As of 3 December, all backups (all macOS) to my personal (S3 Compatible) MinIO web server fail. I see this on a client system:
A WebException with status TrustFailure was thrown.
This is, I think, something about certificates (duh). But which ones? Mono?
Full log:
Amazon.Runtime.AmazonServiceException: A WebException with status TrustFailure was thrown. ---> System.Net.WebException: Error: TrustFailure (Authentication failed, see inner exception.) ---> System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception. ---> Mono.Security.Interface.TlsException: CertificateUnknown
at Mono.AppleTls.AppleTlsContext.EvaluateTrust () [0x000c6] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at Mono.AppleTls.AppleTlsContext.ProcessHandshake () [0x00075] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000da] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool)
at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000fc] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00262] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x0016a] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001ba] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x0021a] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00141] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at System.Net.WebOperation.Run () [0x0009a] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x00094] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at System.Net.HttpWebRequest.GetResponse () [0x00016] in <31ab9cbd49d84bc9a3c66a80af36e0cb>:0
at Amazon.Runtime.Internal.HttpRequest.GetResponse () [0x0003b] in <e28e89f25c1649a69062a2c53f89d718>:0
at Amazon.Runtime.Internal.HttpHandler`1[TRequestContent].InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x00073] in <e28e89f25c1649a69062a2c53f89d718>:0
at Amazon.Runtime.Internal.PipelineHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x0000e] in <e28e89f25c1649a69062a2c53f89d718>:0
at Amazon.Runtime.Internal.RedirectHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x00000] in <e28e89f25c1649a69062a2c53f89d718>:0
at Amazon.Runtime.Internal.Unmarshaller.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x00000] in <e28e89f25c1649a69062a2c53f89d718>:0
at Amazon.S3.Internal.AmazonS3ResponseHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x00000] in <79796cc3f14a4a2d81133207810e557f>:0
at Amazon.Runtime.Internal.ErrorHandler.InvokeSync (Amazon.Runtime.IExecutionContext executionContext) [0x00000] in <e28e89f25c1649a69062a2c53f89d718>:0
at Duplicati.Library.Main.BackendManager.List () [0x00049] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.Collections.Generic.IEnumerable`1[T] protectedFiles) [0x0000d] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.Collections.Generic.IEnumerable`1[T] protectedFiles) [0x00000] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x0011d] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0026f] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00349] in <156011ea63b34859b4073abdbf0b1573>:0
