6f447.dblock.zip.aes, but not found in list, registering a missing remote file
Remote file referenced as duplicati-be5ab965c9e8d4b61ad7da6e4eb195ff2.dblock.zip.aes, but not found in list, registering a missing remote file
Remote file referenced as duplicati-beeb2e5f144d94bbfa7e05452355bb3fb.dblock.zip.aes, but not found in list, registering a missing remote file
Finally I reverted the destination to Mega. A database Repair was needed and backups can be run again.
Did I miss a step in the process or what can be the cause of the errors?
