Webdav back-end running on Ubuntu that is on the same local net as the requesting PC. I use the public IP addr for consistency.
I have several other machine in this same building that are actively backing up without errors, but this one is the largest by far. That’s why I thought size might be playing a factor.
The error changed from this “actively refused connection” to the 500 error after I upgraded to the latest Canary. Hence the 2nd posting about that as I assumed the error was related to the newer version
Show log for the 95%:
Feb 9, 2025 3:03 AM: Failed while executing Backup “zz.rick-s.backups5” (id: 32)
System.AggregateException: One or more errors occurred. —> System.AggregateException: No connection could be made because the target machine actively refused it 47.155.192.51:443 —> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 47.155.192.51:443
at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<b__13_0>d.MoveNext()
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<FlushBackend>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- at CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task) at Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.<Backup>b__0(BackupResults result) at Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action
1 method)
at Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter)
—> (Inner Exception #0) System.AggregateException: No connection could be made because the target machine actively refused it 47.155.192.51:443 —> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 47.155.192.51:443
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<FlushBackend>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() ---> (Inner Exception #0) System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 47.155.192.51:443 at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult) at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at CoCoL.AutomationExtensions.<RunTask>d__10
1.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__19.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__20.MoveNext()<—
—> (Inner Exception #1) System.AggregateException: One or more errors occurred. —> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 47.155.192.51:443
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<FlushBackend>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- ---> (Inner Exception #0) System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 47.155.192.51:443 at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult) at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at CoCoL.AutomationExtensions.<RunTask>d__10
1.MoveNext()
