Best Practice for backing-up local database
Is there an accepted “best practice” for backing up the local Duplicati sqlite database?
Is it worth excluding the database from existing backups, and then creating a backup that only backs up the databases for the other backups? Or instead of a backup, use a tool to upload the database(s) to the cloud?
I know some Duplicati users do make a backup of the local database.
I think they will usually have an additional backup that takes care of databases, and then schedule it to run a few minutes after the primary backup.
The design of Duplicati is such that the local database is not needed, so from a design perspective, you should not have to do so.
In the past, there has been complaints that the recreate database was really slow, and in some cases failed, requiring the use of the recovery tool to get data out.
Happily corrected, but I do not believe any of these concerns are valid anymore.
This is basically what I was considering.
From another post:
So the database recreate was really slow, and the clean-up has resulted in issues that have not yet been solved.
As a user, I consider these concerns to still be valid.
I haven’t heard of RecoveryTool use in a really long time, but not all are reported.
More common is the slow or failed path, then it’s a fight to get back into business.
I use “business” for all users’ routines, but actual businesses may prefer to spend resources to reduce risk of downtime (they should have multiple backups though).
Personal backups might have a different tradeoff about predictability of recoveries.
In addition to that posted situation, there’s my own recent situation where 2.1.0.107 Canary made a mess that took a long time to find a working path to a DB recovery.
Granted, Canary is a test release, but some of these same bugs landed in the Beta and first 2.1.0.4 Stable release, leading to fast 2.1.0.5 Stable and low broad impact.
Database Restore Takes Over 5 Days/Looking for Alternatives hasn’t concluded yet.
is another Canary case that hasn’t even been started on. Concerns remain valid.
Situation seems to be generally improving (ignoring Canary risk), but isn’t solved.
I still backup my job databases in a separate job, but I don’t schedule it. Instead I use the after job script to run it via a command. All my main jobs exclude their own database when backing up the main Duplicati data directory and then the extra backup picks up that database without worrying about it being in use.
I still worry about the main Duplicati database as I don’t think that can be simply “rebuilt” like the others, unless I’m mistaken. If not, then some way to back that up cleanly would be nice if the database is in use, It’s come in handy when rebuilding a failed machine.
I have created a separate backup for the Duplicati configuration directory and excluded the same directory from the regular backup. The backup of the configuration directory is scheduled to run after all the other backups.
I get the design point that the local database is supposed to be rebuildable from the remote files, but in practice that assumption has not held up well for me.
I’ve spent about a month and a half unable to run a normal backup because the database recovery path keeps failing. That has included multiple machines, multi-day recreate/repair attempts, operations running for 3-5 days and then failing, and long periods where the backup set exists but I still can’t safely resume backups.
So while the local database may not be required in theory, I now see it as important recovery metadata. For a small backup, recreating it might be fine. For a large backup, a known-good copy of the local database could be the difference between a quick recovery and months of downtime.
