example with alias duplicati='docker exec -it duplicati mono /app/duplicati/Duplicati.CommandLine.exe'
This excludes everthing: duplicati test-filters /mnt/ --exclude='[/(m)nt/.*]'
This excludes nothing: duplicati test-filters /mnt/ --exclude='[/(m|)nt/.*]'
nor does this: duplicati test-filters /mnt/ --exclude='[/(m|aaa)nt/.*]'
Shouldn’t that work?
I have two layers of (x|y|z) and (a|b|c) in my expression so that will explode to 9 cases which is a pain.
Best Alex
PS: Edit after ts678 response: The * is missing in the last two examples, but its there in the raw post. I guess the forum also messes with regExp to confuse the user
PPS: Now with proper markdown (thx kenkendk)
I think you dropped an essential * at the end of the RE in the last two, but even after a fix, it’s acting odd.
Here’s a test I made by touch of three files, one with a vertical bar embedded in it. Notice how it found it:
$ ls -ln /tmp/sub
total 0
-rw-r--r-- 1 1000 1000 0 Sep 4 21:09 1
-rw-r--r-- 1 1000 1000 0 Sep 4 21:09 1|2
-rw-r--r-- 1 1000 1000 0 Sep 4 21:09 2
$ duplicati-cli test-filters /tmp/sub --exclude='[.*(1|2).*]'
Including source path: /tmp/sub/
Including path as no filters matched: /tmp/sub/1
Including path as no filters matched: /tmp/sub/2
Excluding path due to filter: /tmp/sub/1|2 => ([.*(1\|2).*])
Matched 2 files (0 bytes)
$ duplicati-cli test-filters /tmp/sub --include='[.*(1|2).*]'
Excluding path due to filter: /tmp/sub/1 => null
Excluding path due to filter: /tmp/sub/2 => null
Including path due to filter: /tmp/sub/1|2 => ([.*(1\|2).*]) || (*/)
Matched 1 files (0 bytes)
Windows doesn’t backslash-escape the vertical bar. I wonder if something is trying to avoid Linux pipes?
/mnt/user/media/TestDuplicati --exclude='[/mnt/user/media/TestDuplicati/(Test1\|Test2)/.*]'
Including source path: /mnt/user/media/TestDuplicati/
Excluding path due to filter: /mnt/user/media/TestDuplicati/Test2/ => ([/mnt/user/media/TestDuplicati/(Test1\\|Test2)/.*])
The input filter has only one backslash on the pipe \| but the output has two \\|
I think the info under Syntax in the section 'Folder names always end with a slash ’ is incorrect. Are they talking about source set or filters? Its certainly not relevant for regular expressions.
I rarely use filters, and may be wrong, but the following indicates slash is relevant for regular expressions:
The best rule for “but nothing else” is a regular expression that excludes all files. It is -[.*[^/]] on Linux or Mac, and on Windows the rule is -[.*[^\\]]. The rule says “exclude everything that is not a folder”.
Being somewhat more familiar with internals such as the database File table, the Path there follows this backslash rule, with a trailing backslash (of the proper direction for the OS) only applied if it’s a folder, so filter rule syntax might be using the same mechanism to distinguish even if you don’t see the backslash.
I have a good understanding of the how the filters works in duplicati by, though it took some time. Especially because I suck at taking the few minutes to actually properly read the docs I wrote the Advanced section under filters help because that gives a much better understanding (in my view) of how the filtering works in duplicati, and also illustrates exactly what you pointed to by excluding all remaining files - well almost, because I exclude all files in top dirs.
I also just added a link in the docs to online regexp builder, that helps enourmously when RegExp semantics and my brain is out of sync.
Can you try adding --debug-output to the commandline? This should show what input reaches Duplicati, so we know if the substitution happens before Duplicati is invoked.
Backslash is early and generic. –parameters-file looked for the backslashed version. –log-file wrote to one. Had the backslash both when passing vertical bar in an option, or in the non-option portion of a command. Finally I did test below which appears to suggest that backslash is added when starting the child Duplicati:
I tried --debug-output, but it seems it doesn’t include the filters.
