B2 backup - SSL connection error
Duplicati version: 2.4.0.1 (via linuxserver docker image)
Host: Unraid 7.3.4
As of last night, all of my backups that write to B2 are failing with a System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
I do have one backup job that writes to a local drive, and that job is successful.
I upgraded Unraid from 7.3.2 to 7.3.4 last night, so that seems to be the impetus for the error. However, the error information from Duplicati isn’t very helpful, at least to my eyes. I’m hoping somebody could point me in the right direction to get to the root cause.
Here’s the full error text:
FailedOperation: The operation Backup has failed
 ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
   at System.Net.Security.SslStream.SendAuthResetSignal(ReadOnlySpan`1 alert, ExceptionDispatchInfo exception)
   at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions)
   at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](Boolean receiveFirst, Byte[] reAuthenticationData, CancellationToken cancellationToken)
   at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.InjectNewHttp11ConnectionAsync(QueueItem queueItem)
   at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
   at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.<SendCoreAsync>g__Core|4_0(HttpRequestMessage request, Boolean useAsync, CancellationToken cancellationToken)
   at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.<SendCoreAsync>g__Core|4_0(HttpRequestMessage request, Boolean useAsync, CancellationToken cancellationToken)
   at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
   at Duplicati.Library.Utility.Utility.WithTimeout[T](TimeSpan timeout, CancellationToken token, Func`2 func)
   at Duplicati.Library.Backend.Backblaze.B2.GetAsync(String remotename, Stream stream, CancellationToken cancellationToken)
   at Duplicati.Library.Main.Backend.BackendManager.GetOperation.DoGetFileAsync(IBackend backend, CancellationToken cancelToken)
   at Duplicati.Library.Main.Backend.BackendManager.GetOperation.ExecuteAsync(IBackend backend, CancellationToken cancelToken)
   at Duplicati.Library.Main.Backend.BackendManager.Handler.UntilCancelledAsync[TResult](Task`1 task, CancellationToken token)
   at Duplicati.Library.Main.Backend.BackendManager.Handler.ExecuteAsync[TResult](PendingOperation`1 op, CancellationToken cancellationToken)
   at Duplicati.Library.Main.Backend.BackendManager.Handler.ExecuteAsync(PendingOperationBase op, CancellationToken cancellationToken)
   at Duplicati.Library.Main.Backend.BackendManager.Handler.ExecuteWithRetryAsync(PendingOperationBase op, CancellationToken cancellationToken)
   at Duplicati.Library.Main.Backend.BackendManager.GetWithInfoAsync(String remotename, String hash, Int64 size, Boolean allowParityRepair, CancellationToken cancelToken)
   at Duplicati.Library.Main.Backend.BackendManager.GetFilesOverlappedAsync(IEnumerable`1 volumes, Boolean allowParityRepair, CancellationToken cancelToken)+MoveNext()
   at Duplicati.Library.Main.Backend.BackendManager.GetFilesOverlappedAsync(IEnumerable`1 volumes, Boolean allowParityRepair, CancellationToken cancelToken)+System.Threading.Tasks.Sources.IValueTaskSource<System.Boolean>.GetResult()
   at Duplicati.Library.Main.Operation.TestHandler.DoRunAsync(Int64 samples, LocalTestDatabase db, IBackendManager backend)
   at Duplicati.Library.Main.Operation.BackupHandler.PostBackupVerificationAsync(String currentFilelistVolume, String previousTemporaryFilelist, IBackendManager backendManager)
   at Duplicati.Library.Main.Controller.<>c.<<BackupAsync>b__23_0>d.MoveNext()
   at Duplicati.Library.Main.Controller.RunActionAsync[TRes,TCon](TRes result, String[] paths, IFilter filter, TCon context, Func`2 method)
Thank you for any guidance you can provide!
