After 4 days backup stalled to Google Drive. Tried abort after file finished, but of course it was not gonna finish. So I told it to abort now.
Then told it to run the backup again, came back with a database locked error
Restarted Duplicati and am now getting the following error:
Failed: One or more errors occurred.
Details: System.AggregateException: One or more errors occurred. ---> System.AggregateException: Detected non-empty blocksets with no associated blocks! ---> System.Exception: Detected non-empty blocksets with no associated blocks!
at Duplicati.Library.Main.Database.LocalDatabase.VerifyConsistency (System.Int64 blocksize, System.Int64 hashsize, System.Boolean verifyfilelists, System.Data.IDbTransaction transaction) [0x0017e] in <0ce58d578b8642d49036dc15fbad38f1>:0
at Duplicati.Library.Main.Operation.Backup.BackupDatabase+<>c__DisplayClass31_0.<VerifyConsistencyAsync>b__0 () [0x00000] in <0ce58d578b8642d49036dc15fbad38f1>:0
at Duplicati.Library.Main.Operation.Common.SingleRunner+<>c__DisplayClass6_0.<RunOnMain>b__0 () [0x00000] in <0ce58d578b8642d49036dc15fbad38f1>:0
at Duplicati.Library.Main.Operation.Common.SingleRunner+<>c__DisplayClass5_0`1+<<DoRunOnMain>b__1>d[T].MoveNext () [0x00038] in <0ce58d578b8642d49036dc15fbad38f1>:0
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <71d8ad678db34313b7f718a414dfcb25>:0
at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__19.MoveNext () [0x003c9] in <0ce58d578b8642d49036dc15fbad38f1>:0
at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__19.MoveNext () [0x0102c] in <0ce58d578b8642d49036dc15fbad38f1>:0
at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x0005d] in <6973ce2780de4b28aaa2c5ffc59993b1>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x00008] in <0ce58d578b8642d49036dc15fbad38f1>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass13_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x00035] in <0ce58d578b8642d49036dc15fbad38f1>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0011d] in <0ce58d578b8642d49036dc15fbad38f1>:0
---> (Inner Exception #0) System.AggregateException: Detected non-empty blocksets with no associated blocks! ---> System.Exception: Detected non-empty blocksets with no associated blocks!
---> (Inner Exception #0) System.Exception: Detected non-empty blocksets with no associated blocks!
at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__19.MoveNext () [0x003c9] in <0ce58d578b8642d49036dc15fbad38f1>:0 <---
---> (Inner Exception #1) System.AggregateException: One or more errors occurred. ---> System.Exception: Unable to find log in lookup table, this may be caused by attempting to transport call contexts between AppDomains (eg. with remoting calls)
at Duplicati.Library.Logging.Log.get_CurrentScope () [0x0004d] in <a0d17c5f1b8942efac55f621de8cc00b>:0
at Duplicati.Library.Logging.Log.WriteMessage (Duplicati.Library.Logging.LogMessageType type, System.String tag, System.String id, System.Exception ex, System.String message, System.Object[] arguments) [0x0001e] in <a0d17c5f1b8942efac55f621de8cc00b>:0
at Duplicati.Library.Logging.Log.WriteWarningMessage (System.String tag, System.String id, System.Exception ex, System.String message, System.Object[] arguments) [0x00000] in <a0d17c5f1b8942efac55f621de8cc00b>:0
at Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess+<>c.<Run>b__1_3 (System.String rootpath, System.String errorpath, System.Exception ex) [0x00000] in <0ce58d578b8642d49036dc15fbad38f1>:0
at Duplicati.Library.Utility.Utility+<EnumerateFileSystemEntries>d__23.MoveNext () [0x001d9] in <5336a8b903594fa5ae5a9692dae4b7fe>:0
at System.Linq.Enumerable+SelectManySingleSelectorIterator`2[TSource,TResult].MoveNext () [0x0006f] in <c0502b9f220448589f6c0bfcd98a6c9b>:0
at Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess+<ExpandWorkList>d__4.MoveNext () [0x000da] in <0ce58d578b8642d49036dc15fbad38f1>:0
at Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess+<>c__DisplayClass1_0+<<Run>b__0>d.MoveNext () [0x00263] in <0ce58d578b8642d49036dc15fbad38f1>:0
at CoCoL.AutomationExtensions+<RunTask>d__10`1[T].MoveNext () [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0
---> (Inner Exception #0) System.Exception: Unable to find log in lookup table, this may be caused by attempting to transport call contexts between AppDomains (eg. with remoting calls)
at CoCoL.AutomationExtensions+<RunTask>d__10`1[T].MoveNext () [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 <---
Log data:
2018-07-04 15:16:09 -06 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
I have repair and compacted, they come back with no problems, but run backup comes back with the above. Am not sure what to look for
Thankls
Myk
