Hey everyone, I’m wondering if someone with more experience and intelligence can help me track down why I can’t get Duplicati to backup.
I consistently get the error "Error while running Backup - Could not find file “” ". For context, I am using portainer and setting up duplicati using the app template within portainer. I have tried to recreate the container multiple times using many different ways… app template, manual container configuration, and docker compose. I have mapped my drives correctly and verified that the container can see every directory. Everything has the proper permissions, and I can configure the backup and all “tests” for destination and source pass during backup configuration within the Duplicati UI. Every single time I get presented with the same error.
I greatly appreciate any help on this topic, as a good friend and I have searched endlessly for someone with a similar issue. Thank you in advance!
When I go to check the logs in duplicati, this is the larger error message I get:
Sep 8, 2023 11:48 AM: Failed while executing "Backup" with id: 1
System.IO.FileNotFoundException: Could not find file ""
at System.IO.DriveInfo.GetDiskFreeSpace (System.String path, System.UInt64& availableFreeSpace, System.UInt64& totalSize, System.UInt64& totalFreeSpace) [0x00014] in <d636f104d58046fd9b195699bcb1a744>:0
at System.IO.DriveInfo.get_TotalSize () [0x00000] in <d636f104d58046fd9b195699bcb1a744>:0
at Duplicati.Library.Backend.File.get_Quota () [0x0000a] in <a11c194a0ed94b3ea73efea18edcd2ee>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.Collections.Generic.IEnumerable`1[T] protectedFiles) [0x00291] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.Collections.Generic.IEnumerable`1[T] protectedFiles) [0x00000] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x0005f] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0026f] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00349] in <30a34d71126b48248d040dda634ddad9>:0 ```
