As per this thread title, the text like: “70601 files (206.91 GB) to go at 727.85 KB/s” Cannot be seen as it is rendering under the title.
Suggest making the text smaller so 2 lines will fit in the progress bar, and top aligning the backup title, and bottom aligning the XXX files and speed line, e.g.:
My Backup Title
There have been some recent updates to the status bar that should have helped with this issue - can you confirm what version of Duplicati you are running?
I’ve just opened the GUI for the first time in a long time as I’ve not needed to use it.
Now i can only see the backup job name in the progress bar. The rest is hidden on a 2nd line. I can select it, copy it, then read it, but can’t see it all at the same time.
Here’s the text:
UnRAID to ReadyNAS
161 files (39.94 GB) to go at 782.94 KB/s
It would be better if the progress text “161 files (39.94 GB) to go at 782.94 KB/s” was always displayed below the progress bar. then length of text will no longer be an issue.
Edit:
Google Chrome Version 70.0.3538.110 (Official Build) (64-bit)
Win 7
