Hello,
Hoping I could get some verification as to if these errors are substantial. If they are I’d be happy to submit a bug report to help along with development.
I’m backing up to s3, looks like Duplicati is unable to process a couple of paths. It also looks like its not processing a couple of files that itself created. To note I have Duplicati running inside a docker container (courtesy of linuxserver.io)
Log below is truncated to just show warnings and errors, but i’d be happy to include the whole log.
Warnings: [
2019-01-27 10:20:55 -05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /source/docker/home-assistant-config/.storage/auth,
2019-01-27 10:20:55 -05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /source/docker/home-assistant-config/.storage/auth_provider.homeassistant
Errors: [
2019-01-27 10:26:28 -05 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20190127T151714Z.dlist.zip.aes,
2019-01-27 10:27:09 -05 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-i158cdb3cb3dc4de1b5cdd946dcead74e.dindex.zip.aes,
2019-01-27 10:27:49 -05 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-b81dd8e30a94f45fc99f26c5f81c77ce8.dblock.zip.aes
Warnings: [
Errors: [
Warnings: [
Errors: [
ParsedResult: Error
Warnings: [
Errors: [
