After update to 2.2.0.3 no scheduled taks are running any more
I am using Duplicati on a Windows PC for a long time and I have setup several scheduled backup tasks to run every Saturday in the morning around 7 o’clock. This means when I start my PC some hours later, the scheduled tasks will run.
This worked fine until I did update Duplicati to version 2.2.0.3 (from 2.2.0.1). Now the scheduled tasks do not start any more and in the WebGUI its shown that the next run should have already happened.
Has anybody an idea how I can repair my installation?
Thanks and regards,
Andreas
Estoy exactamente en el mismo caso, no inicia la tarea si no está el GUI abierto…
¿Alguna solución, por favor?
I’m exactly in the same situation; the task doesn’t start if the GUI isn’t open… Any solution, please?
After I did set the option “Pause after startup or hibernation“ to “None” the scheduled tasks did start again.
With this options set to a value like “6 min” the tasks did not start at all, means not after that time.
Yo ya tenía ese valor y sigue sin funcionar salvo que mantenga la UI abierta…
