I have a system on Duplicati 2.4.1.0 that I am trying to implement multi-destination backups on.
The primary destination is an SMB share on a local NAS. The secondary destination is a remote WebDAV server.
It “works” for the most part, in that it executes and at the end both destinations are synchronized, but with every single backup run, it deletes every file on the WebDAV server and re-uploads them again. All off them, every single time.
The confusing part for me is that I have implemented this on other systems, and it works just fine in those places, so I’m somewhat at a loss as to why this one might be behaving this way. I have an identically configured system that is still running 2.4.0.1 that does not do this.
Also, on a somewhat related topic, multi-destination behaves in an inefficient way if the backup files were already copied to the secondary destination, such as by sneaker-net. Duplicati will delete all existing files from the second destination and re-upload new copies, even if they are exactly the same files that were already there.
Please let me know if I am misunderstanding any of this.
Thanks for reporting. This has been reported before but I was not able to figure out what the cause was, but this time I did.
The reason is timezones. If the timezone is positive in relation to UTC, then the files are considered “newer” than the source and so they are re-uploaded (assuming something has changed them).
This was only triggered for WebDAV, rclone, Tencent, pCloud and Storj because the other backends correctly anchor the time in UTC so the compare is working despite timezone differences.
I will be fixed in next canary and included in the next point-release for 2.4.
There are no immediate general workarounds. Some suggestions until the fix is out:
Avoid WebDAV as the secondary target, use it as primary (not really great here)
Use a file:// primary instead of smb:// because the file backend does not return UTC times but SMB does
Set Duplicati’s timezone to UTC (not really feasible unless this is a Docker instance or similar)
Avoid the secondary destination for now, and then have a separate Sync job that copies from SMB to WebDAV.
That sounds both plausible and implausible at the same time. The backups run once per day, and so I would think that would be enough for any problems with timestamps to wring themselves out … unless it’s looking for them to be identical and is upset if they are not … thus deleting and re-uploading everything.
I won’t argue with your interpretation. Maybe I’ll try switching to file:// for one of the smaller jobs and see what happens. Is there any downside to doing this?
The problem is that the WebDAV backend writes the file, say at 10:00+01.
When Duplicati later reads the file list it sees 10:00 and assumes it is UTC, so compares it as 11:00 which is then newer than what it expects. This triggers a rewrite, which itself has the same issue, so it never fixes itself.
I guess you could go and manually change the “last modified” timestamp on all files and it would go away (until a new file is uploaded).
