I’ve seen other topics with this error, related to OneDrive recently update, but I think my case is different.
I have a Ubuntu server that makes everyday backup of to sets of files to two onedrive accounts. Both of them have been working ok for the last 2 months, but one of them are stuck with this error since tuesday.
This is the error reported:
Fatal error
System.ArgumentException: An item with the same key has already been added.
at Duplicati.Library.Main.BackendManager.List () <0x40c86ba0 + 0x0016b> in :0
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, IBackendWriter log, System.String protectedfile) <0x40c83870 + 0x0015f> in :0
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, IBackendWriter log, System.String protectedfile) <0x40c82e20 + 0x000cb> in :0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) <0x40c828f0 + 0x001af> in :0
I don’t know how to recover the situation and what is the problem that causes it. Other problem is that if I want to recover some file from this backup, the error repeats and none is restored (although the UI reports that the restore was succesful)
Some more data: I’ve tried to repair database, verify files, and recreate database, but in all cases the error appears.
At this point, I can’t do more restore test, because database is deleted, so I can’t get the list of files to restore, and can’t recreate database.
I guess the only solution is to delete all the uploaded and corrupted backup and rebuild and reupload the 400GiB backup, and give up the backup history.
Yes, that is possible. You can run the list call with something like:
Duplicati.CommandLine.BackendTool.exe LIST onedrive://path?authid=xyz`
This will call the OneDrive API with the exact same code that is normally used inside Duplicati and will show the output. But for this problem, the error happens before the LIST operation fails, so the output will probably not reveal the raw list of files.
Yes, the error appears before. This is the output of the command:
Invalid type Microsoft.WindowsAzure.Storage.Blob.BlobEncryptionPolicy for instance field Microsoft.WindowsAzure.Storage.Blob.BlobRequestOptions:k__BackingField
Invalid type Microsoft.WindowsAzure.Storage.Queue.QueueEncryptionPolicy for instance field Microsoft.WindowsAzure.Storage.Queue.QueueRequestOptions:k__BackingField
Invalid type Microsoft.WindowsAzure.Storage.Table.TableEncryptionPolicy for instance field Microsoft.WindowsAzure.Storage.Table.TableRequestOptions:k__BackingField
Name Dir/File LastChange Size
Command failed: An item with the same key has already been added.
at System.ThrowHelper.ThrowArgumentException (ExceptionResource resource) <0x4103b7c0 + 0x0002b> in :0
at System.Collections.Generic.Dictionary2[TKey,TValue].Insert (System.Collections.Generic.TKey key, System.Collections.Generic.TValue value, Boolean add) <0x40e341d0 + 0x0018b> in <filename unknown>:0 at System.Collections.Generic.Dictionary2[TKey,TValue].Add (System.Collections.Generic.TKey key, System.Collections.Generic.TValue value) <0x40e34190 + 0x00023> in :0
at Duplicati.Library.Backend.OneDrive.List () <0x40f701b0 + 0x002d1> in :0
at Duplicati.CommandLine.BackendTool.Program.RealMain (System.String _args) <0x40f54c50 + 0x00854> in :0
With my other OneDrive backup the command runs ok and the list is printed well.
