Backend manager queue runner did not stop
“Backend manager queue runner did not stop”
I recently updated the Duplicati version in one of our servers from 2.1.0.5_stable_2025-03-04 to 2.1.2.0_beta_2025-08-20. I was hoping that this new build solved another problem I was having (where the tool seemed to crash somehow, and the tray icon would disappear when hovering).
However, this new build seem to introduce a Warning, which says “Backup manager queue runner did not stop”. I was able to reproduce this, here’s more information about the setup:
  • Job runs on a Windows Server 2019 machine;
  • Destination backend is an FTP server;
  • Source files are ~200-500MB only
  • No warnings when:
    a. There are no changes to source files
    b. Changes are small (tested with a ~3KB file)
    c. Backend is a different SFTP server (instead of the regular FTP one)
I believe it’s likely this is not an issue, but I would prefer not to have this Warning, as it generates some commotion when some people look at the resulting DupReport e-mail…
So, is it an issue? Is it possible to fix it through some kind of configuration?
Thanks in advance!
P.S.: And thanks for the great tool (this is my first time posting here)!
Update: I have noticed that the Warning is not showing up on Saturdays for the past 30 days, but it does on the other days of the week since I installed it. It looks a lot to be related to some kind of congestion on the path up to the destination FTP machine, but I’ll have to keep looking as I can’t find any clues.
So does anyone have an idea on how to avoid this warning without changing the code? I think that’s probably just some timer that has to be tweaked. I’ll also keep looking at things like the FTP server config and pending sessions, for example.
Welcome to the forum @RodT
  --suppress-warnings (String): Suppress specific warnings
    Suppress warnings and log them as information instead. Use this if you
    need to silence specific warnings. This option accepts a comma separated
    list of warning IDs.
Maybe this one second timer, but this could use some dev help:
Thanks, this solved it for me. The exact string I used was --suppress-warnings=BackendManagerShutdown. Not sure if there’s a list of the warnings we can suppress somewhere, just took this from the code you also quoted in your reply.
I am curious about the 1 second delay limit, is there a reasoning behind this value? Maybe one of the devs can shed some light on this.
Same issue here. Running 2.3.0.1_stable_2026-04-24.
Backing up from Linux desktop(s) to OpenMediaVault via FTP.
Looks like everything worked, just the warning message was of concern. I plan to suppress it per suggestion, but I’m a little concerned there may be something of concern lurking in the message…
Any ideas?
Thanks in advance!
