Backup Dies with Timeout 90 minutes in
This is a backup on Ubuntu to Google Drive that has worked for a long time and now dies with
Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
TimeoutException: The operation has timed out
about 90 minutes, consistantly. Repairs succeed with nothing to repair. Here is the log
“DeletedFiles”: 0,
“DeletedFolders”: 0,
“ModifiedFiles”: 727,
“ExaminedFiles”: 696332,
“OpenedFiles”: 3824,
“AddedFiles”: 2726,
“SizeOfModifiedFiles”: 1262888491,
“SizeOfAddedFiles”: 1177951179,
“SizeOfExaminedFiles”: 232709278670,
“SizeOfOpenedFiles”: 2445562513,
“NotProcessedFiles”: 0,
“AddedFolders”: 0,
“TooLargeFiles”: 0,
“FilesWithError”: 0,
“TimestampChangedFiles”: 0,
“ModifiedFolders”: 0,
“ModifiedSymlinks”: 0,
“AddedSymlinks”: 0,
“DeletedSymlinks”: 0,
“PartialBackup”: false,
“Dryrun”: false,
“MainOperation”: “Backup”,
“CompactResults”: null,
“VacuumResults”: null,
“DeleteResults”: null,
“RepairResults”: null,
“TestResults”: null,
“ParsedResult”: “Fatal”,
“Interrupted”: false,
“Version”: “2.2.0.1 (2.2.0.1_stable_2025-11-09)”,
“EndTime”: “2025-11-29T01:07:08.8182902Z”,
“BeginTime”: “2025-11-28T23:21:22.9974793Z”,
“Duration”: “01:45:45.8208109”,
“MessagesActualLength”: 1888,
“WarningsActualLength”: 8,
“ErrorsActualLength”: 2,
“Messages”: [
“2025-11-28 18:21:22 -05 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started”,
“2025-11-28 18:24:30 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()”,
“2025-11-28 18:24:53 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (5.247 KiB)”,
“2025-11-28 18:24:54 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: QuotaInfo - Started: ()”,
“2025-11-28 18:24:54 -05 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-KeepIncompleteFile]: Keeping protected incomplete remote file listed as Temporary: duplicati-20251128T184310Z.dlist.zip.aes”,
“2025-11-28 18:25:02 -05 - [Information-Duplicati.Library.Main.Operation.Backup.UploadSyntheticFilelist-PreviousBackupFilelistUpload]: Uploading filelist from previous interrupted backup”,
“2025-11-28 18:25:25 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-20251128T184311Z.dlist.zip.aes (45.340 MiB)”,
“2025-11-28 18:26:12 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-20251128T184311Z.dlist.zip.aes (45.340 MiB)”,
“2025-11-28 18:28:46 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b920213491a6346b2b10a0994b7a406ee.dblock.zip.aes (50.023 MiB)”,
“2025-11-28 18:28:46 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b4205379e246a49fe8581587d2ffdbe78.dblock.zip.aes (50.075 MiB)”,
“2025-11-28 18:28:46 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b45c29ef0876142daa6743410ec9e94bc.dblock.zip.aes (50.079 MiB)”,
“2025-11-28 18:28:46 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bd9d7e9570f854224aaf345177c926003.dblock.zip.aes (50.055 MiB)”,
“2025-11-28 18:29:37 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Retrying: duplicati-b4205379e246a49fe8581587d2ffdbe78.dblock.zip.aes ()”,
“2025-11-28 18:29:38 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Retrying: duplicati-bd9d7e9570f854224aaf345177c926003.dblock.zip.aes ()”,
“2025-11-28 18:29:39 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Retrying: duplicati-b920213491a6346b2b10a0994b7a406ee.dblock.zip.aes ()”,
“2025-11-28 18:29:39 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Retrying: duplicati-b45c29ef0876142daa6743410ec9e94bc.dblock.zip.aes ()”,
“2025-11-28 18:29:47 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Rename: duplicati-b4205379e246a49fe8581587d2ffdbe78.dblock.zip.aes (50.075 MiB)”,
“2025-11-28 18:29:47 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Rename: duplicati-ba930c9cf93c84069a8fd3b989605a227.dblock.zip.aes (50.075 MiB)”,
“2025-11-28 18:29:47 -05 - [Information-Duplicati.Library.Main.Backend.PutOperation-RenameRemoteTargetFile]: Renaming “duplicati-b4205379e246a49fe8581587d2ffdbe78.dblock.zip.aes” to “duplicati-ba930c9cf93c84069a8fd3b989605a227.dblock.zip.aes””,
“2025-11-28 18:29:47 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-ba930c9cf93c84069a8fd3b989605a227.dblock.zip.aes (50.075 MiB)”
“Warnings”: [
“2025-11-28 20:07:08 -05 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerHandlerFailure]: Error in handler: The operation has timed out.\nTimeoutException: The operation has timed out.”,
“2025-11-28 20:07:08 -05 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeWhileActive]: Terminating 3 active uploads”,
“2025-11-28 20:07:08 -05 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeError]: Error in active upload: Cancelled”,
“2025-11-28 20:07:08 -05 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeError]: Terminating, but 2 active upload(s) are still active”,
“2025-11-28 20:07:08 -05 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeError]: Terminating, but 1 active upload(s) are still active”,
“2025-11-28 20:07:08 -05 - [Warning-Duplicati.Library.Main.Backend.BackendManager-BackendManagerShutdown]: Backend manager queue runner crashed\nAggregateException: One or more errors occurred. (The operation has timed out.)”
“Errors”: [
“2025-11-28 20:07:08 -05 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error\nTimeoutException: The operation has timed out.”,
“2025-11-28 20:07:08 -05 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: The operation Backup has failed\nTimeoutException: The operation has timed out.”
“BackendStatistics”: {
“RemoteCalls”: 385,
“BytesUploaded”: 205210507,
“BytesDownloaded”: 0,
“FilesUploaded”: 7,
“FilesDownloaded”: 0,
“FilesDeleted”: 0,
“FoldersCreated”: 0,
“RetryAttempts”: 375,
“UnknownFileSize”: 0,
“UnknownFileCount”: 0,
“KnownFileCount”: 5373,
“KnownFileSize”: 140381788473,
“KnownFilesets”: 21,
“LastBackupDate”: “2025-11-28T01:30:01-05:00”,
“BackupListCount”: 22,
“TotalQuotaSpace”: 109951162777600,
“FreeQuotaSpace”: 95660575223619,
“AssignedQuotaSpace”: -1,
“ReportedQuotaError”: false,
“ParsedResult”: “Success”,
“BeginTime”: “2025-11-28T23:21:22.9974834Z”,
“Duration”: “00:00:00”,
“MessagesActualLength”: 0,
“WarningsActualLength”: 0,
“ErrorsActualLength”: 0,
“Messages”: null,
“Warnings”: null,
“Errors”: null
2.2.0.1 CommandLine help googledrive gives 3 timeouts you can adjust:
  --short-timeout (Timespan): Short operation timeout
    The timeout in seconds for short operations like delete and create folder
    * default value: 30s
  --list-timeout (Timespan): List operation timeout
    The timeout in seconds for listing files and folders
    * default value: 10m
  --read-write-timeout (Timespan): Read/write operation timeout
    The timeout in seconds for read and write operations. If no activity is detected in this interval, a timeout error is raised
I don’t think you’re in a list, so that cuts it to 2. You can raise one at a time.
Personally, I think these timeouts are too low, as TCP retry may exceed them.
Duplicati can retry, and here it had to do it a lot. Watch this value while tuning.
