Hey all
I am having a issue with one of my backups to wasabi. There are 2 backups which are backing up to one of my wasabi bucket. One is working fine but the 2nd one keeps come with “Failed: Access Denied” (Please see full log at bottom of this post)
I was trying to get Bucket level access to work but didn’t have much luck. Which I believe might be casing this issue.
Tonight I created a test user at the wasabi end and try this user for the backup with the same out come.
Details: Amazon.S3.AmazonS3Exception: Access Denied —> Amazon.Runtime.Internal.HttpErrorResponseException: The remote server returned an error: (403) Forbidden. —> System.Net.WebException: The remote server returned an error: (403) Forbidden.
at System.Net.HttpWebRequest.GetResponseFromData (System.Net.WebResponseStream stream, System.Threading.CancellationToken cancellationToken) [0x00146] in <33b19a7ad5234d94abf4fd9b47566616>:0
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <33b19a7ad5234d94abf4fd9b47566616>:0
at System.Net.HttpWebRequest.GetResponse () [0x00016] in <33b19a7ad5234d94abf4fd9b47566616>:0
at Amazon.Runtime.Internal.HttpRequest.GetResponse () [0x00000] in :0
at Amazon.Runtime.Internal.HttpRequest.GetResponse () [0x0003a] in :0
at Amazon.Runtime.Internal.HttpHandler1[TRequestContent].InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x00073] in <e28e89f25c1649a69062a2c53f89d718>:0 at Amazon.Runtime.Internal.PipelineHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x0000e] in <e28e89f25c1649a69062a2c53f89d718>:0 at Amazon.Runtime.Internal.RedirectHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x00000] in <e28e89f25c1649a69062a2c53f89d718>:0 at Amazon.Runtime.Internal.PipelineHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x0000e] in <e28e89f25c1649a69062a2c53f89d718>:0 at Amazon.Runtime.Internal.Unmarshaller.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x00000] in <e28e89f25c1649a69062a2c53f89d718>:0 at Amazon.Runtime.Internal.PipelineHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x0000e] in <e28e89f25c1649a69062a2c53f89d718>:0 at Amazon.S3.Internal.AmazonS3ResponseHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x00000] in <79796cc3f14a4a2d81133207810e557f>:0 at Amazon.Runtime.Internal.PipelineHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x0000e] in <e28e89f25c1649a69062a2c53f89d718>:0 at Amazon.Runtime.Internal.ErrorHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x00000] in <e28e89f25c1649a69062a2c53f89d718>:0 --- End of inner exception stack trace --- at Duplicati.Library.Main.BackendManager.Delete (System.String remotename, System.Int64 size, System.Boolean synchronous) [0x0005c] in <e60bc008dd1b454d861cfacbdd3760b9>:0 at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.Collections.Generic.IEnumerable1[T] protectedFiles) [0x0061a] in :0
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.Collections.Generic.IEnumerable1[T] protectedFiles) [0x00000] in <e60bc008dd1b454d861cfacbdd3760b9>:0 at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x0011d] in <e60bc008dd1b454d861cfacbdd3760b9>:0 at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <e60bc008dd1b454d861cfacbdd3760b9>:0 at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x00050] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0 at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <e60bc008dd1b454d861cfacbdd3760b9>:0 at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <e60bc008dd1b454d861cfacbdd3760b9>:0 at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action1[T] method) [0x0011c] in :0
Log data:
2023-02-01 21:39:21 +13 - [Warning-Duplicati.Library.Main.BackendManager-DeleteFileFailure]: Failed to recover from error deleting file duplicati-b286efeab17dc4be7a1315f181c395a1e.dblock.zip.aes
System.NullReferenceException: Object reference not set to an instance of an object
at Duplicati.Library.Main.BackendManager.ThreadRun () [0x003e3] in :0
2023-02-01 21:39:21 +13 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.Collections.Generic.IEnumerable`1[T] protectedFiles) [0x00000] in :0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x0011d] in :0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00452] in :0
