“Server” runs on SSD 512GB plus HDD 14TB.
Setup 3 backup jobs time daily scheduled to the same desination drive.
For energy consuption reasons the “Server” goes to Standby during night hours and is started in the Morning manually when needed. For unknown reasons the 14TB HDD fails to start when the Sytem is going up. This happend every some weeks within the last months.
I know this should not be, but its impossible to ask for replacement of the HDD even it is still under warranty since there are is nothing suspicious in smart data. On the other hand the system is quite old and to be replaced, so the reason might be a week capacitor.
Well today the system was started from PowerDown at 9:36am, I did not recocknize the HDD did not start poperly so Ducpikati started backups scheduled at 1:10,1:20,1:30pm
For sure all three backups failed but now two of it are missing files now and ask for repair.
The backup job that still works after the disk is available again showed this error message:
2025-04-28 13:10:46 +02 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: Die Operation Backup ist mit folgenden Fehler fehlgeschlagen: Ein nicht vorhandenes Gerät wurde angegeben. : '\\?\h:\Duplicati-backup_local\Datenarchiv'
IOException: Ein nicht vorhandenes Gerät wurde angegeben. : '\\?\h:\Duplicati-backup_local\Datenarchiv'
One backup job that now needs repair:
2025-04-28 13:32:14 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20250428T113000Z.dlist.zip.aes
IOException: Ein nicht vorhandenes Gerät wurde angegeben. : ‘\?\h:\Duplicati-backup_local\Privatdaten\duplicati-20250428T113000Z.dlist.zip.aes’
2025-04-28 13:32:55 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20241210T082545Z.dlist.zip.aes
IOException: Ein nicht vorhandenes Gerät wurde angegeben. : ‘\?\h:\Duplicati-backup_local\Privatdaten\duplicati-20241210T082545Z.dlist.zip.aes’
2025-04-28 13:33:35 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20250425T163459Z.dlist.zip.aes
IOException: Ein nicht vorhandenes Gerät wurde angegeben. : ‘\?\h:\Duplicati-backup_local\Privatdaten\duplicati-20250425T163459Z.dlist.zip.aes’
2025-04-28 13:34:16 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-i4322cee6c6ec4edda054f41aeda54c8e.dindex.zip.aes
IOException: Ein nicht vorhandenes Gerät wurde angegeben. : ‘\?\h:\Duplicati-backup_local\Privatdaten\duplicati-i4322cee6c6ec4edda054f41aeda54c8e.dindex.zip.aes’
2025-04-28 13:34:57 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-i5a8fd7a0d01f479fa34b8c7e18690483.dindex.zip.aes
IOException: Ein nicht vorhandenes Gerät wurde angegeben. : ‘\?\h:\Duplicati-backup_local\Privatdaten\duplicati-i5a8fd7a0d01f479fa34b8c7e18690483.dindex.zip.aes’
2025-04-28 13:35:38 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-if72e7cfaefc1490c9bc8ef4f2070f1d0.dindex.zip.aes
IOException: Ein nicht vorhandenes Gerät wurde angegeben. : ‘\?\h:\Duplicati-backup_local\Privatdaten\duplicati-if72e7cfaefc1490c9bc8ef4f2070f1d0.dindex.zip.aes’
2025-04-28 13:36:18 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-b084f571b936c408c9c87092f05ca12a2.dblock.zip.aes
IOException: Ein nicht vorhandenes Gerät wurde angegeben. : ‘\?\h:\Duplicati-backup_local\Privatdaten\duplicati-b084f571b936c408c9c87092f05ca12a2.dblock.zip.aes’
2025-04-28 13:36:59 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-b9dda665db1f54ecd8a7fd6b1c6753552.dblock.zip.aes
IOException: Ein nicht vorhandenes Gerät wurde angegeben. : ‘\?\h:\Duplicati-backup_local\Privatdaten\duplicati-b9dda665db1f54ecd8a7fd6b1c6753552.dblock.zip.aes’
2025-04-28 13:37:40 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-bcbc9fe8f41c44322b51cbb70dd67ed92.dblock.zip.aes
IOException: Ein nicht vorhandenes Gerät wurde angegeben. : ‘\?\h:\Duplicati-backup_local\Privatdaten\duplicati-bcbc9fe8f41c44322b51cbb70dd67ed92.dblock.zip.aes’
2025-04-28 13:37:40 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-Test results]: Verified 9 remote files with 9 problem(s)
And throws this started with attached destination disk:
Errors 1
* 2025-04-28 15:25:48 +02 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: Die Operation Backup ist mit folgenden Fehler fehlgeschlagen: Found 3 files that are missing from the remote storage, please run repair RemoteListVerificationException: Found 3 files that are missing from the remote storage, please run repair
I had the problem once before and a repair worked to fix the problem. But how can be a missing destination disk for whatever reason is messing up the backup setup ? And why in 2 of 3 cases?
Please let me know i there is anything to save/provide before I run the repair.
