I am trying to use box.com for storage. I use the AuthID wizard to create the login and everything indicates success. When I click the test button I receive the error: Failed to connect: Error: SecureChannelFailure (The authentication or decryption has failed.)
Box.com web interface shows the app access for duplicati. Not sure how to get past this problem to get my backup setup.
Running package on debian 9 and Duplicati - 2.0.4.23_beta_2019-07-14
This is possibly a TLS problem between mono and box.com.
What does mono --version say? If it says 4.6.2.7+dfsg-1 you might be on the latest from Debian but not high enough to do TLS 1.2. Before mono 4.8, TLS ended at TLS 1.0, leading to the following problem:
