Backups start failing after a week or so
I have a backup that after a week or so starts to fail with various errors usually stating that files are missing at the remote storage (an NFS share).
Failed: Found 51 files that are missing from the remote storage, please run repair
Details: Duplicati.Library.Interface.RemoteListVerificationException: Found 51 files that are missing from the remote storage, please run repair
I’ve not been able to figure out why so far and sometimes a repair/purge will fix it but most times I have to wipe the backups and start again. I thought it might have been because sometimes the remote server is rebooted and so the NFS share is disconnected, but that has never happened during a backup and I made sure the past few weeks manally run a “mount -a” after the reboot and confirmed the files are accessible.
The only errors that seem to come up constantly are:
6 Dec 2021 07:42: Failed to load assembly /usr/lib/duplicati/MimeKit.dll, error message: Exception of type 'System.Reflection.ReflectionTypeLoadException' was thrown. Could not load file or assembly 'BouncyCastle.Crypto, Version=1.8.5.0, Culture=neutral, PublicKeyToken=0e99375e54769942' or one of its dependencies. Could not load file or assembly 'BouncyCastle.Crypto, Version=1.8.5.0, Culture=neutral, PublicKeyToken=0e99375e54769942' or one of its dependencies. Could not load file or assembly 'BouncyCastle.Crypto, Version=1.8.5.0, Culture=neutral, PublicKeyToken=0e99375e54769942' or one of its dependencies. Could not load file or assembly 'BouncyCastle.Crypto, Version=1.8.5.0, Culture=neutral, PublicKeyToken=0e99375e54769942' or one of its dependencies. Could not load file or assembly 'BouncyCastle.Crypto, Version=1.8.5.0, Culture=neutral, PublicKeyToken=0e99375e54769942' or one of its dependencies.
And also
"ClassName":"System.Net.WebException","Message":"Error: TrustFailure (Authentication failed, see inner exception.)","Data":null,"InnerException":{"ClassName":"System.Security.Authentication.AuthenticationException","Message":"Authentication failed, see inner exception.","Data":null,"InnerException":{"Message":"Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED\n  at /build/mono-2liaiA/mono-5.18.0.240+dfsg/external/boringssl/ssl/handshake_client.c:1132","Data":{},"InnerException":null,"StackTrace":"  at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00054] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000c6] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool)\n  at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x0012a] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at Mono.Net.Security.AsyncProtocolRequest.StartOperation (System.Threading.CancellationToken cancellationToken) [0x000a4] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 ","HelpLink":null,"Source":"mscorlib","HResult":-2146233088},"HelpURL":null,"StackTraceString":"  at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00336] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x0018c] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001f5] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 ","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2146233087,"Source":"mscorlib"},"HelpURL":null,"StackTraceString":"  at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x00275] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x0015b] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at System.Net.WebOperation.Run () [0x000b7] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x000b1] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x00118] in <a9a08e39ba304bd0a84c49bd158dfc02>:0 \n  at Duplicati.Library.Utility.AsyncHttpRequest+AsyncWrapper.GetResponseOrStream () [0x0004d] in <d644d641ef094b6cbc223bc3a32d53af>:0 \n  at Duplicati.Library.Utility.AsyncHttpRequest.GetRequestStream (System.Int64 contentlength) [0x00068] in <d644d641ef094b6cbc223bc3a32d53af>:0 \n  at Duplicati.Library.UsageReporter.ReportSetUploader+<>c.<Run>b__3_0 (CoCoL.IReadChannel`1[T] chan) [0x000c4] in <5d01de97f88c47219817ca3929a597f5>:0 ","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2146233079,"Source":"Duplicati.Library.Utility"}
Any ideas?
APIVersion : 1
PasswordPlaceholder : **********
ServerVersion : 2.0.6.100
ServerVersionName : - 2.0.6.100_canary_2021-08-11
ServerVersionType : Canary
StartedBy : Server
BaseVersionName : 2.0.6.100_canary_2021-08-11
DefaultUpdateChannel : Canary
DefaultUsageReportLevel : Information
ServerTime : 2021-12-06T07:49:30.075328+01:00
OSType : Linux
DirectorySeparator : /
PathSeparator : :
CaseSensitiveFilesystem : true
MonoVersion : 5.18.0.240
MachineName : ziff
UserName : root
NewLine :
CLRVersion : 4.0.30319.42000
CLROSInfo : {"Platform":"Unix","ServicePack":"","Version":"5.10.63.7","VersionString":"Unix 5.10.63.7"}
ServerModules : []
UsingAlternateUpdateURLs : false
LogLevels : ["ExplicitOnly","Profiling","Verbose","Retry","Information","DryRun","Warning","Error"]
SuppressDonationMessages : true
SpecialFolders : [{"ID":"%MY_DOCUMENTS%","Path":"/root"},{"ID":"%HOME%","Path":"/root"}]
BrowserLocale : {"Code":"en-GB","EnglishName":"English (United Kingdom)","DisplayName":"English (United Kingdom)"}
SupportedLocales : [{"Code":"bn","EnglishName":"Bangla","DisplayName":"বাংলা"},{"Code":"ca","EnglishName":"Catalan","DisplayName":"català"},{"Code":"cs","EnglishName":"Czech","DisplayName":"čeština"},{"Code":"da","EnglishName":"Danish","DisplayName":"dansk"},{"Code":"de","EnglishName":"German","DisplayName":"Deutsch"},{"Code":"en","EnglishName":"English","DisplayName":"English"},{"Code":"en-GB","EnglishName":"English (United Kingdom)","DisplayName":"English (United Kingdom)"},{"Code":"es","EnglishName":"Spanish","DisplayName":"español"},{"Code":"fi","EnglishName":"Finnish","DisplayName":"suomi"},{"Code":"fr","EnglishName":"French","DisplayName":"français"},{"Code":"fr-CA","EnglishName":"French (Canada)","DisplayName":"français (Canada)"},{"Code":"hu","EnglishName":"Hungarian","DisplayName":"magyar"},{"Code":"it","EnglishName":"Italian","DisplayName":"italiano"},{"Code":"ja-JP","EnglishName":"Japanese (Japan)","DisplayName":"日本語 (日本)"},{"Code":"ko","EnglishName":"Korean","DisplayName":"한국어"},{"Code":"lt","EnglishName":"Lithuanian","DisplayName":"lietuvių"},{"Code":"lv","EnglishName":"Latvian","DisplayName":"latviešu"},{"Code":"nl-NL","EnglishName":"Dutch (Netherlands)","DisplayName":"Nederlands (Nederland)"},{"Code":"pl","EnglishName":"Polish","DisplayName":"polski"},{"Code":"pt","EnglishName":"Portuguese","DisplayName":"português"},{"Code":"pt-BR","EnglishName":"Portuguese (Brazil)","DisplayName":"português (Brasil)"},{"Code":"ro","EnglishName":"Romanian","DisplayName":"română"},{"Code":"ru","EnglishName":"Russian","DisplayName":"русский"},{"Code":"sk","EnglishName":"Slovak","DisplayName":"slovenčina"},{"Code":"sk-SK","EnglishName":"Slovak (Slovakia)","DisplayName":"slovenčina (Slovensko)"},{"Code":"sv-SE","EnglishName":"Swedish (Sweden)","DisplayName":"svenska (Sverige)"},{"Code":"th","EnglishName":"Thai","DisplayName":"ไทย"},{"Code":"zh-CN","EnglishName":"Chinese (Simplified)","DisplayName":"中文 (中国)"},{"Code":"zh-HK","EnglishName":"Chinese (Traditional, Hong Kong SAR China)","DisplayName":"中文 (中国香港特别行政区)"},{"Code":"zh-TW","EnglishName":"Chinese (Traditional)","DisplayName":"中文 (台湾)"}]
BrowserLocaleSupported : true
backendgroups : {"std":{"ftp":null,"ssh":null,"webdav":null,"openstack":"OpenStack Object Storage / Swift","s3":"S3 Compatible","aftp":"FTP (Alternative)"},"local":{"file":null},"prop":{"s3":null,"azure":null,"googledrive":null,"onedrive":null,"onedrivev2":null,"sharepoint":null,"msgroup":null,"cloudfiles":null,"gcs":null,"openstack":null,"hubic":null,"b2":null,"mega":null,"box":null,"od4b":null,"mssp":null,"dropbox":null,"sia":null,"storj":null,"tardigrade":null,"jottacloud":null,"rclone":null,"cos":null}}
GroupTypes : ["Local storage","Standard protocols","Proprietary","Others"]
Backend modules: aftp azure b2 box cloudfiles dropbox ftp file googledrive gcs hubic jottacloud mega msgroup onedrivev2 sharepoint openstack rclone s3 ssh od4b mssp sia storj tahoe tardigrade cos webdav
Compression modules: zip 7z
Encryption modules: aes gpg
This is almost certainly a problem on the back end. Files should not just disappear. Running repair might get Duplicati working again, but you still lost data for some reason.
