Hello!
I want to backup data to my StorageBox from Hetzner. I want to do it via the SFTP protocol. But sadly it never works. When I test the connection it works, but I always have to confirm this message manually:
“The host key has changed, please check with the server administrator if this is correct, otherwise you could be the victim of a MAN-IN-THE-MIDDLE attack. Do you want to REPLACE your CURRENT host key [key are displayed here]…?”
When I accept it the connection test is successful. I can do a backup manually after accepting the certificate but a few hours later i would have to accept it again to do a backup. I guess that’s the reason why the automated backups never work.
Wanted to try it with webdav but I can’t get any connection there. Don’t know what I’m doing wrong there.
Does anyone have experience with duplicati & Hetzner and can help me set up a stable, working connection?
Thanks (:
