504 errors the past two days backing up to OneDrive v2
Starting yesterday, my backups to OneDrive have been failing with errors of the for
StatusCode: 504, ReasonPhrase: ‘Gateway Timeout’,
One such result, from a few minutes ago:
Duplicati.Library.Backend.MicrosoftGraph.MicrosoftGraphException: GatewayTimeout: Gateway Timeout error from request https://graph.microsoft.com/v1.0/me/drive/root:/Selected_P_Folders:/children
Method: GET, RequestUri: ‘https://graph.microsoft.com/v1.0/me/drive/root:/Selected_P_Folders:/children’, Version: 1.1, Content: , Headers:
User-Agent: Duplicati/2.0.4.5
Authorization: Bearer ABC…XYZ
StatusCode: 504, ReasonPhrase: ‘Gateway Timeout’, Version: 1.1, Content: System.Net.Http.StreamContent, Headers:
Transfer-Encoding: chunked
request-id: 534ecdb6-4259-4ce2-bf69-b840181f0841
client-request-id: 534ecdb6-4259-4ce2-bf69-b840181f0841
x-ms-ags-diagnostic: {“ServerInfo”:{“DataCenter”:“South Central US”,“Slice”:“SliceC”,“Ring”:“5”,“ScaleUnit”:“003”,“RoleInstance”:“AGSFE_IN_3”,“ADSiteName”:“SCU”}}
Duration: 20009.39
Strict-Transport-Security: max-age=31536000
Cache-Control: private
Date: Wed, 21 Aug 2019 19:33:26 GMT
Content-Type: application/json
“error”: {
“code”: “UnknownError”,
“message”: “”,
“innerError”: {
“request-id”: “534ecdb6-4259-4ce2-bf69-b840181f0841”,
“date”: “2019-08-21T19:33:26”
at Duplicati.Library.Main.BackendManager.List()
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
at Duplicati.Library.Main.Operation.BackupHandler.d__19.MoveNext()
at Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.b__0(BackupResults result)
at Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter)
Another, from yesterday:
System.AggregateException: One or more errors occurred. —> System.AggregateException: Object reference not set to an instance of an object. —> System.NullReferenceException: Object reference not set to an instance of an object.
at Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock(String hash, Byte data, Int32 offset, Int32 size, CompressionHint hint)
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<b__0>d.MoveNext()
at CoCoL.AutomationExtensions.d__10`1.MoveNext()
(more stack trace after this,then)
—> (Inner Exception #1) System.AggregateException: One or more errors occurred. —> Duplicati.Library.Backend.MicrosoftGraph.MicrosoftGraphException: GatewayTimeout: Gateway Timeout error from request https://graph.microsoft.com/v1.0/me/drive/root:/Tim_Selected_K_Folders/duplicati-bbe8bb0d83c1344a4b6dcaece72cda6fd.dblock.zip.aes:/createUploadSession
Method: POST, RequestUri: ‘https://graph.microsoft.com/v1.0/me/drive/root:/Tim_Selected_K_Folders/duplicati-bbe8bb0d83c1344a4b6dcaece72cda6fd.dblock.zip.aes:/createUploadSession’, Version: 1.1, Content: , Headers:
request-id: 8db412ed-0b48-4691-9a35-a62422b05956
client-request-id: 8db412ed-0b48-4691-9a35-a62422b05956
x-ms-ags-diagnostic: {“ServerInfo”:{“DataCenter”:“South Central US”,“Slice”:“SliceC”,“Ring”:“4”,“ScaleUnit”:“000”,“RoleInstance”:“AGSFE_IN_0”,“ADSiteName”:“SCU”}}
Duration: 10058.0562
Date: Tue, 20 Aug 2019 17:38:27 GMT
“error”: {
“message”: “”,
“innerError”: {
“request-id”: “8db412ed-0b48-4691-9a35-a62422b05956”,
“date”: “2019-08-20T17:38:27”
Any wisdom? Backups to other backends (Google, AWS S3) work fine.
is about the only thing I recognize from the info. While listing has been known to fail at 5000 files, I think it breaks differently (if it still breaks at all). You could read “BackendStatistics” “KnownFileCount” in job log.
This is a server-side error, and possibly Microsoft will just fix it. FWIW it went fine on my test yesterday…
If yours continues, I guess you could try further debugging, with some of the following actions to isolate it:
  • Try Destination screen “Test connection” button which usually does a list. Does it work? Is it quick? OneDrive operations time out at 100 seconds unless –http-operation-timeout is raised, but a list is usually a pretty small amount of data compared to the many megabytes that an upload would take.
  • While looking at Destination screen, open another tab and start down direct restore path which will probably need to do a file list to even get as far as showing you the dropdown of versions. Could it?
  • Duplicati.CommandLine.BackendTool.exe can also get a file list. Maybe code differs a bit from GUI.
  • Try third-party tools such as Cyberduck or rclone. They need to set up their own OneDrive access.
  • You could see if getting Duplicati new access to OneDrive helps, but bug doesn’t “look” like access.
Sorry for the extended lack of followup.
As predicted, it magically fixed itself. Yay, I guess.
Thank you for the wisdom.