Could you perhaps try using a different back end protocol to see if you experience the same thing? That’s probably what I’d do in your situation just to see what happens.
Sorry, I was not fully clear - the files do not disappear, the NFS share does not disappear, everything is there even before I ran a “mount -a” for good measure. For example, it performed its backup last Friday without issue, but then come Monday morning and it goes to run the same job, it errors. No amount of repair, delete & repair, purge broken or anything else would fix the job. At one point it told me I had extra files, the ones from Friday as it turned out, so I removed them and tried again, and I was back to missing of different files.
Since I wrote the original post I have now uninstalled and re-installed Duplicati (including Mono) hoping it might remove the weird BouncyCastle messages, it did not, plus I deleted the backup job, database and backup files, created a new one and the job ran first time successfully, but still with those messages. I will now see how it behaves in the coming days.
Ok, so what you’re saying is the files Duplicati claims are missing are actually present in the NFS share?
Are you backing up to Backblaze B2? It started failing last week because they updated the SSL certificate and Duplicati doesn’t accept the new certificate. See separate thread on that.
Yup, hopefully I’ll no more soon, as either way recreating the job will fix or do nothing for the problem. I’ll make sure to properly document what goes on.
Nope, NFS share as stated
Small related question while I continue to diagnose this, is it possible to connect to an NFS share with the backup job in the same way as I would do with an SMB share? At the moment I’m using an auto-mount in the OS itself to mount during boot, which has it’s own issues, so I was wondering if I could get Duplicati to do it instead in the same way as I do for Windows machines.
No, doesn’t look like Duplicati supports NFS directly. It’s not one of the supported back ends.
A similar test might be to uninstall your current 2.0.6.100 and downgrade to the previous Canary 2.0.5.114_canary_2021-03-10, Alternatively, do you recall if 2.0.6.100 is when messages began?
A somewhat less disruptive real test would be to unzip 2.0.5.114 and add a file to Duplicati area:
/usr/lib/duplicati/BouncyCastle.Crypto.dll
Theory behind this is that MailKit.dll 2.3.1.0 has a dependency on MimeKit >= 2.3.1 which has a
dependency on BouncyCastle >= 1.8.5 which Duplicati shipped until 2.0.6.100 removed its use,
possibly not realizing that there was an indirect use through MailKit which is used to send email.
Weighing against the theory is that 2.0.6.100 has been out four months, so who gets this or not?
Regarding NFS, no ideas yet, but did anything known change around then that might be related?
Nor does it support SMB. Storage Type is Local folder or drive I guess. OS does the rest.
Do you mean the allegedly missing files are there, or just something is there that looks a backup?
An Information-level log is good to get. It shows the remote file actions and the missing file names.
Use About → Show log → Live → Information or log-file=<path> and log-file-log-level=information.
Tried copying the BouncyCastle.Crypto.dll from the previous RPM file and the message has now stopped appearing for any jobs, so it does seem something needs fixing in MimeKit like you thought.
