Anyone know why Traefik's http auth would cause 401's in Duplicati?
Hey all,
A while back I set up some instances of Duplicati behind Traefik. I used Traefik’s http auth middleware in front of Duplicati to secure them. (This was before there was any password protection.)
This worked for a long time, but a while back something changed and my instances stopped loading my configuration. At the time I didn’t have the time to dig into it, and nothing was super important about the backups, so I just turned them off and didn’t try to figure it out until now.
Duplicati is running in a Docker container as part of a Swarm Stack. As of my testing today, it’s Duplicati - 2.1.0.4_stable_2025-01-31.
Traefik is on 2.11.
As far as I can tell, if you have the Traefik basic auth middleware enabled for your Duplicati service, after logging in using Duplicati’s UI password, you get a screen like this:
In Firefox’s network inspector, I see a lot of 401 errors.
In the console I see the same errors and can copy them. Here is one:
XHRGET
https://myinstance.mysite.mytld/api/v1/notifications
[HTTP/2 401  101ms]
GET
Status
401
VersionHTTP/2
Transferred176 B (17 B size)
Referrer Policystrict-origin-when-cross-origin
DNS ResolutionSystem
    content-length
    	17
    content-type
    	text/plain
    date
    	Sat, 08 Feb 2025 18:05:17 GMT
    www-authenticate
    	Basic realm="traefik"
    X-Firefox-Spdy
    	h2
    Accept
    	application/json, text/plain, */*
    Accept-Encoding
    	gzip, deflate, br, zstd
    Accept-Language
    	en-US,en;q=0.5
    Authorization
    	Bearer redacted_token
    Cache-Control
    	no-cache
    Connection
    	keep-alive
    Cookie
    	redacted_sessionid; default-theme=ngax
    DNT
    	1
    Host
    Pragma
    	no-cache
    Referer
    	https://myinstance.mysite.mytld/ngax/index.html
    Sec-Fetch-Dest
    	empty
    Sec-Fetch-Mode
    	cors
    Sec-Fetch-Site
    	same-origin
    TE
    	trailers
    User-Agent
    	Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:133.0) Gecko/20100101 Firefox/133.0
Anyway, I’m just curious if anyone has any ideas what is going on. Have both the http auth user/password, and Duplicati’s password would be good. Adds an extra layer of defense. :slight_smile:
One random thought, could the basic auth be messing with the websockets? Traefik supports websockets automatically, but maybe the middleware doesn’t?
v2.1.0.4_stable_2025-01-31
v2.1.0.3_beta_2025-01-22
v2.1.0.2_beta_2024-11-29
Mandatory password and new authentication scheme for server
Server authentication model
Increasing security for Duplicati’s web server
Reverse Proxy Apache2 is an effort to get that up. Canary mentioned on Feb 6 isn’t out yet.
So, I had seen the info about the new login password.
If I turn off Traefik’s basic auth middleware, and just use the password I set for Duplicati via DUPLICATI__WEBSERVICE_PASSWORD, Duplicati does work.
After, reading those links, and thinking things through a bit, I’m guessing that Traefik is stomping on Duplicati’s Authorization header.
Which would explain the 401’s.
Thanks!
