I had the backup retention set to smart but it was only keeping one backup, I set it to custom and used 7D:1D,4W:1W,36M:1M but it is still only keeping 5 backups
Can you Export your backup job “as command-line” and paste it here? Mask sensitive information of course (passwords, etc).
Hello @rdwild and welcome to the forum!
How often were backups made? Retention doesn’t make backups, it only decides which to retain or delete.
You can see its steps at the end of any backup. Easiest way is About --> Show log --> Live --> Information.
Below are some log lines done a more long-term way using –log-file and –log-file-log-level. Information isn’t terribly verbose, but Profiling level is, so you might want to stick with Information unless you need all details.
Example:
2019-04-30 22:02:45 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-StartCheck]: Start checking if backups can be removed
2019-04-30 22:02:45 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-FramesAndIntervals]: Time frames and intervals pairs: 7.00:00:00 / 1.00:00:00, 28.00:00:00 / 7.00:00:00, 365.00:00:00 / 31.00:00:00
2019-04-30 22:02:45 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupList]: Backups to consider: 4/30/2019 9:00:00 PM, 4/30/2019 7:00:00 PM, 4/29/2019 7:00:00 PM, 4/28/2019 7:00:00 PM, 4/26/2019 3:54:41 PM, 4/15/2019 7:19:56 AM, 4/7/2019 6:16:14 PM, 3/29/2019 5:18:13 PM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-NextTimeAndFrame]: Next time frame and interval pair: 7.00:00:00 / 1.00:00:00
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsInFrame]: Backups in this time frame: 4/26/2019 3:54:41 PM, 4/28/2019 7:00:00 PM, 4/29/2019 7:00:00 PM, 4/30/2019 7:00:00 PM, 4/30/2019 9:00:00 PM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 4/26/2019 3:54:41 PM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 4/28/2019 7:00:00 PM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 4/29/2019 7:00:00 PM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 4/30/2019 7:00:00 PM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-DeletingBackups]: Deleting backup: 4/30/2019 9:00:00 PM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-NextTimeAndFrame]: Next time frame and interval pair: 28.00:00:00 / 7.00:00:00
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsInFrame]: Backups in this time frame: 4/7/2019 6:16:14 PM, 4/15/2019 7:19:56 AM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 4/7/2019 6:16:14 PM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 4/15/2019 7:19:56 AM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-NextTimeAndFrame]: Next time frame and interval pair: 365.00:00:00 / 31.00:00:00
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsInFrame]: Backups in this time frame: 3/29/2019 5:18:13 PM
2019-04-30 22:02:45 -04 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 3/29/2019 5:18:13 PM
2019-04-30 22:02:45 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsToDelete]: Backups outside of all time frames and thus getting deleted:
2019-04-30 22:02:45 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-AllBackupsToDelete]: All backups to delete: 4/30/2019 9:00:00 PM
“C:\Program Files\Duplicati 2\Duplicati.CommandLine.exe” backup “s3s://xxxxxx-backup/?s3-server-name=s3.amazonaws.com&s3-location-constraint=us-west-1&s3-storage-class=&auth-username=xxxxx&auth-password=xxxxx” “E:\NextCloud\Personal\” “E:\NextCloud\Photos\” --backup-name=“Test Backup - xxxxx” --dbpath=“C:\Users\rod.wild.xxxx\AppData\Local\Duplicati\88798079817970746882.sqlite” --encryption-module=aes --compression-module=zip --dblock-size=500MB --passphrase=“xxxxx” --retention-policy=“7D:1D,4W:1W,36M:1M” --disable-module=console-password-input
Excellent point! I didn’t even think that maybe jobs weren’t scheduled lol.
@rdwild your job definition looks fine to me - but yeah how often are backups scheduled to run?
Backups are scheduled to run every day at 1:00 AM (the computer is always on). Funny thing is, its now working or at least it seems to be. I think it started working after I ran a manual backup but I will try it on another machine and report back in a few weeks when I have more details.