$ docker exec duplicati mono /app/duplicati/Duplicati.CommandLine.exe test-filters /mnt/user/media/TestDuplicati/A/AA --exclude='[/mnt/user/media/TestDuplicati/A]' --debug-output
Input command: test-filters
Input arguments:
Input options:
debug-output:
Including source path: /mnt/user/media/TestDuplicati/A/AA/
Including path as no filters matched: /mnt/user/media/TestDuplicati/A/AA/.disk3.md5
Including path as no filters matched: /mnt/user/media/TestDuplicati/A/AA/.user.md5
Including path as no filters matched: /mnt/user/media/TestDuplicati/A/AA/@Minecraft Install.lnk
Matched 3 files (868 bytes)
Ah, intersteting with the --parameters-file. However I couldn’t get it to work for me, none of my magic encantations below worked (the cat illustrates that the file is there readable from within the docker):
alex@Tower: /mnt/user/home/alex/duplicati
$ docker exec duplicati mono /app/duplicati/Duplicati.CommandLine.exe test-filters --parameters-file=/mnt/user/home/alex/duplicati/testFilterParamFile /mnt/user/media/TestDuplicati/A
Including path as no filters matched: /mnt/user/media/TestDuplicati/A/AB/
Including path as no filters matched: /mnt/user/media/TestDuplicati/A/AB/.disk3.md5
Including path as no filters matched: /mnt/user/media/TestDuplicati/A/AB/.user.md5
Including path as no filters matched: /mnt/user/media/TestDuplicati/A/AB/@Minecraft Install.lnk
Matched 6 files (1.70 KB)
$ docker exec duplicati cat /mnt/user/home/alex/duplicati/testFilterParamFile
--source=/mnt/user/media/TestDuplicati/
--exclude='[/mnt/user/media/TestDuplicati/(A|Test1)/]'alex@Tower: /mnt/user/home/alex/duplicati
No source paths given
$ docker exec duplicati mono /app/duplicati/Duplicati.CommandLine.exe --parameters-file=/mnt/user/home/alex/duplicati/testFilterParamFile test-filters
also --log-file=/mnt/user/home/alex/duplicati/dup.log gives me an empty log file.
I didn’t quite understand your post, maybe you just refered to a previous issue, I though I could get log.
My --parameters-file test and --log-file tests were just diagnostics to see what file was used. Testing with --parameters-file would show which file (backslashed or not) would be used for input, --log-file for output.
Actually using the --parameters files to supply the filter works, but you don’t quote, and need source path:
$ cat no_mnt
--exclude=[/(m|)nt/.*]
$ duplicati-cli test-filters /mnt/ --parameters-file=no_mnt
Excluding path due to filter: /mnt/root-filesystem/ => ([/(m|)nt/.*])
Excluding path due to filter: /mnt/Shared_with_VM/ => ([/(m|)nt/.*])
Excluding path due to filter: /mnt/ramdisk/ => ([/(m|)nt/.*])
Excluding path due to filter: /mnt/dev-sda1/ => ([/(m|)nt/.*])
Excluding path due to filter: /mnt/tmp/ => ([/(m|)nt/.*])
Matched 0 files (0 bytes)
$ AUTOUPDATER_Duplicati_SKIP_UPDATE=true duplicati-cli test-filters /mnt/ --exclude='[/(m|)nt/.*]'
Prefix way of setting a temporary environment variable can be long term (if you prefer it that way) by using export AUTOUPDATER_Duplicati_SKIP_UPDATE=true but you need export -n if you change your mind.
$ docker exec duplicati mono /app/duplicati/Duplicati.CommandLine.exe test-filters /mnt/user/media/TestDuplicati/A/AA --anyWrongName='[/mnt/user/media/TestDuplicati/(A|A)]' --debug-output
Input arguments:
Input options:
anywrongname: [/mnt/user/media/TestDuplicati/(A\|A)]
debug-output:
The supplied option --anywrongname is not supported and will be ignored
# --log-file=/mnt/user/home/alex/duplicati/dup.log
So indeed, the pipe got backslashed before reaching duplicati debug printer.
