I know that duplicati currently has an option for alternate-destination-marker. What I’d really like to see is that when someone selects that option, it immediately offers to write that marker to the destination for them so that the destination that is currently accessible has that marker and is effectively “annointed” for duplicati backups.
I’m not sure if this is easy to implement or not but I just thought it might aid the USB external harddrive scenario in windows.
I like the idea, though I think it would need more coding to get it working than it deserves…
I am a bit worried about the interface for it. Are you suggesting a manual “do it now” button or that when the setting is saved it checks the destination right then and offers to create if not found?
I think it could be done during the “save” process. If the destination is “file” and the --alternate-destination-marker is set, check if the file is currently available, and ask to create it if not?
I was thinking that the file would only be written on the initial job creation?
For the drive-ID, that would be a new feature. I guess we could look at the destination, determine that it was a drive (checking for removable drive was buggy when I last looked), and ask to fill in a new --removable-drive-guid option, or check it in case it was already filled.
