And also today, I apologize for my bad english.
The context comes from DeepL
Remember, if anyone answers me.
Today I selected “Add Backup” via the WebGUI.
The target is a network hard disk, it is LUKS encrypted and has an ext4 file system. I access it via SSH and create the backup using Duplicati PGP encryption
I do this from the same computer to the same target with the same method since a long time with different data. But with the new directories that are to be backed up with this method, the error message appears as in the subject.
Unfortunately I can’t see which data is causing the error, because the backup starts first and backs up a large part of data before the error occurs.
You might have to try backing up your area adding a bit at a time until you can locate the bad name.
Another option would be to set up a log-file at log-file-log-level=verbose and search with a good tool.
Possibly you will need one that will let you find lines ending with a space or period. Finding folders is simpler because Duplicati logs folders with backslash at the end. Below is a test set of odd folders:
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: C:\tmp\sub1\subend\
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: C:\tmp\sub1\subend \
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: C:\tmp\sub1\subend.\
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: C:\tmp\sub1\subend\dir_withoutspace_subdir\
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: C:\tmp\sub1\subend.\dir_without_space
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: C:\tmp\sub1\subend \dir_with_space
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: C:\tmp\sub1\subend\dir_without_space
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-AddDirectory]: Adding directory C:\tmp\sub1\subend.\
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FilePreFilterProcess.FileEntry-CheckFileForChanges]: Checking file for changes C:\tmp\sub1\subend.\dir_without_space, new: True, timestamp changed: True, size changed: True, metadatachanged: True, 7/11/2020 6:31:48 PM vs 1/1/0001 12:00:00 AM
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-AddDirectory]: Adding directory C:\tmp\sub1\subend\dir_withoutspace_subdir\
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-NewFile]: New file C:\tmp\sub1\subend.\dir_without_space
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-AddDirectory]: Adding directory C:\tmp\sub1\subend \
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FilePreFilterProcess.FileEntry-CheckFileForChanges]: Checking file for changes C:\tmp\sub1\subend \dir_with_space, new: True, timestamp changed: True, size changed: True, metadatachanged: True, 7/11/2020 6:31:25 PM vs 1/1/0001 12:00:00 AM
2020-08-01 20:59:34 -04 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-NewFile]: New file C:\tmp\sub1\subend \dir_with_space