May 9, 2019 1:03 AM: Result
May 8, 2019 1:00 AM: Result
May 7, 2019 3:11 PM: Result
May 7, 2019 3:00 PM: Result
May 7, 2019 1:03 AM: Result
May 6, 2019 1:03 AM: Result
May 5, 2019 1:08 AM: Result
May 4, 2019 8:48 AM: Result
Apr 27, 2019 1:04 AM: Result
Apr 26, 2019 1:03 AM: Result
Apr 25, 2019 1:03 AM: Result
Apr 24, 2019 1:00 AM: Result
Apr 23, 2019 1:00 AM: Result
Apr 22, 2019 1:03 AM: Result
Apr 21, 2019 1:03 AM: Result
Apr 20, 2019 1:03 AM: Result
Apr 19, 2019 1:03 AM: Result
Apr 18, 2019 1:03 AM: Result
Apr 17, 2019 1:03 AM: Result
Apr 16, 2019 1:03 AM: Result
Apr 15, 2019 1:03 AM: Result
Apr 14, 2019 1:04 AM: Result
Apr 13, 2019 1:03 AM: Result
Apr 12, 2019 1:03 AM: Result
Apr 11, 2019 8:51 AM: Result
Apr 10, 2019 9:11 AM: Result
Apr 10, 2019 1:12 AM: Result
Apr 9, 2019 1:03 AM: Result
Here is the log file for the last backup:
DeletedFiles: 0
DeletedFolders: 0
ModifiedFiles: 0
ExaminedFiles: 6897
OpenedFiles: 1
AddedFiles: 1
SizeOfModifiedFiles: 0
SizeOfAddedFiles: 84412
SizeOfExaminedFiles: 27374276418
SizeOfOpenedFiles: 84412
NotProcessedFiles: 0
AddedFolders: 0
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
CompactResults:
DeletedFileCount: 0
DownloadedFileCount: 0
UploadedFileCount: 0
DeletedFileSize: 0
DownloadedFileSize: 0
UploadedFileSize: 0
Dryrun: False
MainOperation: Compact
ParsedResult: Success
Version: 2.0.4.5 (2.0.4.5_beta_2018-11-28)
EndTime: 5/9/2019 1:00:08 AM (1557385208)
BeginTime: 5/9/2019 1:00:07 AM (1557385207)
Duration: 00:00:00.7595911
Messages: [
2019-05-09 01:00:00 -06 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started,
2019-05-09 01:00:00 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2019-05-09 01:00:01 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (128 bytes),
2019-05-09 01:00:03 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b2164a710972f4a5d9b924258271ee3c6.dblock.zip.aes (81.54 KB),
2019-05-09 01:00:04 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b2164a710972f4a5d9b924258271ee3c6.dblock.zip.aes (81.54 KB),
Warnings:
Errors:
BackendStatistics:
RemoteCalls: 8
BytesUploaded: 885175
BytesDownloaded: 525278775
FilesUploaded: 3
FilesDownloaded: 3
FilesDeleted: 0
FoldersCreated: 0
RetryAttempts: 0
UnknownFileSize: 0
UnknownFileCount: 0
KnownFileCount: 131
KnownFileSize: 26184836359
LastBackupDate: 5/9/2019 1:00:00 AM (1557385200)
BackupListCount: 7
TotalQuotaSpace: 0
FreeQuotaSpace: 0
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
Messages: [
Warnings:
Errors:
DeleteResults:
DeletedSets:
Dryrun: False
MainOperation: Delete
BeginTime: 5/9/2019 1:00:06 AM (1557385206)
Duration: 00:00:01.7730210
Messages: [
Warnings:
Errors:
RepairResults: null
TestResults:
MainOperation: Test
Verifications: [
Key: duplicati-20190509T070000Z.dlist.zip.aes
Value: ,
Key: duplicati-i1a602249084c43ec84b59453f1edd633.dindex.zip.aes
Value: ,
Key: duplicati-bc1c4d52e7daa48fa9c6242b4a2783bc6.dblock.zip.aes
Value:
EndTime: 5/9/2019 1:03:36 AM (1557385416)
BeginTime: 5/9/2019 1:00:08 AM (1557385208)
Duration: 00:03:27.6758673
Messages: [
Warnings:
Errors:
BeginTime: 5/9/2019 1:00:00 AM (1557385200)
Duration: 00:03:36.4052984
Messages: [
Warnings:
Errors:
Hello! Does Duplicati support 180m:1m,24h:1h,7D:1D,4W:1W? This function does not work. The minimum period is the “day” or function not correctly written? How to record “hours”, “minutes”?
Should work unless your’re still on 2.0.5.1_beta_2020-01-18 which had a bug and rejected m for minutes.
From About → Changelog
Fixed allowing minutes in retention rules, thanks @Pectojin
If you’re staying on 2.0.5.1 for some reason, you can rewrite 180m as 3h, and 1m as U to mean unlimited.