On a side note, are you aware Win10 has a linux subsystem? That might make it a lot easier to test such stuff, if you are on Windows.
Great, thanks. Now --parameter-file works for me. I suppose the --log-file is for log-output when a backup is made, its still empty with just test-filters.
$ cat ./testFilterParamFile
--exclude=[/mnt/user/media/TestDuplicati/(A|Test1)/]
$ duplicati test-filters /mnt/user/media/TestDuplicati --parameters-file=/mnt/user/home/alex/duplicati/testFilterParamFile
Excluding path due to filter: /mnt/user/media/TestDuplicati/A/ => ([/mnt/user/media/TestDuplicati/(A|Test1)/])
Excluding path due to filter: /mnt/user/media/TestDuplicati/Test1/ => ([/mnt/user/media/TestDuplicati/(A|Test1)/])
Including path as no filters matched: /mnt/user/media/TestDuplicati/Test2/
Including path as no filters matched: /mnt/user/media/TestDuplicati/Test22/
Including path as no filters matched: /mnt/user/media/TestDuplicati/TestA/
I think it makes sense to add an example to the page Advanced Options - Duplicati 2 User's Manual though I cannot do that. I’ll probably add the --parameters-file info to the docs on filters tomorrow, its late now here, and my kids are pulling on me to be put to bed…
That suggests that it is actually the shell/terminal that is doing the escaping. That means that we cannot really fix it inside Duplicati. I think @ts678 had the correct guess:
Hmm I just realized this is pretty identical to the filter test. This just indicates that the pipe reaches the duplicati option handler escaped. It doesn’t say anything about the cause. I wonder what a mono hello world example which just echo input would output. https://www.mono-project.com/docs/getting-started/mono-basics/
Is anyone noticing my Backslash is early and generic finding that this happens at first instant after start? Duplicati starts a child process that does all the actual work (except figuring out which update to launch) however child can be avoided with environment variable AUTOUPDATER_Duplicati_SKIP_UPDATE=true.
Don’t look at the later code analysis too hard. Testing shows somehow the end escaping isn’t happening however I’m kind of confused by the Regex. If that’s a character class, the vertical bars aren’t alternation. Tests, however, show the only character in the Regex that’s escaped is vertical bar. Needs more study…
That said, this still seems like a relatively not-super-critical bug compared to others. It may need an issue filed to keep track of it until whenever the time comes that the less critical bugs get their turn for attention.
Those two GitHub issues are definitely the same underlying cause (this and the one you just linked). I have linked the github issues with a comment.
Wow that’s huge indicator. I didn’t see the point before, to much text spammed my mind in the output.
Here some more
Here the problem is seen:
In the last, the variable is set to empty string/null, whatever that means in bash.
$ ANY_DUMMY=1 mono Duplicati.CommandLine.exe help '1|2'
Topic not found: 1\|2
$ AUTOUPDATER_Duplicati_SKIP_UPDATE= mono Duplicati.CommandLine.exe help '1|2'
On this code-path, the problem is avoided:
$ AUTOUPDATER_Duplicati_SKIP_UPDATE=true mono Duplicati.CommandLine.exe help '1|2'
Topic not found: 1|2
$ AUTOUPDATER_Duplicati_SKIP_UPDATE=1 mono Duplicati.CommandLine.exe help '1|2'
So definitely this is a duplicati issue, its not a bash or mono issue. Something in duplicati messes the arguments, when AUTOUPDATER_Duplicati_SKIP_UPDATE isn’t running.
Since the updater spawns a new executable (to allow unloading and restarting on an update), it needs to pass the commandline arguments to the new process.
Ah you found it, great! Then comes the next troubling question of what it was trying to solve and avoid braking that part. The fun life of a programmer, all that detective work
