Every time after backup I get a warning 2020-01-13 10:13:43 +03 - [Warning-Duplicati.Library.Modules.Builtin.CheckMonoSSL-MissingCerts]: No certificates found, you can install some with one of these commands: cert-sync /etc/ssl/certs/ca-certificates.crt #for Debian based systems cert-sync /etc/pki/tls/certs/ca-bundle.crt #for RedHat derivatives curl -O https://curl.haxx.se/ca/cacert.pem; cert-sync --user cacert.pem; rm cacert.pem #for MacOS Read more: http://www.mono-project.com/docs/about-mono/releases/3.12.0/#cert-sync ]
TlsTest.exe is increasingly obsolete because it can’t do TLS past 1.0. Github seems to require TLS 1.2.
FAQ: Security has a more up-to-date (though less sophisticated) test, and also mentions mozroots.exe which I’m not sure you’ve tried. There are also some troubleshooting ideas, directly from Mono project.
I’m not sure where mono certificates live, but do you have anything in /etc/mono/certstore/certs folder?
Thanks for the answer!
I couldn’t use the mozroots or certmgr tools - I get the message: “file not found”. I don’t know very well * nix systems, maybe I’m doing something wrong …
Also I did not find the folder / etc / mono / certstore / certs.
I found a folder /etc/ssl/certs It contains files:
Blockquote
Warning: Could not import C=CN, O=WoSign CA Limited, CN=Certification Authority of WoSign
System.Security.Cryptography.CryptographicException: Unable to decode certificate. —> System.DllNotFoundException: /volume1/.@plugins/AppCentral/mono/lib/…/lib/libmono-btls-shared.so