If it’s not above, what happens?
I use 2.0.6.3_beta_2021-06-17.
I think it works not correctly. It works strange … In the screenshot, the recovery points that are created for frequently changing file by the formula “180m:1m,24h:1h,7D:1D,4W:1W.”
Copies are created more often than three hours (180m: 1m), but not every day. The computer turns on every day, sometimes for a whole day, sometimes for a couple of hours.
Where can I read more? Here, for example, there is no information about the “hours” and “minutes”.
Retention refers to retaining certain backup versions (and deleting others), not creating versions, which is Schedule or manual. Is there anything on the list that violates the minimum age-based interval of 1 minute going back 180m, or any of the others? I can see how it looks like 3h - 24h range is thinned to 1h spacing.
New retention policy deletes old backups in a smart way is the announcement, which might be a bit dated.
Command line help:
--retention-policy (String): Reduce number of versions by deleting old
intermediate backups
Use this option to reduce the number of versions that are kept with
increasing version age by deleting most of the old backups. The expected
format is a comma separated list of colon separated time frame and
interval pairs. For example the value "7D:0s,3M:1D,10Y:2M" means "For 7
day keep all backups, for 3 months keep one backup every day, for 10
years one backup every 2nd month and delete every backup older than
this.". This option also supports using the specifier "U" to indicate an
unlimited time interval.
GUI help:
GUI smart and custom backup retention aren’t covered #83 is a request to revise the user manual section.
You can see the retention policy being applied at end of backup in an Information-level log-file. For example:
2021-10-06 09:45:56 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-StartCheck]: Start checking if backups can be removed
2021-10-06 09:45:56 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-FramesAndIntervals]: Time frames and intervals pairs: 1.00:00:00 / Keep all, 7.00:00:00 / 1.00:00:00, 28.00:00:00 / 7.00:00:00, 365.00:00:00 / 31.00:00:00
2021-10-06 09:45:56 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupList]: Backups to consider: 10/6/2021 8:40:04 AM, 10/6/2021 7:40:16 AM, 10/6/2021 6:57:12 AM, 10/5/2021 9:40:00 PM, 10/5/2021 8:40:04 PM, 10/5/2021 7:40:27 PM, 10/5/2021 6:40:07 PM, 10/5/2021 5:40:06 PM, 10/5/2021 4:40:14 PM, 10/5/2021 3:40:03 PM, 10/5/2021 2:40:05 PM, 10/5/2021 1:40:09 PM, 10/5/2021 12:40:20 PM, 10/5/2021 11:40:02 AM, 10/5/2021 10:40:00 AM, 10/5/2021 9:40:13 AM, 10/4/2021 10:40:03 AM, 10/3/2021 10:40:00 AM, 10/2/2021 10:40:00 AM, 10/1/2021 9:40:02 AM, 9/30/2021 9:40:02 AM, 9/29/2021 9:40:00 AM, 9/27/2021 8:40:00 AM, 9/26/2021 9:22:14 PM, 9/19/2021 8:40:00 PM, 9/12/2021 5:40:02 PM, 9/8/2021 9:41:05 AM, 8/7/2021 8:40:00 AM, 8/5/2021 1:40:04 PM, 7/4/2021 6:33:36 PM, 7/1/2021 9:40:03 AM, 6/24/2021 7:40:55 PM, 6/20/2021 9:33:01 AM, 6/20/2021 8:02:19 AM, 6/20/2021 6:58:27 AM, 5/25/2021 11:40:02 AM, 5/22/2021 1:58:23 PM, 5/22/2021 1:16:35 PM, 4/19/2021 12:40:01 PM, 4/2/2021 9:40:02 PM, 3/14/2021 2:40:01 PM, 2/6/2021 10:40:04 AM, 1/1/2021 10:40:04 AM, 11/26/2020 7:44:53 AM, 10/17/2020 8:40:00 PM, 10/14/2020 6:40:02 AM
2021-10-06 09:45:56 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsToDelete]: Backups outside of all time frames and thus getting deleted:
2021-10-06 09:45:56 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-AllBackupsToDelete]: All backups to delete: 10/5/2021 9:40:13 AM, 9/29/2021 9:40:00 AM
2021-10-06 09:45:56 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler-DeleteRemoteFileset]: Deleting 2 remote fileset(s) …
For a quicker peek (in reverse-chronological order), you can see About → Show log → Live → Information.
Thanks! Maybe I understanded. I will test.
No. I mistake.
