Hi all!
I’m having trouble getting Duplicati up and running after reinstalling my server, backup server and duplicati itself.
The backup target is a raspberry pi with hard drive attached to it, i want to backup via SSH (did it before, worked perfectly, but can’t remember what Duplicati version i used).
Currently there is a working and active connection from server to backup server, the tests during configuration show no problems. The user I use to login on the backup server has write access to the hard drive for backup.
I’ve made sure that the time is correct on all devices and everything is up to date (version 2.0.4.5).
The log on the backup task itself is Empty on the first tab, the second (remote) tab it shows that it did copy a few dblacks, 6 of them. But then stops with no error.
The log in the about section is pasted below. Can anyone see what to problem is?
System.AggregateException: One or more errors occurred. ---> System.AggregateException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object.
at Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock(String hash, Byte[] data, Int32 offset, Int32 size, CompressionHint hint)
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__12.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext()
at Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.<Backup>b__0(BackupResults result)
---> (Inner Exception #0) System.AggregateException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object.
---> (Inner Exception #0) System.NullReferenceException: Object reference not set to an instance of an object.
at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext()<---
---> (Inner Exception #1) System.AggregateException: One or more errors occurred. ---> Renci.SshNet.Common.SftpPermissionDeniedException: Permission denied
at Duplicati.Library.Main.Operation.Common.BackendHandler.<DoWithRetry>d__21`1.MoveNext()
at Duplicati.Library.Main.Operation.Common.BackendHandler.<>c__DisplayClass13_0.<<UploadFileAsync>b__1>d.MoveNext()
at Duplicati.Library.Main.Operation.Common.BackendHandler.<UploadFileAsync>d__13.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext()
---> (Inner Exception #0) Renci.SshNet.Common.SftpPermissionDeniedException: Permission denied
at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()<---