I do however get this which I think was logging before:
{"ClassName":"System.Net.WebException","Message":"Error: TrustFailure (Authentication failed, see inner
at
With regards to NFS, I assumed that using an SMB share like this meant that it was supported which is why I asked if I could do the same with an NFS share
BTW, I think I might have found the NFS file issue which could be a permissions problems with the files themselves, so I have reset the owner/rights on all share and will see how it goes. How they got messed up is beyond me.
SMB is not directly supported by Duplicati, but as you noted on a Windows system you can use UNC path as the destination because the underlying OS handles the work. UNC paths do not work on non-Windows systems. So that’s why we say it doesn’t directly support SMB.
What you do on Windows isn’t so clear, but because you’re talking about mounting, maybe you want this:
How To Automatically Mount NFS File System with AutoFS
Basically mount on access rather than mount at boot? If so, there’s lots more information on the Internet.
I don’t personally use this and I don’t know how common it is, but I don’t recall hearing it hurts Duplicati…
Another thing that people can do is to use Duplicati scripting options to mount, do backup, then unmount.
I suppose one consideration in all this is which solution gives the desired ability to deal with mount errors.
As a test, you can try changing Settings for Usage statistics:
Setting this to None will disable reporting usage statistics at all.
which looks like it will disable upload. Does it always fail (maybe once per backup) or only sometimes?
What OS is this? This error looks like one that’s begun due to mono, OS, and Let’s Encrypt certificates:
Http send report errors / duplicati-monitoring has one of the better workaround lists, but there are others.
So far so good with my NFS share, I think the issue was with some weird permissions on some of the files, though doesn’t explain how it would sometimes work.
I disabled the reporter and the message has gone - it was actually the only one of my machines with it still enabled.
Thanks for the tip on that other thread, as the SSL message does appear to be due to the old Let’s Encrypt CA certificate still being present - the OS on the problem machines is Raspberry Pi OS (Buster) but it’s ca-certificates package is still dated 2020 even though there is definitely a newer one for Debian now. After I removed the certificate and did the update-ca-certificate it went away along with the block to being able to use an SSL certificate (not an LE one) for the web interface which was nice.
After a backup pause of 14 days I had the error “Failed: Found x files that are missing from the remote storage, please run repair” as well.
I’m using 2.0.6.1_beta_2021-05-03 under WIN10. My backup destination is a USB3 Harddisk.
I tried to repair and executed purge-broken-files,but with no avail.
As solution I started over with a new backup job.
For years I had never problems with dupicati. They strarted with 2.0.6.1.
Is it an idea to downgrade to an ealier version?
I don’t think there is any known bug with the current versions that would cause files to be “missing” on the back end, so I don’t think I’d recommend downgrading.
Maybe there was corruption on that external USB drive that caused files to be lost?
Ok.
Of course I can never be 100% sure with an USB device.
Than I’ll assume this possibility.
Does this mean the pause button was used sometime in the middle of a backup, or no backups were run?
There is one odd issue where Duplicati deletes dindex files during a compact, gets some error, then loses track of its deletions. This bug is present in 2.0.5.1 though, so going back to that won’t help avoid the issue.
Unfortunately default logging doesn’t give lost file names. About → Show log → Live → Warning can show. Problem mentioned above would be deleted-then-forgotten-deleted dindex files, but not enough info to say what happened, e.g. did Duplicati think it wrote the file (per log), then the file didn’t actually make it to drive?
At start of backup, or at end? If at start, look carefully at the previous backup to see if anything went wrong.
Ideally you set log-file=<path> at log-file-log-level=Information so that you have evidence of all file activities.
If problem is reproducible occasionally, having records like these will help to understand what happened…
No, the backup was uninterrupted.
Few seconds after start.
I set log-file-log-level=verbose. Perhaps “infomation” is enough to have a better survey what happed during the last backup.
But indeed is it not unprobable that the USB drive had a filesystem damage. I’ll run a chkdsk before executing backup.to get a better feeling when a repair took place…
So I’m guessing that the 14 days was just the gap between backups. Does pre-gap backup log look good?
That’s when it looks at backup to see what’s there, which should (in lack of oddities) what prior backup left.
Information should show all the file transfers. If it weren’t a local drive, Retry is better. Networks error more.
