Hello,
I have a very strange Problem with Duplicati 2.0.4.22_canary_2019-06-30. (Ubuntu 18.04 LTS Server VM)
A Backup Job with was working fine for Months is currently throwing expetions. Everything worked fine, and from one Day to another Day without System changes or Updates, there is now the following error:
I dont know what the cause is, maybe the path length is too long ?
error.zip (3.8 KB)
The Strange thing is, that another Job with another Backup Target is working without any Problems, and it has the same source Files.
I already deleted the Job which is failing and recreated it from scratch. It works for several Days and it now starts to throw expeptions again.
Best Regards from Germany.
Failed: One or more errors occurred.
Details: System.AggregateException: One or more errors occurred. —> System.AggregateException: Could not find file “/tmp/dup-c15067ac-3c11-4e20-b8cf-e432b4b25b8b”. —> System.IO.FileNotFoundException: Could not find file “/tmp/dup-c15067ac-3c11-4e20-b8cf-e432b4b25b8b”.
at System.IO.FileStream…ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0021a] in <8f2c484307284b51944a1a13a14c0266>:0
at System.IO.FileStream…ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0
at (wrapper remoting-invoke-with-check) System.IO.FileStream:.ctor (string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare)
at Duplicati.Library.Main.Volumes.VolumeReaderBase.LoadCompressor (System.String compressor, System.String file, Duplicati.Library.Main.Options options, System.IO.Stream& stream) [0x00000] in <63172ad53f6940c395d5db05d1717049>:0
at Duplicati.Library.Main.Volumes.VolumeReaderBase…ctor (System.String compressor, System.String file, Duplicati.Library.Main.Options options) [0x00007] in <63172ad53f6940c395d5db05d1717049>:0
at Duplicati.Library.Main.Volumes.BlockVolumeReader…ctor (System.String compressor, System.String file, Duplicati.Library.Main.Options options) [0x00010] in <63172ad53f6940c395d5db05d1717049>:0
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess+<>c__DisplayClass0_0+<b__0>d.MoveNext () [0x0023c] in <63172ad53f6940c395d5db05d1717049>:0
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0
at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0
at CoCoL.AutomationExtensions+d__10`1[T].MoveNext () [0x0007a] in <6973ce2780de4b28aaa2c5ffc59993b1>:0
at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0
at Duplicati.Library.Main.Operation.BackupHandler+d__12.MoveNext () [0x00349] in <63172ad53f6940c395d5db05d1717049>:0
at Duplicati.Library.Main.Operation.BackupHandler+d__19.MoveNext () [0x00a3a] in <63172ad53f6940c395d5db05d1717049>:0
at Duplicati.Library.Main.Operation.BackupHandler+d__19.MoveNext () [0x0103c] in <63172ad53f6940c395d5db05d1717049>:0
